2007 HID Headlight issues, already replaced bulb and ballast
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jason Sayre, Sep 22, 2014.
  1. Jason Sayre
    Jason Sayre New Member
    Tomball, TX
    So I started having the issue with my drivers side headlight going out and saw the many threads regarding issues with the bulbs and ballast. I started out purchasing a new bulb, from ebay
    TOYOTA PRIUS GENIUNE PART PHILIPS D4R 42406 XENON HID HEADLIGHT LIGHT LAMP OEM
    Came in "Toyota" box. Got the bulb in and still had issues with the light turning off... so then I bought the after market ballast and replaced it yesterday. Light still going off.... Any other suggestions on what to check? Just read the article regarding bulbs, going to pull out the one I just got and have a better look at it.... Not all HID Bulbs are created equal | PriusChat
    From what I've understood, most issues were fixed either replacing the bulb or ballast, being mechanically inclined, I hate taking the car to the shop for anything that I know I can do myself. If I can get it apart, I can get it back together, but its when you don't know what to do next is the issue.
  2. Jason Sayre
    Tomball, TX
    Well, I think I'm going to start with swapping the bulbs from side to side, then if it persists on drivers side, swap the ballasts and see what happens.
    I know there was a class action for this, but I'm way outside that extended warranty. Is there any value in trying to call toyota to get the issue resolved?
  3. Bill Gibson
    Bill Gibson Junior Member
    NORTH CAROLINA
  4. Bill Gibson
    NORTH CAROLINA
    Did you ever get this fixed? What was the fix? I have the same problem. I see on You Tube some are thinking it's the ballast. I see others are just switching out from HID to LED. That's the direction I'm probably going to go.
  5. Prius Dragster
    Prius Dragster Junior Member
    35
    Winchester, VA
    I had/have similar issues with my 2007 Prius. The driver's side headlight would come and go, always turning on right away so state safety inspection was not an issue. The headlight would turn off for no apparent reason and turning the headlight switch off and back on again would always bring it back, but there was no telling when it would decide to turn off again. I thought I had the problem narrowed down to driving over bumps and/or moisture in the air, but those theories were not 100% conclusive either.
    I followed the YouTube video in which the female tech shows how to remove the entire headlight assembly in minutes (I have small hands but there was no way I was going to loosen that twisting plastic seal on the rear of the headlight assembly with it still mounted in the car. I left blood evidence and currently have small scars to prove it.) When I initially addressed this issue in early January, I found that the HID bulb on the driver's side had two small cloudy spots inside the bulb, similar to when we used to find television tubes that had gone bad. (Showing my age here.) After additional research, I read that the ballasts in general are good for about 7 years before they are susceptible to crapping out as well. Armed with this Internet knowledge (It has to be true, right?) I ordered 2 new Philps Xenon HID bulbs and 2 new Denso D4R Xenon HID Headlight Ballast Control Modules. At the time, the ballasts were $31.99 each on ebay and took forever to come from China. I don't recall the price of the bulbs but there were an Amazon purchase. I purchased 2 bulbs because I also read that with HID bulbs, one may be brighter than the other upon installation if you do only one.
    Today was the day to attack the headlights in Winchester, VA. Beautiful sunny day in the 70's. In February. I'll take it. Each headlight was a slow and methodical process; the removal aspect was easy since I had done it once before. The ballasts were another issue. There is yet another YouTube video out there in which the guy shows a step-by-step (kind of) for replacing the ballasts. The hard part is interchanging some parts and wiring from the old ballast wire harness to the new one. The new ballasts show up with connectors that are not identical to those in the Prius. In addition, in order to get new wiring from the new ballast to the HID bulb connector, you need to pull apart brand new connectors and adapters and fish what is left of them through the headlight assembly due to a narrow, restrictive passage way when the headlight lense is still in place. Was not going to remove the lease. Was not going to pull apart a factory sealed and clamped connector in order to try the fish-the-wires-through method. I spliced wires. Don't tell anyone.
