2013 Prius v (lowercase v) 50+mpg
Discussion in 'Prius v Fuel Economy' started by shawnph1970, Apr 23, 2014.
  1. shawnph1970
    shawnph1970 Junior Member
    I got my Prius v in November 2013. I live in North Florida, fairly mild winter but does get cold. In Dec I got 44mpg. In Jan-Feb I got 47.5mpg. Now that it's warm out, I'm getting an astonishing 55.6mpg, although it looks like it may settle somewhere between 53 and 55 over the next week.
    I'm going by the Prius' computer. So it could be off a bit. But I find a number this high strange. I live in the suburbs and 90% of my driving is 35/45mph in warm weather on totally flat terrain.
    This seem like it's on the high side, based on what I've been reading. I admit I do use a lot of the techniques I read about, accelerating like a grandpa after a red light when no one is behind and doing the pump/glide thing when I can get away with it and no one will be annoyed.
    I keep the tire pressure at 40/42, if that matters. Apparently, it might.
    Still though, these are some crazy MPG, even if it's a few MPG off if calculating manually.
    49,797
    35-45 is right in the sweet spot., especially if you don't have too many stops. congrats!(y)
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The computer is roughly 5% over-generous on the MPG. It takes the car a few thousand miles to loosen up and do its best, so you're right on track, and with the warmer weather. It should fall off a bit once you start working the A/C hard. I find I do best when ambient temps are around 70-80'.
  4. vskid3
    vskid3 Active Member
    773
    228
    Check the mileage when you fill up to know for sure. The computer is usually off, but seems pretty consistent in my experience.
    Having your tires pumped up where they are definitely helps. One thing that may be hurting your mileage a bit is accelerating slow. Brisk acceleration is generally considered best for mileage as long as you won't have to slow down right after.
  5. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    Fill your Prius full of gas; trip distance meter to " 0 " ( A or B ) ; and drive to a point when the
    " FUEL" light comes on. ( don't worry , you will not run out of gas, you will still have about 1 1/2 gallons left in the tank ) Gas it up to full; check mileage on trip meter { 572 miles example } and divide it by how much fuel you put in { 10.3 U S gallons example } = to 55.5 MPG example. Try to gas up on level ground and don't top off the tank. If you need to put 50 more cents in the Prius to round up to a dollar, that's ok!!
  6. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    No question, the Florida roads and temps are appreciated by the Prius.
    35-35 mph is a definite sweet spot for mpg, but the highway mileage is sweet as well.
  7. Stevevee
    821
    224
    Vermont
    Just had the snow tires taken off Thursday, and I haven't gotten to check the tire pressure yet. But my displayed mileage is a little higher, but I've not done the same trips yet on the highway. My OEM tires are the Yokohama Blue earth LRR's. The trouble with most of those tires is their tread wear rating, usually a lower number on the 300's. The Yokohama's on our Camry Hybrid have a tread wear rating in the high 500's, are not LRR's, and the fuel mileage is stellar. Typically, these tires will last almost twice as long as most LRR's will. An exception I recently saw was a new Yokohama Avid Ascend, an LRR tire, which has an incredible tread wear rating of 740.
  8. Richard Jones
    Richard Jones New Member
    NY
    One of the biggest drains on gas economy is the AC when you've got it on full blast so you'll get your real figure later on. That said, glad you're enjoying your Prius, the mpg makes it perfect for daily use, it's great.
  9. Stevevee
    821
    224
    Vermont
    In my experience, the very worst mileage is when it's cold, and/or windy. My highest mileage ratings on trips were obtained regardless of AC blasting or not. I haven't noticed much of a change there. The wind is particularly cruel to hybrid gas milage.
  10. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Agreed, the A/C is the least of the possible detriments to MPG.
  11. mikefocke
    3,729
    1,665
    Sanford, NC
    Rain and thus driving through puddles in the ruts on older roads increases the rolling resistance and kills mileage.
