2008 Prius started remotely
Discussion in 'Gen 2 Prius Technical Discussion' started by yort, Jul 14, 2008.
  1. yort
    yort New Member
    Ohio
    My 2008 Prius started remotely with my smart remote key in my pocket. I was about 10' from the car. How is this possible? Has anyone else had this experience?
  2. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Started? As in the car was ready to roll?
    Or the interior lights came on and the doors unlocked when you touched the handle? <:0)
    Sorry, just trying to get the obvious out of the way.
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Unless it was always on and the ICE decided to recharge the batteries at that point.
  4. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    i did that once. scaryed the :D out of me...
  5. Stefx
    Stefx Member
    336
    If you walk by your car with the smart key in your pocket, the dome light turns on (probably assumes you're going to enter the car...)
    First time it happened I thought I had forgotten to turn the light off. Took me a while to realize the detection function.
  6. yort
    yort New Member
    Ohio
    Embarrassed to say that I think I forgot to press the power button since I was interrupted as stopping the car. The car was in stealth mode, then finally needed to charge the HV battery.
  7. Stefx
    Stefx Member
    336
    Nothing to be embarassed about.
    When I took delivery, I spent 10mins trying to open the power windows, not knowing you had to press power twice if you didn't press the brake pedal while turning it on.
