2008 Prius Starting and Computer Reset Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Armacham, Jun 12, 2014.
  1. Armacham
    Armacham New Member
    Tucson, Arizona
    I have a 2008 Prius with about 55,000 miles. Today after work I got in and went through the normal starting procedure, but nothing happened. I stepped out of the car, took a quick lap around the car to check for anything noticeable, and locked and unlocked the car with the key-fob. I sat back down and it started up just like usual except that the trip odometers and clock had all been reset, and my radio presets were gone. I recently replaced both the key-fob battery as well as the 12V battery within the last couple of months. Any ideas what might have caused this?
  2. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    It sounds like power was lost to your car. Have you checked the voltage on your 12V battery? I would recommend doing so if you have not done it recently. Also check all the connections to the 12V battery & look for corrosion. If the voltage is OK and after tightening connections and cleaning the terminals as necessary, wait & see if the issue reappears.
  3. Armacham
    Armacham New Member
    Tucson, Arizona
    Just checked the voltage and the diag screen is showing 11v, so it seems like the battery is defective. A $150 battery should last more than 7 months. I hope that obtaining a warranty replacement is not a pain in the nice person.
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    Why don't you try recharging the 12V battery?
  5. Armacham
    Armacham New Member
    Tucson, Arizona
    I probably will do that while waiting to see about a replacement, but a 7 month old battery that goes dead for no reason is defective and I would rather not risk getting stranded someplace with a dead battery if it fails again.
  6. usnavystgc
    3,159
    988
    Tucson, AZ
    That's not necessarily true; maybe you have a bad connection and it wasn't charging, maybe your inverter charging circuit is bad? Maybe a map light was left on. There could be a myriad of possibilities.
