2010 Corolla Xrs wheels on 2010 Prius, will fit?
Discussion in 'Gen 2 Prius Main Forum' started by kewrad, Jun 9, 2011.
  1. kewrad
    kewrad New Member
    Maryland
    Will the 2010 Corolla Xrs 17" (Five spokes) wheels fit on 2010 Prius II ?
    According to the specs:
    2010 Toyota
    Prius I, II, III, IV
    Bolt Pattern: 5x100
    Center Bore: 54.1
    Hardware:12x1.50 Lug
    Offset: 35-48mm
    2010 Toyota
    Corolla
    Bolt Pattern: 5x100
    Center Bore: 54.1
    Offset: 38-50mm
    The only difference I see is the offset but not by much. What u think?
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    run google search.
    there is a guy who used a set of Corolla rims for winter tires in Cleveland(?) Chicago(?)
    I think it came up in TPS sensor thread
  3. Mendel Leisk
    38,313
    FWIW, I'm using 15" Corolla steel rims with snows on our Touring model, same 17" rims as the US V model.
  4. kewrad
    kewrad New Member
    Maryland
    This is the info I have for Corolla XRS 17":
    15-inch Wheels: 15.0x6.0" +33mm Offset, 5x100mm Bolt Pattern
    16-inch Wheels: 16.0x6.5" +39mm Offset, 5x100mm Bolt Pattern
    17-inch Wheels: 17.0x7.0" +39mm Offset, 5x100mm Bolt Pattern
    For the 2010 Prius:
    17-inch Wheels: 17.0x7.0" +50mm Offset, 5x100mm Bolt Pattern
    The offset is very different, I wonder if this could cause fitment problems. ???
