2012 Prius v Won't Start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CrazyJen, Mar 28, 2013.
  1. CrazyJen
    CrazyJen
    Expand Collapse
    Junior Member
    San Fran Bay Area
    I'm hoping I can get some help from you folks.
    I came downstairs to my Prius v with my kids and our laundry to find a completely dead car. I couldn't open the trunk. Luckily the doors were already unlocked. The power button doesn't work at all. No lights no nothing. It is DEAD. Is it possible the battery discharged and I need a jump? Or is this more serious and I need to get it towed to the dealer?
  2. Indy John
    Indy John
    Expand Collapse
    Member
    70
    27
    Indianapolis
    It is almost a certainty that the 12-volt battery is dead.
    A "jump" to the 12-volt terminal in the under-hood fuse box would likely get you started.
    EXTREME caution must be used - positive to positive, negative to nearby bolt in engine compartment.
    BETTER to use a battery charger, 4 amp. max., for several hours first, then start normally.
    Jumping without charging first may get you going, but the battery charging circuit is inadequate to restore the battery to full charge unless you'll be going on a multi-hour trip.
  3. xpcman
    xpcman
    Expand Collapse
    Senior Member
    1,284
    261
    California - SF Bay area
    Probably a dead battery.
    You must be very careful when you jump start a Prius. AAA should know how. But, your neighbor probably doesn't. You can fry $1,000+ worth of parts if it's done wrong. You need to keep the Prius in the "Ready" state for an hour or more to get a minimal charge after the jump.
    Good Luck
  4. css28
    css28
    Expand Collapse
    Senior Member
    1,559
    419
    Suburban Detroit
    The good news is that the 12V battery doesn't do the work of the cranking so you should be able to use wimpy jumper cables.
  5. sURFNmADNESS
    sURFNmADNESS
    Expand Collapse
    Prii Family
    186
    Omaha, NE
    I have not had my 2012 v do it yet but know my wife killed her 2006 Prius by leaving on the dome light for more than a few hours. I have a battery jump pack for just such times which works well when you follow the instructions for jump starting the Prius.
  6. F8L
    F8L
    Expand Collapse
    Protecting Habitat & AG Lands
    19,149
    4,027
    50
    Sacramento, CA.
    2013 Chevy Volt
    You can unlock the door manually with the key inside your key fob. The truck can also be opened from inside (read the manual).
    If this happens more than a few times you may want to replace the 12v battery. They don't like being fully discharged multiple times and can cause weird issues and lower mpg if they go mostly bad.
