2007 Prius - Stubborn TPMS Sensor after loads
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sdrocker, Jul 25, 2015.
  1. sdrocker
    sdrocker Member
    166
    San Diego
    Hi all,
    My 2007 Prius has a stubborn TPMS light. This started about a week and a half ago after I made a few trips from my house which sold to my new apartment. I had the car loaded up with stuff in each of the four trips and maybe had a lot of weight.
    I checked the tire pressure after the 3rd trip and it looked fine on all of them. I set them to 35 psi and made one more trip with heavy-ish stuff. I did not check the tire pressure after that last trip but I tried resetting the TPMS light.
    I press my foot on the brake pedal and hit the power button twice and then I held the Set button until I saw the TPMS pattern change to three blinks and then it stops. It then continues blinking for the 1 minute duration and stays solid. I tried this a couple of times and waited 3 minutes or so after doing it to see if it made any difference.
    Am I likely not trying to reset correctly? I also have techstream on a cd and the tool and a laptop but am not sure if I should set that up and then try to debug using that tool?
    Could a heavy load damage a TPMS sensor? Maybe I need to check pressure again after that last load but I don't think it would have changed much based on the 3 prior loads after which I had checked the pressure.
    The only other thing I can think of is the tires were rotated by a tire shop, however the light didn't come on until I started doing the trips with stuff to my new residence.
    Thanks.
    49,068
    set her to 42/40 and see what happens.
  3. JC91006
    16,470
    8,384
    sensors could go bad, just replace with one on ebay
  4. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks would that have been caused by the heavier loads I was transporting? This happened right when I was moving stuff to my new place.
  5. JC91006
    16,470
    8,384
    You should check the pressure again, you may have a leak on a tire and not really see/notice it.
    Sensors go bad with or without load. It's an electronic part so it could fail regardless of load.
  6. bisco
    49,068
    also a check of your pressure gauge.
  7. sdrocker
    sdrocker Member
    166
    San Diego
    Which pressure gauge?
    I will check the current pressure and then go to a gas station and try 42/40 as you had suggested and then do the light reset steps with the set key button.
  8. bisco
    49,068
    the pressure gauge you are using to test your tyre pressure.
  9. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    A 2007 is getting to the age where the TPMS batteries start to die. I've replaced one in my 2006 because of failure, and 2 more when I changed the tires. One left that is still hanging on...
    #9 RobH, Jul 25, 2015
  10. bisco
    49,068
    i read that they were only good for about 5 years, but they don't seem to be much of an issue yet. will be interesting if they're the next big thing. personally, i would keep an eye on my pressure and ignore it.
  11. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks, I agree with everything everyone is saying. I just find it weird it happened right in the middle of driving with one of the loads I was taking to my new residence. This makes me think it had something to do with the weight I had.
    I will try 42/40 psi when I have time and then report back.
  12. sdrocker
    sdrocker Member
    166
    San Diego
    Ok so I finally filled the fronts to 40psi and the rears to 38psi. I tried resetting using the Set key and even let the car sit for 20 minutes with the ignition on. The light still blinks for 60 seconds and then goes solid.
    The tires look fine. The first time I saw the light come on was while I was driving with a reasonable load of stuff in the back. This is why I kept thinking it must have perhaps made the tires low. It seems like such a coincidence if it were a battery or the sensors went bad. A week and a half before that I had the tires rotated but the light did not come on until I was driving with that load in the back.
    Hmmm.....
