2010 Prius OEM-quality Fog Light Kit Now Available!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danny, May 10, 2010.
  1. Judgeless
    Judgeless Senior Member
    1,821
    256
    Cleveland, OH
    Is it possible to order extra switches? I like the look of the switch. It would be great to get two extra. One to turn off the auto head lights and another to turn on an air horn.
  2. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Nope, I already inquired with our supplier about getting extra parts. The minimum order would be like 500 pieces of each part :(
  3. Judgeless
    1,821
    256
    Cleveland, OH
    Thanks, It does not hurt to ask.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I bought another Yaris kit from e-bay so I have an extra switch and wiring harness. I will probably put that up for sale soon. If you are interested, let me know.
  5. kawita
    kawita Junior Member
    88
    Batavia, IL
    Is anyone saving their blanks once they install the fogs? I can't imagine they're worth anything...
  6. SJ2010
    SJ2010 New Member
    Toronto
    Has anybody installed these yet?
    1. I was also wondering if there's a way to keep them on at all times (and thus function as DRL). There was a method suggested in this post (brown wire & ECU)...can someone verify this?
    2. I'm aware of the likelihood of having 6 lights (after high beam usage) but I'm from Canada and the regulations might be different.
    Thanks.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Actually the brown wire is only active when the parking/headlights are on. You would have to find a wire that is active when the car is powered up (so the light are on while the car is powered up). Shouldn't be hard to find a source since the fuse box is close by.
  8. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    ready to do this ... i have few questions:
    a) only 2 of the black wood screws get ued (1 each side assembly) - the rest 6 are not needed?
    b) the little machine screw w/ washer that came - where does that get used?
    Thanks everyone for all the tips. TIA !
  9. Prius42
    Prius42 New Member
    139
    Maryland
    As far as I was able to tell, these are extra parts. Have fun!!
  10. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    thanks! whew 3 hrs into it and now I just need to close up the patient ... checked the lights and everything working ...
    another question : do the fog light "on" indicator on the main display light up? or just that little green light on the switch??
    thanks again for everyones help!
  11. Prius42
    Prius42 New Member
    139
    Maryland
    No Just the switch. Good job! Did you have any trouble pulling the harness through the firewall?
  12. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    Thanks for the prompt replies P42 !
    I had no trouble pulling the harness once I punctured it (used soap solution) got it in one try but puncturing the damn rubber boot took me more than an hour only because i didnt have anything thin, long and sharp :( i also probably spent good 30 minutes rummaging thru the kitchen to find somehting suitable since wifey was absent ...
    some notes: I didnt find a neat place to hang the fuse coming off the relay so i tied it to another harness .. i also used atleast 12-15 more cable ties than the 6 included which looked mucho cheap and definitely not UV / ext weather rated (then again I am just anal) ...
    also cannot believe how plasticky this car is and yet i did not manage to break any of those tabs (touch wood) ...
    my only complaint is that the glass is not totally tight against the bezel and bezel is not totally tight with the bumper - otherwise I am pretty pleased ... keep in mind i did it for aesthetics instead of functionality ...
    this was my first major mod to the Prius ... once again, thanks P42 and everyone else ...
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    2 people like this.
  14. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    Danny,
    I was in a rush and scrolled rather quickly re: use of fogs as DRLs. Have you installed them and will they function as DRLs?
    Thanks,
    Tony Renier
  15. Tideland Prius
    16,206
    How'd you guys get the ground and fuse to attach to the recommended locations? The ground bolt was impossible to remove (I think it must've been overtightened) and the fuse bolt was pretty hard to screw back once the fuse was attached.
  16. Prius42
    Prius42 New Member
    139
    Maryland
    Hi Tideland. Do you mean the relay and the ground strap? The fuse was an inline plastic housing which I just cable-tied to the harness. I remember attaching the relay was a little awkward but putting it under the same bolt holding the fuse box worked well. The bolts were tight but threaded smoothly.
  17. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Does anyone know if the foglights are still available? Placed an order about three weeks ago and haven't gotten them yet so was just wondering.
  18. jdcollins5
    5,131
    1,338
    Wilmington, NC
    PM Danny and have him check for you.
  19. ozzielj31
    ozzielj31 New Member
    Olympia,WA
    I ordered mine two weeks ago and they arrived yesterday...had them installed today at Car Toys...look and work great.
    Ozzielj
  20. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    I attached both the relay and the ground to one of the engine bolts...those twobwere very difficult to get to and one bolt was much more awkwardly positioned than the other so I just made sure the ground went between the relay and the frame
