2010 prius 12v battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Mar 3, 2013.
  1. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    I've heard about the Exide Edge AGM too, but didn't find it available locally. Due to my state's core charge policy to encourage returning batteries for recycling I thought I'd rather just swap mine for a new one at a local store than order online. The store brand batteries have lower ratings (Amp-Hours, warranty, etc.). I don't know how close they are to the quality of the Exide Edge or other name brands. I wasn't aware of Toyota's longer warranty, but the short life of my original battery left me unimpressed (which may be due to how easily it's damaged by leaving a dome light on). I've now replaced my Toyota battery with an Optima, which claims to tolerate deep discharge.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    The Optima claims a lot of things........but seems to be having trouble delivering recently.
    Do a search here for Optima for some unsettling stories.
  3. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    On March 1, 2014; I ordered the Optima 8171-767 yellow-top deep cycle battery from Streetsideauto.com for $ 147.05; and with free shipping.:cool: I think I got a pretty good deal.:)
    I hope this battery fits OK !!
  4. srivenkat
    srivenkat Active Member
    596
    93
    IL
    For one thing, I see the Toyota Truestart Prius battery (apparently still made in Japan by GS Yuasa) now shows 45 AH while the Optima is 38 AH. I wonder if GS Yuasa has learned from the failures of the OEM 12V (or not, only time will tell). It comes with 2-year free replacement followed by 5 years prorated (total 7 years warranty). Exide Edge also has 45 AH capacity and a 4 year warranty. The O'Reilly Super Start is 46 AH IIRC, not sure about warranty... All in all, I am not too enthused by the Optima currently primarily because of the low capacity....
    ADDITION: I believe the Exide warranty is 4-year free replacement.
    ADDITION: Per O'reilly web-site SuperStart has a 3-year "limited" warranty.
  5. srivenkat
    596
    93
    IL
    So, this points to an issue with the capacity and deep-cyclability of the specific 12V that Toyota shipped the car with. Non-OEM batteries such as the Optima seem to be faring much better due to their higher capacity and the ability to withstand more than a couple of deep cycles. Some people even go as far as saying these batteries do really have an easy time in the Prius application.
  6. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Looks like this thread is a bit on the old side... I have a 2010 Prius, with the original battery still. It's now 7 years old, and is finally ready for replacement, since it's showing 11.9v after sitting for a day (roughly 40% capacity). I'm surprised to read that people have had so much trouble with the original batteries supplied by Toyota. I totally drained my battery shortly after purchasing the car, because I left the map light on overnight. But a jump got me going. I have not treated the 12v battery gently over the last 7 years, because I have a 1,000w inverter connected directly to it, off of which I've cooked rice (800w rice cooker, 20-30 minutes), run a small microwave (rated at 600w, but it actually draws close to 900w), and during a power outage, supplied power to our basement freezer, phone system, and internet for 3.5 hours. Admittedly, the Prius gas motor starts up periodically to keep the battery charged up, these things are not running off the 12v battery by itself.
    The Prius battery is used for the on-board computer, to unlock doors, open windows, run the startup stuff like pumps, but does not crank the starter motor like in most cars. So the old rule of batteries "only last 4-5 years," or a map of climate doesn't really apply to the Prius 12v battery - it applies to cars that use the 12v battery to start the car (cranking the starter motor in normal cars takes a huge load). So I expect the small Prius 12v battery to last a long time, and I think 7 years is a good long time.
    Yes, the Toyota battery costs a bit more, but after reading about third party batteries here and other places, it seems quality control may not be very good for third party batteries - some seem to last a long time, others (even the same brand) seem to die a young death. So I plan to replace my 7 year old 12v battery with another Toyota 12v battery. If it fails, it's a short trip to the dealership.
    Tande, Merkey and Mendel Leisk like this.
  7. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    The sticker that says "Never add water" and "Do not open" meant nothing to you? These are not normal batteries, they are sealed for safety, especially so that hydrogen gas doesn't escape into your car and blow up. (OK, probably not likely, but there's a reason there's a tube on the battery to allow off-gassing to escape to the outside. Break the battery seal, and you defeat the purpose of that safety feature.)
    Merkey likes this.
  8. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Truth.
    Just get a new one.
    Merkey likes this.
  9. Chasir
    Chasir New Member
    denver CO
    Just thought I would put in my experience, Ive owned my 2007 model since late 07 and am just now seeing signs of low 12V battery, so nearly 10 years 135k miles of use and even had the main hybrid battery replaced, the 12V battery did rather well. I did jump start it about a year ago but ran fine until now. May just need another jump start but I think its time to replace. I may go with the original from Toyota.
    cwerdna and bisco like this.
  10. bisco
    51,976
    welcome and well done! my best is only 8 years.:p
  11. Elerikk
    Elerikk New Member
    Gilmer Texas
    Hello all I wanted to post here that i found an ac delco battery for my 2010 prius that is an exact replacement battery for 127.41 on amazon
    here is the part number:
    ACDelco ACDB24R Advantage AGM Automotive BCI Group 51 Battery
    it arrived in 2 days and has been running with no issues... ill keep you posted
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    amazon.com/ACDelco-ACDB24R-Advantage-Automotive-Battery/dp/B010GKJ8F6
    The reviews say it DOES have a vent hole, as it should.
  13. Currahee
    Currahee Member
    103
    34
    CT
  14. Mendel Leisk
    41,495
  15. Rolls Canardly
    Rolls Canardly New Member
    yes
    2003 Prius
    Do a Google search on the Optima for this vehicle.
    I did - and found one for $148.00 on the Top right - hand comparisons.
  16. bisco
    51,976
    it might be cheaper to buy a gen 4. it comes with a new battery, and you get a bunch of other neat stuff.
    Raytheeagle likes this.
  17. Mendel Leisk
    41,495
    The gen 4 battery looks to be more conventional, in the engine bay, regular size posts. Doesn't look to be AGM, and has uncovered/accesible cell caps, larger, and accordingly more resilient?
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    (The OP does not have a Gen 4) The Gen 4 battery does not share space with the occupants of the car, so the safety requirements are more lax than Gen 2 and 3.
  19. Mendel Leisk
    41,495
    Yeah bisco wound me up.
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is one reason he is on my ignore list, but mostly his deliberately bad advice.