    When the new ballasts show up, at least the ones I bought, the cable from the ballast to the HID bulb connection is shorter than the factory one by about 2 inches. This was not appreciated and I am crafting a strongly worded letter to Mr. Denso to let him know my feelings on this matter. Anyway, I cut old wire from the old connection harness and spliced the pieces into the new harness. I had to remember to fish the new ballast wires through the narrow and restrictive headlight assembly space BEFORE I spliced the correct HID bulb connector back in place. Forgot to do this on headlight #2. Not the end of the world but definitely a forehead slapper before I undid and re-spliced everything in the correct order.
    As I finished each headlight, I reinstalled it and turned the headlights on to be sure my splicing efforts actually worked. I then bolted the headlight and front bumper back in place, again, addressing one side at a time.
    With my level of expertise (medium-to-low) coupled with my access to tools, places to work, and cleaning areas in the engine compartment before reinstalling the completed headlight assemblies, the whole process of addressing both headlights took about 41/2 hours. Both headlights work as of now, and both appear to have an equal brightness to them. I will let you know if I put too much $$ into a problem that still occurs in the future. Remember when you could buy a replacement headlight for under $20 and replace it under 15 minutes? It's a good thing Toyota nipped that problem in the bud.......
  6. Bill Gibson
    NORTH CAROLINA
  7. Bill Gibson
    NORTH CAROLINA
    So you stayed with HID and replaced the bulbs and the ballasts?
    I'm confused now. Some commented that replacing the HID bulbs with new HID bulbs and new ballasts didn't fix the flickering, on/off problem with the lights. One guy replaced the HID system and went to LED but has a problem with FM radio interference.
    My car is a 2007. The year is now 2018. Does anyone have a 2007 Prius that has had the headlight problem fixed and has been worry free for 3 or more years? If so, please let me know how it was fixed.
    Classic Car Guy likes this.
  8. Prius Dragster
    35
    Winchester, VA
    Not sure about that one. I am new to the Prius game and while I like some things about this car, other things have me scratching my head. I am HOPING that all new headlight parts that tend to wear out with age will do the trick. I read that the LED conversion is very expensive if you have someone else do the work. I don't believe I have the tools and know-how to accomplish that task on my own. As background, I purchased my used Prius back in December 2017. Since then, I have found half-assed repair attempts or at least a tight-wad mindset repairs that I discovered when addressing other issues. I also curse the "extended warranty" that expired basically when I bought the car. Regarding the headlights - At the very least, the driver's side headlight had been addressed before, and the passenger side may have received at least a bulb. How do I know? the back plastic casing of the headlight assembly on the driver's side was cracked in three places and the spin-off access cover had pieces of plastic missing that could easily allow moisture to get in (allegedly certain death for both ballast connector and the bulb.) I addressed the cracks in the black plastic rear cover the best I could and am hoping my efforts will do the trick. If not, a new headlight assembly? We will see. It's only money......
  9. nevergetany
    nevergetany Junior Member
    North Bend, Oregon
    My 2007 Prius was out of warranty too, but I got a letter from Toyota saying to take it into a dealership and they would replace the BULBS for no charge. If you still have the original bulbs that came with it put them back in and take it to the dealership and remind them about the recall on headlight bulbs. However, if you (or the prior owner) already did that THEN DO NOT go back to the original bulbs, as that issue has already been taken care of. IF that recall issue has not been taken care of yet, and you do not have the original bulbs, then you can still have the recall issue taken care of. I had mine taken care of, and it was fine for about 2 or 3 years, and then the problem started again. I found out that the bulb was not making good contact (on the drivers side). They removed the rust, and the drivers side has been good since. Now I have issues with the passenger side. The mechanic checked it out and there was no rust (the last time {several weeks ago} they did find corrosion and cleaned it up). But the problem still persists. I purchased 2 new HID lights. Drivers side has no issue; Passenger side still does. I think it is not making good contact. So maybe it is either loose connection; bad wiring; or the ballast; or a combination of any of these items. I saw the parts man who works for the dealership today (6/29/18); and he mentioned he thought there was an ballast update and for me to check in to find out about it. A mechanic told me, if I do buy a ballast, get 2 of them, and have both ballast replaced and keep the old ballast for backup in case a ballast goes out again.
