2006 Prius MPG dropoff - battery pack?
Discussion in 'Gen 2 Prius Technical Discussion' started by DPSWL, Sep 13, 2012.
  1. DPSWL
    DPSWL
    Expand Collapse
    Junior Member
    I am a newbie to this site, but love my prius.
    I have noticed a significant (15 to 20%) drop-off in mpg in the last 6 months or so. My 2006 prius at 95,000 miles is just short of the warranty on the battery pack. I brought it in to the dealership and they ran the routine computer diagnostics and said everything looks good. I fully expected them to tell me that the performance on the batterpack had fallen off, so I was a bit put out. The guy actually got a bit defensive with me when I asked him some further questions about what the criteria are for determining whether the battery back was performing as it is supposed to in order to get the maximum MPGs.
    Is it possible that the diagnostic machine would indicate that everything is fine, but the battery pack NOT be fully up to par?
    Sadly, I'm not sure I trust my dealer with acknowledging a functioning, but poor performing battery pack just short of the warranty period being up.
    Any comments or suggestions are greatly appreciated.
  2. richard schumacher
    richard schumacher
    Expand Collapse
    shortbus driver
    7,652
    892
    United States
    As a long-time owner I assume you know about low rolling resistance tires, tire inflation, the effects of short trips, not overfilling the oil, and the like. If you still have the original 12V battery you should check it yourself, either with a voltmeter or the built-in test procedure:
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
  3. edthefox5
    edthefox5
    Expand Collapse
    Senior Member
    4,083
    832
    Clearwater, Florida
    Replace Inverter Coolant and install Mobil 1 synthetic oil. Replace trans fluid.
  4. uart
    uart
    Expand Collapse
    Senior Member
    3,994
    912
    Australia
    Hi DPSWL. They generally wont do anything unless it throws an error code. Apparently the battery can lose a very large percent of its capacity without throwing a code, provided that the other parameters like voltage and resistance are ok.
    That being said however, tests have shown the Prius can still get very good fuel economy even with a large loss of battery capacity, and there are many other sources of possible MPG loss to consider.
    Have you noticed ant anomalous behavior of your traction battery SOC during regular driving?
