2008 Prius Red Exclamation Mark, (!), VSC, and Check Engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lizardofoz, Sep 2, 2015.
  1. Lizardofoz
    Lizardofoz New Member
    Louisiana
    I had just picked my kid up from school, as I turn out of the parking lot my A/C stops blowing cool air, I check the A/C screen and it still says it's set on High with temp at 68. However, it is blowing very low woth warm air. Seconds later the dash lights up with numerous warning lights. I'm on the highway and I'm able to gather speed, but each time I do I hear the engine reving like crazy. We only live a few miles from the school so I am able to make it home. Once home, I turn off the car and turn it back on. The only warning lights displayed now are the red triangle and the yellow check engine light. I turn the car off, pop the hood, I check the belt and it was fine. I checked the oil and it seemed fine. I check the coolant overflow and it was empty.
    After reading many of similar complaints I'm really worried that the hybrid battery is going bad and needs replacing. This would be catastrophic for my family. We couldn't even afford a $50 fix, let alone a multiple hundred or thousand dollar one. Is there any chance in hell that it is something smaller? We've had so many things go wrong within the past month, I'm not sure we can take anymore.
    We bought the car used in 2009, it has about 103k miles.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    yes your battery is gone, the failing AC is the first sign as it uses the most power.
    if you ran the car without coolant you did a lot of damage.
    if you keep driving it the way it is you will destroy the rest of the car.
    sell it as is and buy something else, you don't have any options if you cant afford the repairs.
    its just a car, dump it and move on
    post it on craigs list for $2000 and see if you get any offers
    #2 Beachbummm, Sep 2, 2015
  3. Patrick Wong
    18,199
    6,464
    Yes, there is a good chance that your car has two relatively small problems. At the moment it is unclear that the high voltage traction battery is at fault.
    Unless you are able to walk or bicycle everywhere you need to go, you must allocate some money to service your car now.
    1. Buy a gallon of Toyota Super Long Life Coolant and use that to fill the "coolant overflow" container. I assume you are referring to the engine coolant overflow reservoir. Also, remove the large black plastic cover over the radiator, and fill the radiator.
    2. Make the Prius READY. Look at the inverter coolant reservoir. If you do not see fluid turbulence then the inverter coolant pump needs to be replaced. I have posted on how to do that, you can DIY for <$100.
    3. If #2 is OK, rev up the engine while the car is sitting on your driveway, gear selector in P. Turn on the cabin heater, temp MAX HEAT, fan speed MAX. Make sure the cabin heater is working and you do not hear air bubbling in the heater core. If you hear air, then rev the engine around 10 minutes or until the air bubbling goes away. Then turn off the car. Wait until the engine cools down, then remove the radiator cap and replenish coolant in the radiator as well as in the overflow container.
    4. Repeat #3 until the coolant level remains steady.
    5. Look at the engine coolant pump pulley. If you see a pinkish stain on the inside of the pulley, that is where the engine coolant is leaking. You will need to replace the coolant pump (which I have posted on how to do) and this also will cost you less than $100 if you DIY. However you can defer this replacement for a while as long as you frequently monitor the engine coolant level and keep the radiator full.
    6. Try the air conditioner compressor to see if the AC will produce cold air. You should not have to set the temp at 68 unless you are using your car as a refrigerator.
    Easy money likes this.
  4. JC91006
    16,470
    8,383
    You might be covered under warranty for the hv battery
  5. Lizardofoz
    Louisiana
    Also, I forgot to mention that I tried to use the cruise control and it wouldn't work, the word cruise didn't even show on the dash.
    And, I know this is probably terrible, but I never got any of the recall noticed fixed. I called at the time and there was a 2 month wait, and then as time passed & a hectic schedule I just forgot about them. Could any of those be responsible?
  6. Lizardofoz
    Louisiana
    I still owe money on the car so, this is not an option. Also, had an oil change in July where they should have topped off the coolant. So, if it's low on coolant it hasn't been long.
  7. Beachbummm
    1,160
    392
    are you talking about the coolant in the engine or the invertor (the invertor is in the center of the engine compartment if that's empty you cooked the invertor and that in turn killed the battery) when it was checked last is meaningless, if it leaked out and ran hot for about 20 mins its cooked.
    if you owe money on it let them repo it..if it needs a battery and invertor the car is worthless..you are going to have to get it towed to the dealer (Id join AAA today) and spend about $100 to see if its worth fixing...
    either way Id start looking for a $1000 beater and dump this car, the damage has been done.
  8. JC91006
    16,470
    8,383
    The car has 103k miles, what's this talk about beater? Almost any hybrid repair would probably be done on a goodwill warranty, if it's not covered by a carb warranty. There should be no cost
  9. Beachbummm
    1,160
    392
    what makes you think Toyota will give them a free battery?
    just because one in twenty get it does not mean they will.
    even at 50% off its still $1500 out of pocket with no idea why the battery failed so early.
    bad invertor?
    bad charging system ?
    other issues..
    who knows.
  10. JC91006
    16,470
    8,383
    I recommend you taking to the dealer to see what's wrong with it, then you can have an idea what you are facing.
    If it's the battery or inverter, ask for a goodwill warranty and chances are they'll cover the repair at no charge. What state are you in?
  11. Lizardofoz
    Louisiana
    No, I'm talking about the overflow coolant tank next to the radiator. I don't think you are giving me good advice. This is first problem I've had with this car. I've taken good care of it. I won't be ditching it.
  12. Lizardofoz
    Louisiana
    I'm in Louisiana. I called the dealership, but the soonest appointment is on the 15th. One person I talked to seemed to think it might be related to one of the recall issues.
  13. bisco
    48,996
    is the fluid in the inverter reservoir swirling?
  14. JC91006
    16,470
    8,383
    There is a recall on the inverter pump
  15. docbonezz
    docbonezz New Member
    Louisiana
    I live in north Louisiana. I recently had a similar problem with my Prius and it was the main battery!!!!!!!!!! Dealer wanted $4000.00 to replace the battery. NO GOODWILL HERE!!!!!! I started reading up on re-conditioned batteries and what they did to re-condition them. I am pretty "handy" so I pulled the main battery (about an hour and a half), checked each cell. I found I had 3 bad cells. Ordered 3 off of eBay. After I put the battery back together I had to cycle each cell (discharge and charge each cell 3 times) and this took a long time. After I put the battery all back together I put it back in the car and haven't had any more problems with the car other than the A/C. But all the lights have gone off on the dash and the car is running great.
  16. docbonezz
    Louisiana
    depending on where you are in Louisiana I may be able to help you with this.
  17. Rebecca Leyva
    Rebecca Leyva New Member
    Colorado
    How do you know which cells are bad? Are there any special tools needed to determine this? How did you charge the cells?
  18. bisco
    48,996
    you need a mini vci, and an old compatible windows laptop.
  19. Beachbummm
    1,160
    392
    just watch the videos on youtube on rebuilding prius batteries
  20. danthemechanic
    danthemechanic New Member
    wisconsin
    Four Touring
    check the fuses under the hood. I had a similar issue with my 2011 and there was a blown 10 amp fuse in the panel under the hood. I forget what the fuse is for but it fixed the problem. can't hurt to check.
