2005 toyota prius VSC, ABS, (!) and emergency brake light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zico, Jan 25, 2014.
  1. zico
    zico New Member
    2005 toyota prius VSC, ABS, (!) and emergency brake light on/hybrid system warning light
  2. YOLOsoBuyaPrius
    YOLOsoBuyaPrius Junior Member
    77
    Nebraska
    Is the battery fan running continuously or more than usual? Can it be driven?
  3. Patrick Wong
    18,200
    6,479
    When the Prius is READY, look at the inverter coolant reservoir for fluid turbulence. If you do not see this, the inverter coolant pump has failed and that is the reason for the warning lights that are displayed.
    koolingit likes this.
  4. ZaX
    ZaX Junior Member
    Sesvete, Grad Zagreb, Croatia
    Few days ago had same problem. Charged my 12V battery, problem solved. Check you 12v voltage. Cheers
    SM-N9005 ?
  5. zico
    zico New Member
    my 12 votls battery is ok
  6. bisco
    49,797
    did you run out of gas?
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    As the Prius 12v system is slightly different to traditional cars, could you clarify how you checked the 12v just to make sure all is well. A silently failing 12v is often missed in diagnostics and can throw the sorts of errors you're reporting.
  8. Austre
    Austre Junior Member
    I have a Prius 2007 with the same problem, plus when I press the brake pedal, it suddenly loose pressure and makes a lot of noises on engine bay, plus an alarm high-pitched sound coming from under dash. :mad: I've been reading complains about the same problem form another prius owners. Does anybody know about a TSB or Toyota recalls related to this same problem????
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    After reading this forum for 4 years I don't think I've come across a fault like you describe BUT if you are losing brake pressure I wouldn't drive the car and call for it to be taken away and checked - URGENTLY.
  10. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    The alarm is warning you of low brake fluid pressure. You might check to see if your brake fluid reservoir is full and if you see any brake fluid leaking.
    Avi
    GrumpyCabbie likes this.
