2012 Prius v Press Release Materials
Discussion in 'Prius v Main Forum' started by TonyPSchaefer, Sep 20, 2011.
  1. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Here are the Press Release materials provided by Toyota on September 17th.
  2. Tideland Prius
    16,073
    Maybe keep the date out so you can just keep adding press release material as they are distributed for various years or models.
  3. TonyPSchaefer
    14,816
    2,497
    66
    We can all just make sure the date is in the posts to which we attach materials. This way, we'll know the dates they are released.
  4. Tideland Prius
    16,073
  5. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    I just went to the Toyo website and found info hard to get to, screens that didn't open, and long lists of features so blended together that it's a headache. NOT impressive marketing. Neither is the obnoxious NYTimes homepage, where the MBenz ad is inyourface.
    Toyo V (yes, I'd like to see that capitalized, so it isn't like versus) is a great product, but more attention is needed in it's onthescreen presentation.
  6. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    The emblem on the side of my car, clearly, has a capital "V".
  7. borjbor
    borjbor New Member
    new york
    2000 Prius
    I
    wow thats a gud thing to hear!!!prius model for a new year!
  8. borjbor
    borjbor New Member
    new york
    2000 Prius
    I
    i think latest materials will be used!
  9. jas1178
    jas1178 Junior Member
    44
    St. Petersburg, FL
    Agreed - definitely a capital V
  10. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Is it a capital V, or is it a little v in a larger font size, like Prius v? :)
  11. sandrajolly
    sandrajolly New Member
    Tennessee
    Thanks for taking the time to discuss this, I feel strongly about information and love learning more on this. If possible, as you gain expertise, It is extremely helpful for me. would you mind updating your blog with more information. :)
  12. blisspacket
    32
    StAugustine FL
    And today I note the phrase "while producing low smog-forming emissions". Digest that. The wordsmiths clearly don't know how to covey positively what they want to say.
    The website is still too fast to absorb the written text that flashes by. I won't rant on, because no one seems to be looking/reading at toyota inc.
  13. hellow91
    hellow91 New Member
    It's informative
  14. hill
    8,071
    I have a coworker interested in buying the v but he'd like to know what the front seat cushion height is ... (no info on the spec sheet) can anyone help a brothah out? (he's deciding between the v & and the c-max
    thx
  15. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    The seat cushion height is adjustable. I like to pump it up higher for a better view down the road. Does your friend need head room or height?
  16. hill
    8,071
    Ease of entry ... (handicap) so I would suspect nearly maximum height would be best case scenario for entry - as she can't get down real low - so the higher the better
  17. Monicka_Kahawm
    Monicka_Kahawm New Member
    Hi guys I'm not sure how to start .. With this chat stuff .. Can someone help .. I have a 2012 PriusV .. Engine died took it to dealer it will only start for a minute n cuts off the say fuel pump n has line are good .. Can anyone explain why it not getting has where it go to keep car running ..!? Pretty frustrated ... Only car we have also ..
    iPhone ?
  18. bisco
    48,995
    is under warranty, yes?
  19. Elsiediveley
    Elsiediveley New Member
    Chunky, MS 39323
    I drive a PriusV I purchased some jumper cable that goes from cigarette lighter to cigarette lighter just in case I ever needed to jump my car off. Does anyone know if these really work, or did I just waste money?
  20. rjparker
    rjparker Tu Humilde Sirviente
    7,610
    4,464
    Texas Hill Country
    Won't work on a Prius because the lighter is turned off when you might need it. If possible take it back and consider buying a portable starter battery like an Antigravity Lithium Jump Start Battery Kit or a cheaper and less reliable lead acid version. The Lithium versions are smaller and liess weight and are likely to hold their charge much longer so it's there when you need it. Finally have the manual information on how to do it via the engine bay's fuse box available and understand a wrong connection could burn out expensive electronics.
    SnoozinJTD likes this.
