2008 Prius Gen2 Issues
Discussion in 'Gen 2 Prius Technical Discussion' started by NortTexSalv04Prius, Oct 12, 2014.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    I have a 2008 Prius and have these issues.
    Engine ICE runs high rpm
    From cold start thru warm up cycle engine rpm runs high and ICE temps goes to 190 fwt on SG2
  2. JC91006
    16,470
    8,383
    Are there any warning lights? You can try cleaning the throttle body and maf sensor. That might help your problem.
  3. AzWxGuy
    AzWxGuy Weather Guy
    970
    491
    Tucson, AZ
    2021 Prius
    Agree, it's probably a gummed up, sticky throttle plate. Can't say I've ever had this problem myself. Unknown if that coolant temperature rise rate and value are significant in this problem. What is "fwt" ? Some other things to check, integrity of O-ring seal on MAF sensor (can be checked when removed for cleaning with MAF cleaner), throttle body to air cleaner junction clamp, binding in the throttle plate shaft to throttle position sensor (from ingress of dissolved solids). From your post, it sounds like this happens all the time. I have noticed a short period of higher RPM in my car when made ready just after refueling. Higher RPM and extended ICE runtime might also be a symptom of a weak 12V auxiliary battery.
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    I think fwt is what Scangauge 2 shows when engine temperature is showed in degrees of Fahrenheit. 190F is 88c which is normal temperature for engine.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    An acronym of the OBDII reader used.
    f = farenheight
    t = temperature
    w ?. perhaps water
