For Sale 2010 Prius V 17" wheels/tires
Discussion in 'Private Sales' started by Vecoplan, Oct 12, 2014.
  1. Vecoplan
    Vecoplan New Member
    $700 LOCATED IN CENTRAL NC
    Toyota P/N 4261147200
    These came on my wife's V from dealer (bought used from Vann York in HP) and I'm using it as an excuse to swap my OEM wheels off my BRZ (yes I know I need 5mm spacers) over to her car and get new wheels for me :). All 4 tires have pretty good tread, I haven't measured how much but enough that the dealer sold them to us with them I guess. One of the tires looks like some one ran it out of camber for a little while (it was on drivers side rear) on the outside (which is odd... usually bad camber wears the inside so maybe the switched them over at some point). The area of camber wear isn't bad or anything... No nylon showing or anything like that just trying to describe as good as possible. The wheels are fairly "like new" looking. Some Japanese brand tire on there, Yokohama, Toyo , something like that I don't remember but can look when I get home if you care.
    EDIT: as pointed out below- Sumitomo tires 215/45/17
    #1 Vecoplan, Oct 12, 2014
  2. Vecoplan
    Vecoplan New Member
    $700
  3. JC91006
    16,498
    8,408
  4. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Outside tread wear is caused by excess toe-in. It likely happened on the front and was rotated to the rear.
    For the BRZ wheels on the Prius you need 3mm spacers, not 5mm. Go that thick, and you wont have any threads holding on the lugs.
    GLWS
  5. drowssap
    drowssap Member
    154
    30
    Thanks for edit and GLWS. Pretty good deal for a lucky buyer
    #5 drowssap, Oct 12, 2014
  6. JC91006
    16,498
    8,408
    Listing your location will help
  7. Vecoplan
    Vecoplan New Member
    SUGGESTED CHANGES MADE IN ORIGINAL POST
    #7 Vecoplan, Oct 13, 2014
  8. Manila Ice
    Manila Ice Hybrid and V8 Lover
    96
    63
    Chino Hills
    any pix of the other 3 wheels....
  9. John Bergendahl
    102
    17
    gulfport,ms
    Wanna trade for some OEM 15's
  10. Vecoplan
    Vecoplan New Member
    I'll post pix tomorrow. All look just as good. Not interested in 15s. Sorry.
  11. Vecoplan
    Vecoplan New Member
