1. Online
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,082
    826
    Charlotte, NC
    Your Vehicle Year:
    That's right, they're finally in-stock! 2010 Toyota Prius Fog Light Kit - OEM Quality
    [IMG]
    Product Description:
    Did you want the fog lights from the 2010 Prius model V, but didn't want to pay the hefty premium or lose out on other features? So did PriusChat, and that's why we are proud to bring you a factory-quality fog light kit that is easy to install and comes with everything you need to have that factory fresh look.
    The kit includes:
    • Fog light trim pieces to replace the "blanks" you currently have on your 2010 Prius below your turn signals.
    • Fog lights
    • Factory-quality switch to integrate into your dash
    • Full wiring
    • Full-color, step-by-step instructions
    PriusChat Shop : 2010 Toyota Prius Fog Light Kit - OEM Quality [PIPL-40C] - $114.99
    I've included both color and black and white versions of the installation documentation. I think the B/W version will print out better for installation, but the color ones are good if you are going to have your laptop nearby during the install.
    [IMG]
    15 people like this.
  2. Offline
    ibnird New Member
    Mar 1, 2010
    61
    SF Bay Area
    Your Vehicle Year:
    Can these be left on permanently and thus function as daytime running lights? In other words, will they turn off automatically when the car is turned off?
  3. Online
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,082
    826
    Charlotte, NC
    Your Vehicle Year:
    From what I can gather from the installation documentation, the answer to your question is: Yes, they will operate independently from the headlights and will turn off automatically when you power down the Prius. I haven't had a chance to install mine yet, but I will double check with the manufacturer to be sure.
  4. Offline
    spiderman wretched
    Jul 5, 2009
    5,628
    805
    Alaska
    Your Vehicle Year:
    If you hook it up per that instructions (brown wire @ the ECU) the answer is yes.
    1 people like this.
  5. Offline
    Nuckz23 New Member
    Jan 22, 2010
    125
    Santa Clara, California
    Your Vehicle Year:
    Picked them up. I can't wait to get them and install.
  6. Offline
    • Moderator
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    4,984
    718
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Question on that "method" - legally, these must shut off when high-beams are activated to keep the "4 simultaneous headlights on max" rule in check (note OE installs where fogs turn off with high-beams). Will they do that if wired as suggested? If not, we'd be looking at 6 lights on w/ high beams, and I wouldn't be interested in a ticket, despite the allure of this being a DRL solution.
  7. Offline
    maltbyman New Member
    Mar 23, 2010
    Greater Seattle Area
    Your Vehicle Year:
    Since I live in the Seattle, WA area, and I live in "rural suburbia," the fog lights are important to me. While DRL would be great (and I wonder why those aren't standard as well, at least give me the option to turn those on), I would much rather have the fog lights in our climate and dark winters. I am looking forward to seeing a post from someone who installs these!
  8. Offline
    wick1ert New Member
    Dec 3, 2009
    1,164
    147
    Delawhere
    Your Vehicle Year:
    I wonder if I got these, if I could just install them in the place where the bling lights currently are....I'd imagine the wiring would be essentially identical, with the only change being a real button as opposed to the radio-shackesque on/off switch I have now.
  9. Offline
    HI MPG New Member
    Aug 25, 2009
    758
    115
    Orange County, CA
    Your Vehicle Year:
    Just received the box... now to find some ramps and time this weekend to install.
  10. Offline
    spiderman wretched
    Jul 5, 2009
    5,628
    805
    Alaska
    Your Vehicle Year:
    Could you tell me if the lenses have DOT/SAE stamped on them? Thanks.
  11. Offline
    exbauer New Member
    Aug 16, 2006
    787
    42
    Chicago, IL
    Your Vehicle Year:
    If you could document and post pictures of your install that would greatly appreciated.
  12. Offline
    HI MPG New Member
    Aug 25, 2009
    758
    115
    Orange County, CA
    Your Vehicle Year:
    The lenses have SAE stamping on them and are glass, seems pretty thick to me.
    As for documentation and pictures, I will try. However, the instructions that Danny provided are very clear and look very precise. I haven't had a chance to review all the steps in detail, but they look comprehensible (I can say that I'm not very technically savvy when it comes to electrical connections, but the few connections that are required do not seem very difficult). With a newborn demanding all my attention these days, I'm not sure how much time I could devote to installation, documentation, and pictures. I'll attempt it though...
    2 people like this.
