2011 Prius Energy Monitor not displaying arrows.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Scotty-P, Sep 1, 2015.
  1. Scotty-P
    Scotty-P New Member
    Chesapeake, VA
    I have a 2011 Prius with 75000miles. The energy monitor (car icon with ICE, Electric motor, and battery) no longer displays the arrows showing energy flow. The wheels on the car are still animated when the vehicle is in motion.
    I have searched through the forums and see that several people have had a similar problem but have not been able to see that anyone was able to solve the problem.
    Any suggestions?
    Thanks
    49,798
    that's an odd one, is the car running fine and mpg's normal?
  3. Scotty-P
    Scotty-P New Member
    Chesapeake, VA
    Car is running fine, haven't noticed and issues. Acceleration is good and I am averaging 50+ mpg. Problem does not seem to affect operation of the car in any way. Just missing the display of the animated arrows.
    49,798
    probably a long shot, but how is the 12v health?
  5. Scotty-P
    Scotty-P New Member
    Chesapeake, VA
    Had the same thought. Battery is good. Has been replaced once. Car Quest battery. Voltage is good.
  6. FACHA
    FACHA New Member
    Aurora
    Did any one have this problem with the energy arrows fixed?
    Thank you.
  7. Polish Prius
    Polish Prius Junior Member
    16
    Poland
    I have the same problem with arrows. I am new to this forum and have had my 2011 Prius only since November 2016. I usually drive using the Hybrid monitor or the 1-5 min consumption bar graph but sometimes want to switch to the Energy monitor and my arrows seem to show up while on other days they don't. There is no consistency. I am the second owner, so I don't know if the auxiliary battery has been disconnected or not. I have searched the forum and there seems to be no definite answer to this problem. I drive a European version. It's not really a problem because everything else works fine. The battery is charging. Has anyone found a reason for this strange behaviour?
    #7 Polish Prius, Feb 27, 2017
  8. Joost78
    Joost78 New Member
    zwolle
    Just came back from the dealer with same issue. The issue was that previous owner/dealer forgot to reattach the temp sensor on the 12v battery!
  9. TerryP
    TerryP New Member
    Mission Viejo
    The "temperature sensor" on top of the auxiliary 12- volt battery attached to the holding bar. either detaching from the 2-wire connector or faulty sensor will deactivate the arrows animation in the Energy Monitor screen and on touchscreen also.
    My problem was fixed today. I found out one of the 2 wires was cut, and I reattached that wire, and the arrows shown.
    Attached is the sensor. Toyota calls it thermistor
  10. William Warf
    William Warf New Member
    Rantoul, IL
    Does this issue affect air conditioning on top of the arrows and charge info not displaying? I have a Gen 2 (2008) with this issue currently.
