2011 Prius ATF Drain and Fill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by calirider, Jun 5, 2015.
  1. calirider
    calirider ECOmobile
    105
    33
    California Central Valley
    This is the second time I have change the ATF. First was at 35k and now at 93k. Looked good to me, not sending it in for analysis or anything.
    Pictures attached is a side by side of new ATF and my used ATF.
    4 quarts came out and 3 3/4 quarts went in.
    xliderider likes this.
  2. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Thanks for posting the pics. :) I also changed the transaxle fluid at 35k.
    I was planning on changing it next at 100k. Yours looks pretty good at 93k.
  3. calirider
    calirider ECOmobile
    105
    33
    I had the same idea of 100k but got anxious and just decided to change it now.
    I was surprised at how red it still was but I drive easy and a lot of freeway driving.
  4. xliderider
    7,849
    3,103
    Honolulu, HI
    I'm curious that you were able to drain 1/4 of a quart more fluid than you got in. Was the car level, or did you raise only the front end?
  5. calirider
    calirider ECOmobile
    105
    33
    It was level. If my research was right 3.5-4 is normal.
  6. xliderider
    7,849
    3,103
    Honolulu, HI
    Yep, and fluid level between 0 to 10mm below bottom of fill hole. You're good.
  7. Mendel Leisk
    38,270
    Yup, ours took about 3.5 liters, which are bit bigger. Seems like the first change is the critical one, after that the fluid is more durable.
  8. A617
    A617 Member
    213
    95
    OKC, OK
    Its strange how ATF WS turns from cough syrup red to grape juice purple, usually atf turns from red to brown.
  9. xliderider
    7,849
    3,103
    Honolulu, HI
    The fluid at 35k was brown, don't know where you are seeing purple, unless red plus brown looks purple to you. ;)
  10. calirider
    calirider ECOmobile
    105
    33
    The pictures on here was my most recent change compared to new oil. And I also think it has more of a purple tint to it than brown.
  11. Tideland Prius
    16,075
    I had mine changed last Sept at 96,000km (60,000 miles). The advisor said I was low on ATF but the technicians didn't find any leaks.
  12. calirider
    calirider ECOmobile
    105
    33
    Was that your first ATF change? Did it come low from the assembly line? If you park in the same spot overnight regularly it's pretty obvious if you have any type of oil leak.
  13. Tideland Prius
    16,075
    Yes it was my first ATF change. I don't know if it came low from the factory as I didn't check the level when the car was new.
    There was no mark on the parking spot.
  14. bisco
    49,012
    i wonder what constitutes low.
  15. Tideland Prius
    16,075
    Not sure. I didn't press the issue further since it would be topped off.
  16. bisco
    49,012
    right. could have been one millimeter, or 10.
  17. calirider
    calirider ECOmobile
    105
    33
    Or it could of been a miscommunication at the dealership. I would highly doubt it came low from the factory and if there were no oil spots in its parking spot I would doubt it was leaking oil also.
  18. Tideland Prius
    16,075
    Possibly. The advisor told me this. I didn't speak to the technician directly. Like Bisco said, it could be within range but on the low end (or just barely making the minimal required fluid amount).
  19. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Several months ago, I read somewhere (probably a Priuschat thread) that that's typical of factory fill. Toyota doesn't waste WS by putting in more than needed.
    When I drained mine, about a cupful less came out than the amount needed to refill it up to the fill hole. There were no signs of leaks.
    Tideland Prius likes this.
  20. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Could you tell us what tools you used for the drain and fill? I'd like to do mine, but don't have tools yet. Please be as specific as possible with brands and model numbers if you have that info.
    Thanks!