  10. Classic Car Guy
    Classic Car Guy Active Member
    397
    114
    Northwest, USA
    Thread resurrection. We have or had the same car, same drivers side and same symptom. Any updates or input would be great?
  11. Therese Rudolph
    Therese Rudolph New Member
    23
    Oklahoma
    Three Touring
    I’m about to have my 2008 Touring changed from the HID to Halogen. I tried piggybacking in LED and one blew in under a year. In another thread there is a reference and post to a place in Texas that’s been doing a lot of these. Maybe Texas Hybrid Batteries? I’m actually in Oklahoma and the mechanic doing mine has a private shop. He will create a new harness for the Halogens and I bought new assemblies for LED which will be nice to have nice clean ones. From what I have read none of the trying to fix HIDs worked regardless of parts changed out. Unfortunately I haven’t found many follow up posts after the repairs nor the Halogen conversion. BUT this gives me hope after changing bulbs 6-8 times only to have them all blow out within a few months to just a year. Good luck to you. So many of us know your frustration very well. If you’re near OKC OK or Texas maybe you can get help.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,366
    6,037
    Columbia, SC
    Would you let us know what brand/model bulbs you were using and your purchase source?
  13. Therese Rudolph
    23
    Oklahoma
    Three Touring
    I’ve used different kinds of HID bulbs from Amazon and the Toyota dealer near me used D4R but my receipt doesn’t say the brand. Those are what I used as well and I think they were Sylvania. If you’d like the brands I can look them up.
    I have bought new headlights that the halogen bulb will fit and the mechanic is going to follow the guide from Texas Hybrid Batteries and create a new harness and I tried to contact them by phone but the one I reached said they are not doing headlight conversions. I really hope this works. It wouldn’t be the end of the world if it wasn’t such a pain to change the HIDs. But it is.
  14. Therese Rudolph
    23
    Oklahoma
    Three Touring
    Oh and yes I did use gloves when I changed them myself.
  15. Classic Car Guy
    397
    114
    Northwest, USA
    Let us know how did it came out. I am so devastated with my 07 Prius when it comes to the headlight phenomenon. 260 bucks for 1 ballast. I normally fix my car everything Toyota parts and its been so reliable. This headlight really got me by the nuts. A part of me is saying replacing the headlamp system to halogen and a part of me wants to buy the whole original Toyota HiD lights which is close to $750 on both sides. Its been a great here and there car but its just sad I cant drive it at night. :(
    is there a threading here that someone rebuilt their original ballast?
  16. mr_guy_mann
    mr_guy_mann Senior Member
    3,593
    1,655
    NJ-USA
    I started to have problems with the HIDs on my 06. Got new bulbs and ballasts from the Toyota dealer - no more problems.
  17. Therese Rudolph
    23
    Oklahoma
    Three Touring
    I totally understand your frustration. I’ve not had this done yet but have someone lined up to do it. Yeah I feel like it’s pretty much a total if I can’t even drive after dark. Especially now with daylight savings time. There’s a place I saw mentioned in Texas that says they are doing a lot of these conversions and I wanted to talk with them but can’t seem to get any contact info. I wish you the best. The guy I have lined up is going to make a new harness for the halogens They may not have the brightness of the HIDs but hey if they work that’s even better. I’m also replacing the whole headlight assembly and those were around $160 off Amazon. They needed to be replaced for the halogens from my limited understanding anyway. where are you located?
  18. Classic Car Guy
    397
    114
    Northwest, USA
    Thats quite true. If you'll go halogen, you might need to replace the whole headlamp assy. I live in Oregon.
  19. Therese Rudolph
    23
    Oklahoma
    Three Touring
    Hi. I just got it back after the headlight conversion and yes he installed new assemblies. Everything seems to be good except for the aim. They are up in the trees. I just created a thread about this issue to see if anyone knows a possible way to aim them.
  20. Classic Car Guy
    397
    114
    Northwest, USA
    Thanks for the follow up. Do you have a link and picture? Thanks,
    CCG
  21. Therese Rudolph
    23
    Oklahoma
    Three Touring
    Thanks. Hope to find a solution. Your ideas are helpful.
