2010 Prius V thru 2012 prius five owners
Discussion in 'Gen 3 Prius Main Forum' started by terry brecheen, Jun 30, 2014.
  1. terry brecheen
    139
    30
    houston, texas
    I'm thinking seriously thinking about joining you guys in owning a 2012 five. My question is have any of you had any major out of pocket expense after the factory bumper to bumper warranty expired? . It will help me make up my mind about purchasing extended warranty. Any help would be greatly appreciated.
  2. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    I'm at 108,000 miles on my 2010 V and I have only done regular maintenance. No problems to speak of ... knock on wood
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
  4. ALMAL
    ALMAL New Member
    DC Area
    I'm also a newbie, but the cost of tires would be my concern, maybe every 3-4 years of replacement.
  5. cproaudio
    2,401
    758
    CA
    My tires are stock. I'm at 51k and have 7/32" thread left.
  6. terry brecheen
    139
    30
    houston, texas
    Brian, do you have ATP ??
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    In 4.5 years & 90000 miles no expenses beyond regular maintenance (oil & filter changes). 60000 miles on the OEM tires at max. sidewall pressure. Tranny fluid drain & fill at 60000 miles.
    A set of LRR tires will save their cost in gas over 60000 miles and are not necessarily more expensive. Try to time the purchase with the "4th tire for $1" promos that come around fairly often.
    Long haul driving is much more civilized with the AT package.
    The extended warranty is just extra profit for the seller. If it's a good deal for the buyer then the seller wouldn't sell it.
  8. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    Yes I have ATP
  9. terry brecheen
    139
    30
    houston, texas
    JIm, what kind of mpg do you get ?.
  10. JimN
    7,028
    1,116
    South Jersey
    On the Yokohama AVID ENVigor tires I have a lifetime average of 49.1mpg over 27827 miles. Going from 350 miles per week to 500 miles per quarter hasn't caused a significant decrease, to my surprise.
    I put 61772 miles on the OEM Toyo Proxes A20 tires for a 54.6mpg average.
    The lifetime average is now 52.8mpg over 89599 miles.
    The Yokohamas make me happy one week per year when I rally & autocross in the 21st Century Automotive Challenge. I've had higher FE on them in the mountains than on the Toyos.
  11. terry brecheen
    139
    30
    houston, texas
    thanks for the reply. I will be getting my 2012 five Monday or Tuesday. The dealer is delivering it to me no charge from Amarillo to Houston. It's got 30000 miles on it and loaded with everything. Atp is what I really wanted and tires will get replaced if the continental tires that are on it are not LRR tires. You have been most helpful. Thank you.
  12. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    200,000 KMS (125,000 miles) and only normal service costs.
  13. JimN
    7,028
    1,116
    South Jersey
    Since the car only has 30000 miles those tires may be OEM. Tires are sourced from a handful of manufacturers so it's common to see two or three different sets of tires on the dealer's lot.
    I wouldn't be in a hurry to swap the tires. Take time to get accustomed to the car, decide what you believe will be a better tire, and wait for the tire sale. There are several criteria that need to be balanced.
    xpcman likes this.
  14. RaZa
    RaZa Member
    480
    93
    I own a 2012 5 ATP with 60K on it so far. Only extra money I've spent is on a couple of tire blowouts. Oh and maybe a few extra compulsive car washes :)
  15. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    And do you overinflate your tires or leave them at the recommended pressures front/back? Do you often run with a fairly full load in the back or just the usual groceries, etc.?
  16. RaZa
    RaZa Member
    480
    93
    I've always run the recommended pressures on front and back. I've rarely had any kind of load in the back
  17. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Thanks, I'm really conflicted reading the thread that discusses running 38/36 or 38 all around.
  18. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Unless you put a huge amount of miles on the car. It's just not cost effective to replace the tires before they are worn out. I only got 25k on the original tires. Probably because I drive HARD on a lot of hilly back roads.
