2010 Prius Knocking (Raptor Sound)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DG Bear, Sep 7, 2015.
  1. Kortenbach
    Kortenbach Junior Member
    Hi dg bear,
    Since you are saying that the misfires only happen in cilinder #1 I really suspect the EGR because cilinder #1 is closest to the EGR. Too much exhaust gas will cause misfires. So how to test if it has something to do with the EGR or not ?
    I think you shlould block the EGR by putting a completely blocked "gasket" in the flange so you can be sure that no exhaust gases can spoil the ignition in cilinder #1. If the misfires continue then i'm wrong :(...
    Next thing to check would be if the sparkplug is really sparking. To check that I would use a pickup-coil on the sparkplug cable or something symilar. If you are sure the sparkplug is sparking, then you should check if the is sufficient compression in cyl #1 I would imagine that compression is really important at low rpm. Losing some compression is not imaginary. It did do quite a few miles after all...
    If that does'nt solve your problem i'm out of guesses for now...
    Good luck and... Please keep me informed of your progress !
  2. DG Bear
    DG Bear Junior Member
    85
    24
    plano, tx
    Thank you very much for input Kortenbach
    * Actually cylinder #1 is the farthest from the EGR.
    The layout is left to right: 1, 2, 3, 4 <- EGR Pipe​
    The problem is not limited to low RPMs it also happens at higher RPM's:
    Originally the problem was intermittent. I only had the problem while driving under certain loads…. normally at low speeds with heavy loads (going up hill with low to medium acceleration). Also occurring for short times when letting off the accelerator. Never occurring at moderate to heavy acceleration. Never at idle.​
    The problem has not progressed to a point where it happens every time when the HV charging kicks in when the car is stationary. This is why I am performing all the benchmarks in the maintenance mode at idle speeds. This environment simplifies the issue and remove a lot of the other variables. The problem it replicated like clock work when the HV charging occurs.​
    I am suspicious of the EGR valve and I have the blocking plate on my to-do list… lately I have been wondering if the valve is not closing properly and causing the problem when manifold pressure is increased (hence the HV charging). Perhaps the hissing sound is also caused by the exhaust gasses passing through this leakage.
    I don’t understand why it’s only causing the misfires on cylinder #1... but I still think it may be a plausible case for the problem.
  3. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    You're correct that the added load on the engine from charging increases intake manifold pressure, but that's absolute pressure, meaning intake vacuum decreases, so EGR flow should decrease if the EGR valve is simply failing to close. Without that load and with a leaking EGR valve, you'd not only have more EGR flow, but also reduced air flow, so proportionately much worse contamination. Of course, that doesn't preclude the possibility that the valve is working properly but partial clogging of EGR passages in the manifold is disproportionately affecting one cylinder. Results of your blocking test will be interesting. Good luck!
  4. mindfk
    mindfk Junior Member
    16
    United States
    The LTFT is the long fuel trim; it shows the actual condition of the engine
    STFT is short trim and once LTFT goes to for example 16, STFT takes that 16 as a baseline and then does its sine wave. So STFT can do +- 20 (or whatever is the maximum) until a steady baseline is reached to alleviate for perfect fuel/air ratio of 14.6:1; the baseline is sourced from LTFT so STFT is not typically used to diagnose and is used more to find a direction of where things go meaning that if you have LTFT=16 and suddenly you fix something, without ECU reset, the STFT willl drop to -5 to -20 to alleviate for too much fuel vs gas. You will have to re-read this few times I guess, it is a simple concept, do some google-fu.
    This is interesting, you see, your original increase of LTFT indicated that there is not enough fuel delivered to the air/fuel mix. So the computer started adding % of fuel until it reached 18-23% over its programmed baseline. Replacing injectors and a following fix concludes that the injectors were clogged. Makes you wonder if it would not be a bad idea to replace the fuel filter?
    High LTFT can be caused by a multitude of items: air leak, bad fuel pump not generating enough pressure, clogged fuel filter, clogged injectors.
    Not yet, try this: replace spark plug coil of cylinder 1 with any other cylinder and see if the "new" coil at cylinder 1 is misfiring, maybe you simply have a bad coil, at that mileage it should be no surprise.
    #24 mindfk, Oct 19, 2015
  5. Juba79
    Juba79 Junior Member
    Hello again, my car still did not suffer any of these symptoms, just 70,000 km, but here in Spain, who has these symptoms, dedicated to Taxi cab cars, ended up being head gasket, some have changed head gasket, electric ice pump, thermostat, and clean front radiators, for caution , to about 250.00 km, for others it was too late.
    Also the possibility of a defect source is studied, as is often broken by the cylinder No. 1, in almost all cases.
  6. Mendel Leisk
    41,234
    Are you saying the head gasket is often broken by cylinder no. 1? Also, which cyclinder do you refer to as no. 1? As you stand at the front of car facing the engine, is cylinder no. 1 at left side?
    Found this regarding cylinder order on gen 2:
    Identify cylinder order | PriusChat
  7. Juba79
    Hello now, I post from my tablet, in my Pc, with Firefox don't have option to upload images, I tried again tonight or tomorrow.