  13. Offline
    Prius42 New Member
    Mar 20, 2010
    140
    39
    Maryland
    Your Vehicle Year:
    Received the parts today. It all looks very straightforward although some of the instructions are a bit confusing. For example, Step 3.2 says install the lamp in the bezel which is easy enough but it doesn't stay put. It slides in but isn't fastened in any way. In step 3.4 it says to place the bezel assembly (bezel + lamp) in the hole in the vehicle and then fasten it with a supplied screw (there are 8 black wood screws and one machine screw so I assume it is one of the wood screws) and a 10 mm nut one took off when removing the blank. However, the wood screw appears to just secure the foglight to the bezel which I think would be easier to do before bringing the bezel assembly to the car. Anyway I screwed them together on the bench and will try putting them in the car tomorrow if it stops raining.
    All in all it looks like a high quality kit. Nice thick lenses, decent plastic, and high quality panel switch. I've attached a picture of the kit. One lamp is installed in the bezel (driver's side) and the other is not yet assembled.
    1 people like this.
  14. Offline
    deltron3030 New Member
    Sep 25, 2009
    441
    56
    Lakewood, CA
    Your Vehicle Year:
    I'm having a problem guys. My fog light kit does not work (no lights, no light on the switch) I installed the kit exactly as the directions instruct, with the exception of one step....
    There is a step where we are to remove 2 bolts from the engine compartment and place the relay at bolt one, and the ground and bolt two.
    I had an exceptionally hard time removing just one of the bolts so I attached both the ground and the relay to the same bolt (the ground is under the relay so it IS touching the bare metal).
    could this be the source of my problem? ever other step seems to be properly done.
  15. Offline
    spiderman wretched
    Jul 5, 2009
    5,628
    805
    Alaska
    Your Vehicle Year:
    We are assuming the lights are at least set to the parking lights setting... correct? You might also check the wire tap on the brown wire @ the ECU... that has caused a problem with another person.
  16. Offline
    Prius42 New Member
    Mar 20, 2010
    140
    39
    Maryland
    Your Vehicle Year:
    No that shouldn't be a problem. I just finished installing mine and I also had real trouble with those bolts. The one facing down came out fine and I put the ground under that one as directed. I could not get a socket wrench on the one that is facing sideways. I took it out with an open end wrench but with the relay under the screw I couldn't get it back in. I don't see how that was supposed to work anyway. There is a bent piece of metal above the screw which would have kept the relay from sitting flat and the bolt from going in all the way. I decided this was a bad idea. Thus I put the relay under the mounting bolt for the fuse box which is right next to the recalcitrant bolt. It fits well there. My fog lights work fine.
    I would check the 12V (red wire spade) connection in the fuse box, that the 20A inline fuse is okay, that the white wire bullet connection under the dash is connected (and check the female end which probably got abused being pulled through the firewall and make sure the wire into the crimp connector is still in good shape. Finally make sure the vampire connector onto the "brown" wire into the electrical harness is okay. This enables the fog light relay when the headlights are on. BTW, just to make sure, you know the foglights only work when the headlights are on (including the light on the switch)? If none of this is wrong, it is time to get out a multimeter.
    I have several pointers and minor corrections to the instructions which I'll try to post tomorrow night along with some pictures. The install took me 3 hours but I could do another one in an hour after figuring out a few things. Finally, the fogs stay on when you switch to high beam. I thought this wasn't legal since the lows, highs, and fogs are all on in this case. How does the V behave?
    p.s. the fogs look sharp!
  17. Online
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,082
    826
    Charlotte, NC
    Your Vehicle Year:
    Be sure you are following the B/W instructions for actual installation, because they are slightly different from the color ones. One of the main differences I picked out was on step 6.10, the B/W instructions point out a different bolt to use for the relay than the color one. Looks like a much easier bolt to use.
    2 people like this.
  18. Offline
    ibnird New Member
    Mar 1, 2010
    61
    SF Bay Area
    Your Vehicle Year:
    You mean that you must have your headlights on to use the foglights? If true, then there is no way to have the fogs on all by themselves as daytime running lights, correct?
  19. Offline
    spiderman wretched
    Jul 5, 2009
    5,628
    805
    Alaska
    Your Vehicle Year:
    Danny,
    Would your supplier consider just selling the light units separately?
  20. Offline
    Prius42 New Member
    Mar 20, 2010
    140
    39
    Maryland
    Your Vehicle Year:
    Well, the headlight interlock is a wire you attach yourself between the foglight relay and the prius electrical harness. I don't have a prius harness diagram but I would guess that this is just 12V and you could attach it to accessory 12V instead of the headlamp circuit. You would need a harness diagram which I've heard can be downloaded from Toyota by buying a 2 day technical subscription for like $15.
    1 people like this.
Share This Page
