2010 Prius Option Packages at NAIAS
Discussion in 'Gen 3 Prius Main Forum' started by Vincent, Jan 24, 2009.
  1. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    Just for clarity's sake: As of this moment, there is NO plan to introduce any model equipped with both (Solar Roof) AND (LED headlamps/17" wheels/DRCC/LKA/PCS/IPA). The reason is that the weight of the vehicle would be too high, causing impacts to fuel economy and requiring more substantial engineering changes. I will never say never, but for the foreseeable future, that is (unfortunately) the case.
    Thanks for continuing to state your case. The more you do, the more pressure there is on us to make sure our customers are satisfied. Keep complaining! ;)
    Doug Coleman
    Prius Product Manager
    Toyota Motor Sales USA
  2. DotComCTO
    DotComCTO New Member
    16
    Westchester County, NY
    Doug,
    Thanks for the amazingly fast response. Frankly, I hadn't expected a direct response. I'm most grateful for the direct communication.
    So, should I take this to mean that the weight of the solar panel moonroof is pushing the Prius curb weight too high, therefore, adding any other tech options is putting it over the Toyota Design Team's target empty weight (like the weight & balance chart in a plane)?
    Either way, I was really hoping to see a more robust bundling of the advanced technology options. Ugh. This is making matters very complicated indeed. The one additional feature I'd personally want with the solar panel moonroof is the DRCC/PCS. The IPA, LKA and 17" alloy wheels are nice, but not crucial. I'd have a preference for LED headlights, but again, not critical. The DRCC/PCS is a huge plus for someone like me that is driving quite a lot. It's really annoying to have to constantly fiddle with cruise control when someone gets ahead of me, but is driving more slowly.
    I suppose the "gold" package is where I'd stop (grudgingly)...the solar panel moonroof & remote A/C are a higher priority than the other options. But...any chance of seeing the combination or the moonroof + DRCC, or is it the weight of the solar panel that is the "deal breaker"?
    And again...thanks for making yourself available on these forums! Great job!
    :cool:
    --DotComCTO
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thank You as well for the direct reply. How about the platinum package plus the moonroof and aolar panels but getting rid of the 17" rims and just using the 15" rims? Would that work or would there still be more substantial engineering changes to be made? Quite a few of us getting the platinum really want the tech and would take the tradeoff of rims for the solar... We're trying to state out cases I guess so we can keep the pressure high to try and satisfy us before laying out 35k to 40k now only see it come out a year down the road for others after we, the faithful, drop the money early lol
    Also, is this package setup getting released in Europe because of it is then it doesn't seem many engineering changes would need to be made:
  4. fookie
    fookie "The Stig"
    38
    DC / Eze, France
    Just out of curiosity, would having a 1 door smart key system and a 3 door smart key system being produced concurrently on various trim levels really save money over having a standard 3 door system?
    I'm planning to pick up the 2010 Prius through our company's fleet program and most likely I'll get something close to a package #3 (silver). My wife and I excited at the prospect of owning a Toyota again after some very expensive to own German vehicles....our wallets will thank you too!
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    obviously yes, otherwise they wouldnt have had it that way.
    In Europe, we will get everything on our Prius's, but they will also be significantly more expensive than in the USA.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    In Australia we will pay more for a base Prius than you pay for Gold or Platinum package while our optioned up version and there will likely only be 1, will cost as much as you pay for a small Lexus in USA.
  7. Tideland Prius
    16,509
    European NCAP and emission standards will be different so they may allow a higher weight.
    i.e. I think there must be a weight range for an mpg sticker to be valid. Obviously a loaded Prius will get less mpg than a basic one so there must be a range where they say that this value (say 50mpg) is valid for the Prius up to x lbs otherwise they may have to retest.
  8. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    Doug, what about the possibility of just adding the Led Headlight and fog lamp combination. Would this be too much weight? And, could this be added later after delivery by a dealer?
    The wheel weight of the 17" seems to me to be the main issue. But all I would want is the LED lights added to the "Gold" package.
    Thanks,
    Lee
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If that is the problem, which it sounds plausible, then just tell us that.
    And if the package in the Platinum which consists of the LED headlights/DRCC/LKA/PCS/IPA is called something like an advanced technology package it should really have the solar panels as well. If putting on 15" rims is necessary to make it happen they should. Then it would be a 'complete' advanced technology package in my book...
  10. DotComCTO
    16
    Having thought about this a bit more, I going to make a wild guess that there are two issues:
    1. Overall weight with the solar panel moonroof.
    2. How to bundle the remaining "tech" items into a compelling package that someone would want (or make a trade-off for the solar panel). For example, if there were a package with the mooroof + LED lights + 17" alloy wheels, how many people would buy a package that deleted those and added the remaining options?
    Does that make sense?
    --DotComCTO
  11. Tideland Prius
    16,509
    It's clear that the Platinum package is to appeal to those that are moving down from luxury cars. Even the Gold sticks with 15" alloys which is meant for us. Granted, we'd like the LED headlights but you also have to find a reason for Toyota to offer the Platinum.
    Think about it. The PCS/ACC option has been available on Lexus models as a stand-alone option (bundled or standard on higher models). The take-rate of those options is very very small (something in the order of 5%). If Toyota took out the LED headlights (or made them available on the lower packages), the incentive to move up to the Platinum isn't there (PCS/ACC/LKA and 17" alloys won't work).
    Gold is already very well equipped. If they added the LEDs to that, the % of people getting the Platinum would be even lower.
  12. fredthepostman
    422
    boothwyn pa
    Correct me if I'm wrong but it seems like most of the packages that we are talking about most people can't afford. If Prius cares about making hybrids popular they have to keep the prices down. I don't like the Insight but I think they have the right Idea as far as being affordable. Hybryds will only be popular if the public can afford them. I would love to get all the extras they are talking about but it seems that Toyota is going to make it difficult for me to get even the basic model.
  13. catsbox
    catsbox Member
    295
    Bellevue, WA
    Last I heard the prices had not yet been released. Do you know something the rest of us don't? If not, how can you make such a statement?
  14. Tideland Prius
    16,509
    That's because Toyota gave us 3 pre-order packages and they're usually on the higher end of the scale (except the Silver one).
  15. patsparks
    10,664
    567
    The Silver package would suit me and would be a step up from what I have.
    It seems Americans are acustomed to being spoiled for choice, here we get 3 choices with the current Prius,
    Basic although better equiped than the US basic Prius, it has no nav, 2 airbags and no SKS, $37,400
    iTech with everything. $46,900
    Another car. $???
    I expect we will have a similar set of choices with the 2010.
  16. Tideland Prius
    16,509
    Yup. They had 9 packages to choose from in 2004. We only had two (bumped to 3 in 2005 with the addition of a navigation system with bluetooth)
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    2004 Pioneer buyers only had 3 to choose from. ;-) Notice a trend?
  18. spwolf
    3,156
    440
    Eastern Europe
    well thats why there is an base package... or are you complaining that there are high end packages? :)
  19. Tideland Prius
    16,509
    I doubt they'll be 9 packages this time but yes I get the reason for 3 packages this time.
  20. fredthepostman
    422
    boothwyn pa
    I was hoping a few months ago after reading that Toyota had reduced the cost of the making hybrids that either there would be a reduction in the base price or that they would improve the Prius but maintain the base cost . I have to admit that everything they did to improve the car is great but I feel that keeping the car affordable to more people is essential.
    I do hope Toyota has taken into account the countless number of people who want to buy a car that not only gets 50 or more mpg's but is affordable.