    Cylinder N-1 is the more near to the egr valve, N-4 is the near to the timing chain.
  8. Besik Mukhiashvili
    Besik Mukhiashvili Junior Member
    Tbilisi, Georgia
    Hello DG Bear,
    What about PCV valve ? If this valve stuck in open position it can provide additional (unmeasured by MAF) air and cause misfire.
  9. Juba79
    Hello pics of blow head gasket, and cleaning inside radiators
    culata1.jpg culata1.jpg culata 2.jpg limpieza radiadores1.jpg limpieza radiadores 2.jpg limpieza radiadores3.jpg
  10. Mendel Leisk
    41,234
    The radiator condition is horrible! Perhaps related?
    m.wynn likes this.
  11. DG Bear
    85
    24
    plano, tx
    Thanks again for our valuable input...
    I tried swapping the coil earlier, no change, then I tried 3 new coils, then I swapped all 4 coils and spark plugs with Prius #2... no change.
    Thanks for the feedback... I checked the PCV valve when I rechecked the intake manifold a few weeks ago. It seemed ok to me... Didn't look clogged, only passed air one way when I manually blew into it...
    Wow... thanks for posting.
    From the picture it looks like the head gasket it missing between the #3 and #4 cylinders (the two on the right hand side - looking toward the rear of the car)... it that correct?
    Was the source of the problem excessive temperature?
    Did the car overheat from the clogged radiator?
    mindfk - Thank you very much for you valuable feedback... Really appreciate the help on this one!
    LTFT - Excellent question...Originally it was quite high... 18 while idling, 23 under load.
    The STFT generally has level around 0 so it seems to be happy with this adjustment.
    Once I discovered this I thought for sure it was an intake leak... That would explain the hissing and the noise with misfiring. However I could not an intake leak using the normal techniques (propane/spraying carb cleaner near the hoses and intake manifold, etc.).
    I moved on to the injectors... once I swapped them with the other Prius, the LTFT was back to a normal range (~4.5).
    The interesting thing is... The high LTFT did not generate a check engine code.
    I would have though this was excessive but apparently it still stays inside the acceptable margin.
    EGR Plate - Good Suggestion.
    I've thought about making a EGR blocking plate from a piece of sheet metal (similar to your picture) but just never took the time.
    I kind of stopped worrying about the EGR valve when the problem starting happening at idle speeds (1100rpms in the maintenance mode).
    I assumed the EGR would always be closed at this speed. Techstream shows the Target EGR Position and the EGR Step Position at 0% before and during the problem condition.
    I also wonder this could be a problem where it is not closing properly and allowing gasses to flow when it's suppose to be closed..
    .It does create a similar effect if I open the EGR valve in the test mode... but I believe this is normal.
    Do you think I should pursue the blocking plate?
    As you might expect... I can also create a similar condition if I vary the VVT control valve. I have suspicions that this could be the problem area but it had not affect when I swapped it out with the other car.
    I can't help but wonder if there is air or oil passage that is partially blocked that is causing the problem (similar to carbon in the intake manifold)???
    On the stethoscope... we tried that. I had three different mechanics try to find this sound… we all had no luck. One of them used a stethoscope very similar to the one in your post. Right now the hissing sound is simply not present.
    Thanks for chiming in Juba79
    I'm not sure I totally understand you post...
    I think you are saying that you have or had a Prius with similar symptoms and the car was fixed by doing a head job or replacing the engine?
    Did you mean that?
    A. A bad head gasket was the cause and resolution to the problem?
    or
    B. The problem was present and it continued until the engine failed with a blown head gasket?
    Can you expand on the problem(s) that you discovered?
    Can you tell me more about the location of the leak?
    What tests were done to location the problem?
    Did you get water in the block or see exhaust leaking from the head, etc.
    Is there anything unique about a Taxi application that would cause this failure?
    Again thanks for your valuable input in the problem.
    #31 DG Bear, Oct 22, 2015
  12. Juba79
    Hello, my prius is relativy new only 76.000 km, here in spain, in a a group of facebook, many menber post this pictures and one video, with similar sound of raptor, and finally the problem is head gasket blow.
    I suggest remove the 4 spark, and use a mini camera, and look inside cylynder .
    DG Bear likes this.
  13. mindfk
    16
    United States
    DG Bear, did you test the compression on the cylinders like Kortenbach suggested? preferably with a leak down test (you test the compression and then add some oil into the cylinder and test again to see if there is any increase, it there is you have worn out rings, if it is not then valves/head work) ? Maybe something happened between April and now... :/
    Also, if you want to experiment, you could do a chinese water torture along with the italian tuneup: Chinese Water Torture (a SeaFoam recipe) - Turbobricks Forums; catch is, with Prius, you would have to be driving at highway speeds in "B" to have 3k rpms....
  14. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    ?? Reaching 3 KRPM is all too easy in "D" on any decent uphill in a Prius, without breaking a speed limit.
  15. DG Bear
    85
    24
    plano, tx
    Update 10-22-15 The #1 Cylinder Misfires Counts shown in Techstream and reported 10-16-15 have now disappeared.
    10-15-15 Review:
    The tests were performed when the car was in the maintenance mode (where it continues to run at about 1100 rpm).