  12. J L
    J L Junior Member
    30
    Northern VA
    2013 Prius v wagon
    I currently get 52 MPG and I do a mix of 65 MPH highway driving and 35-45 MPH in-town driving. With the way traffic is around here, fuel economy is not a focus of my driving. I do keep the climate control on and usually have something playing on the audio system.
    I think the tires make the biggest difference. I am on the factory-installed Bridgestone Turanza tires and I'm really surprised to get mileage like this given the general consensus that these tires are of mediocre quality.
    I plan on switching to Yokohama tires in the spring, and I expect my MPG number to change somewhat.
  13. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    At 75 to 85 mph driving round trip between Las Vegas to Thousand Oaks, California I get 38.6 mpg. as an average. I do not drive for mileage but to get this nice person-flattening trip over as soon as possible. :notworthy: Also sometimes I hit the PWR button to do faster merging from on-ramps when traffic is congested. Then I hit ECO after that.
    I have 215/50/17" Yokohama 580 tires (V rated) so they are not the skinniest tires but I got them for better handling and braking.
    Also my v is lowered 1 inch on Tanabe springs so that may help a tiny bit.
    "Supposably" my INJEN cold air intake lowers mileage too but I really doubt that.
    #13 Eric "v", Nov 21, 2014
  14. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    My v now has over 13,000 miles in 10 months of driving all over the southwest. And finally it is getting better mileage. I think the piston rings take longer to seat well due to the synthetic oil Toyota uses (and which I've used exclusively since 1989).
    Also I notice a bit better acceleration which I attribute to the same thing. I've had my cold air intake on since the 7,000 mile mark but am lately getting even more power.
  15. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    i do about 70-80 with cruise and get about 42-44mpg.
  16. Stevevee
    821
    224
    Vermont
    My fellow hybrid driver today got 35 round trip. Dropped to the teens with a very stiff Northwest wind. My mileage since last summer's trip East is now at 40.5 mpg over 8,500 miles. I would easily be at 43 lifetime or so if I don't live here.
  17. Dalamar
    Dalamar Junior Member
    2013 Prius v wagon
    I originally got a 2011 hatch from carmax (avoid that place like the plague) returned it after 30 days, i only drove it 4 and was in a loaner the rest of the time, anyway, I picked up a 2013 v (lowercase v for the Prius v wagon) five from a private party and love it, over the first 250ish miles I'm averaging 51.6 mpg, I live in SW Florida and go 63 on the highway, limit in town. I got around to increasing the tire psi to sidewall spec and hopefully it will go up :)
  18. Blue_Chord
    Blue_Chord New Member
    Eugene
    2015 Prius v wagon
    Usually going higher than recommend on tire pressure actually costs more in the long run due to irregular tire wear. You want to go off the placard on the driver side door jam for your tire pressure, not the tire's sidewall. The sidewall pressure is the MAX pressure that the tire can be inflated to. Premature tire wear will cost you far more than any MPG gains.
  19. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    With 25K miles on my EnergySaver A/S at 42psi, there is zero indication of unusual wear. Running MFG suggest pressure is almost always going to result in wear patterns consistent with under-inflation.
    What used to be true for high-profile radials in days past with respect to pressure and wear is no longer true with low-profile tires.
  20. Blue_Chord
    Eugene
    2015 Prius v wagon
    Do what you want with your tires, I'm just telling you what I have seen and learned from being in the tire industry for ten years, and taking tons of classes from Michelin.
    You are changing the contact patch of the tire with the road, and there are consequences. What small amount you may gain in MPG, you lose in breaking ability, handling, you hydroplane easier, there is risk of belt separation from an impact, and you could develop a irregular wear pattern that will result in loss of tire life. That will also void your mileage warranty of 55k.
    Someone once told me a good question to ask yourself before you change something on your car:
    "Am I smarter than all the engineers who decided to do this this way?"
