1. Offline
    SCJoe New Member
    Start a Conversation
    Aug 15, 2009
    62
    Sioux City, IA
    Your Vehicle Year:
    Anyone know if you can use the 2010 Prius bluetooth steering wheel controls to completely control an Android phone? If so, would you mind saying which model phones it works with?
    I've read that most Android phones (all except the Devour?) do not support bluetooth voice dialing, meaning you have to press something on the phone to initiate the call when using bluetooth. Thinking of picking up an Android phone, but probably won't if I have to interact with it in the car.
  2. Offline
    raholco Ailurophile
    May 7, 2009
    50
    Your Vehicle Year:
    All current Android that I am aware of do not support voice dialing over Bluetooth.
    However, you can place calls by using "Dial By name" or "dial by number". In the case of Dial By name, you do have to record voice tags.
  3. Offline
    SCJoe New Member
    Aug 15, 2009
    62
    Sioux City, IA
    Your Vehicle Year:
    Yeah, that's what I thought. Supposedly the Devour (with Motoblur interface) does, but that's not a phone I'm considering.
    You mean using the car "dial by" functions, or phone functions?
    Basically, I'm wondering if it's possible to make and receive calls without touching the phone at all (after initial setup, of course), but using the steering wheel controls.
  4. Offline
    shawnb2 Member
    Mar 21, 2009
    481
    89
    Thousand Oaks, CA
    Your Vehicle Year:
    Yes you will. Once the phonebook is loaded in to the headunit you will be able to do the dial by name or number prompt from the steering wheel controls. I'm currently using the Droid and used to use an iPhone. They both work great. Hope this helps.
    1 people like this.
  5. Offline
    SCJoe New Member
    Aug 15, 2009
    62
    Sioux City, IA
    Your Vehicle Year:
    Good news. Thanks, shawn.
  6. Offline
    cutaway Junior Member
    Feb 21, 2010
    WA
    Your Vehicle Year:
    Has anyone who has gotten Android 2.2 OS been able to test voice dialing with the Prius?
  7. Offline
    chuckc192000 Junior Member
    Jul 23, 2010
    44
    Your Vehicle Year:
    I "Dial By Name" all the time and I never recorded any voice tags. I have a Palm Centro phone and it has NO built-in voice dialing capability at all. The voice dialing is all handled by the Prius.
  8. Offline
    chrisj428 Active Member
    Sep 24, 2009
    598
    114
    Vernon Hills, IL
    Your Vehicle Year:
    I use "Dial by Name" and "Dial by Number" all the time with my EVO. I, too, do not have voice tags recorded.
  9. Offline
    gcarey3 New Member
    May 31, 2010
    Lansdale, PA
    Your Vehicle Year:
    I have a Droid 2 running 2.2.20 and have not been able to get native Droid voice dialing working with the Prius. I cannot trigger the voice commands on the phone using hardware in the car or use the car microphone to tell the Droid what to do.
    As others have mentioned, it will dial once you pull the address book from the phone into the Prius.
    What you may have already found is that audio out of the Droid works fine once you pair it up. That means you can select BT audio and all the media audio will come through the car speakers. So I can use the Droid music player and even the navigation functions which auto mute/unmute the audio.
    It seems to me that this is more of a limitation in the Prius than the Droid. I just updated my Jawbone ICON bluetooth earpiece software and it works fine with A2DP and voice commands.
    It sure would be great if the Prius could initiate the Droid voice command and use the built in car microphone for input to the Droid.
Share This Page