    The car will start/stop the knocking sound in concert with the start/stopping of the HV battery charge state. Each and every time the charging mode starts and stops the knocking starts and stops. The engine load increases from about 30 to 60% when the charging is in play.
    About two weeks ago the car was showing constant "misfires counts" on cylinder #1 during this condition (as view in Techstream).
    The misfire counts where only in cylinder #1 and only during the HV Charging / Knocking condition. The counts would increment from 0 to 99, back to 0 then back up to 99 in this consistent pattern. (See the Techstream database file and screen shots in post #20).
    Once the HV charging stopped the misfire counts stopped and magically reset to 0. The check engine light never came active... (nor did any pending check engine codes).​
    * On Monday 10-19-15 I removed the EGR pipe and EGR valve.
    It's hard to say for sure but it's possible the EGR valve was slightly open.
    I say this because once I took it apart it seemed like the mechanism was not fully closed. However that may be just the way the stepper motor rests when it's not under EGR control.
    Cleaning the valve and the EGR pipe did not fix the problem. The valve definitely had soot in and around the seating area but it was not terribly gummy like the intake manifold. In general both the valve and pipe were dirty but not overwhelming.
    It's been about two weeks since I worked on it. During the 10-3-15 set of tests, the hissing was not present...
    During the 10-19-15 set of test, thee hissing is somewhat back and the consistent cylinder #1 counts are no longer present.
    There are some misfire counts but not just on cylinder 1 and not as many as measured with Techstream a few weeks back when those were performed.
    Why are these symptoms changing ???
    10-22-15, I ran addition tests... This time focusing on the EGR valve. I wanted to confirm it was staying closed during the maintenance test.
    I removed the EGR stepper motor control so I could manually open and close the valve. Judging from the temperature of the EGR to intake manifold pipe it appears that the valve is closing properly as the pipe was cold when closed and warmer when open.
    Performing a slight opening did not reproduce the hissing sounds but did affect the knocking (as expected).
    When the HV charging switched on, the raptor sound started as expected. At this point I could manually adjust the EGR opening to make the engine run correctly. This is similar to when I made the adjustments via the Techstream active data test but this time I was able to make the adjustment in a more refined responsive way and it was close to normal... but I had to continuously adjust the valve in a dynamic situation.​
    I also played with the PVC and the Evap tubes. Both had a high vacuum presence and both would make the engine stall if I disconnected the tube for more than a few seconds.
    Any help is very much appreciated...
    One though came to mind when I was working near the ERG valve...
    The knocking sound appeared to be coming from the transaxle area.
    It reminded me of this video I had seen on youtube that identified the knocking sound as originating from transaxle:
    Gen 2 Prius Misfire
    "When Prius misfire the planetary gearset in the transmission slaps around, which can sound like a rod knock. This car had a clogged injector at cylinder #1, and that is all."
    It made me think...
    * Could my problem be in the transaxle?
    * Could this area be imposing a varying load that is causing the engine to misfire?
    * Perhaps there are no misfires... the problem / knocking sound is coming from a problem in the transaxle?
    This problem is driving me nuts...
    * Compression Test: Not yet... it's on my todo list. I have to borrow the tool.
    * Seafoam Test - I'd like to do this but I have a few concerns.
    A. The car is already making a deadly knocking sound... I'm concerned about driving it for extended time periods in its current condition.
    B. I can get to 2500 RPMs while parked in the maintenance mode... is 2500 close enough?
    C. I can't think of a way to get the engine to run at even higher rpms for an hour after the cleaning procedure.​
    Has anyone tried this on a Prius?
    Hills are hard to find in the Dallas area...
    Good idea... I hadn't thought of the camera trick.
    Can you post the url to the facebook pages?
    #35 DG Bear, Oct 23, 2015
  16. Former Member 68813
    3,524
    983
    US
    yes, when there is an ICE misfire, the transaxle motors compensate by momentarily providing torque. at about 10-20/s it will sound like heavy knocking. Easy to replicate by disconnecting one ignition coil.
    this pdf explains it rather well: http://www.aecs.net/techniek2012/March%20prius.pdf
    this would be the first thing i would do. the engine is probably tired at 300,000 miles and low compression can produce misfires.
    #36 Former Member 68813, Oct 26, 2015
  17. mindfk
    16
    United States
    Any updates DG Bear?
  18. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Who's prius is at 300,00 miles?
  19. Former Member 68813
    3,524
    983
    US
    Bears hibernate this time of year, right?
    Read post #1.
  20. mindfk
    16
    United States
    I found this: http://www.api.org/~/media/Files/Certification/Engine-Oil-Diesel/Forms/Whats-New/9-DAP-Understanding-Lubricant-Requirements-of-Hybrid-Electric-Vehicles-DClarke-Infineum-USA.pdf the other day and it made me wonder, maybe you have a bad ring, but then you say that the compression is even on all cylinders so it's probably not your case.
    Then I started to think that maybe the fuel pump is at the end of its life either due to wear or clogged fuel filter...that could cause high ltft but you say that's not the case in your car as well...you have an interesting issue in your prius
