2014 Prius Two fill up issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HaminusMaximus, Aug 29, 2015.
  1. HaminusMaximus
    HaminusMaximus Junior Member
    Los Angeles
    About 3 weeks ago I bought 2014 Prius Two. Was purchased as A Certified Pre Owned. At first I thought I just got a bad pump at the gas station. It's now been 5 fill ups at three different stations and same problem every time.
    The fuel pump clicks almost instantly when trying to fill. I've tried different angles and manage to get a few gallons in before it prematurely clicks. I've resorted to holding the pump at the minimum flow to to get a consistent flow until fill up.
    Any ideas?car is under warranty so will probably just take it to the dealer. If it something quick and easy fix I'd rather just do it myself over the weekend..
    I've ran the gas low most fill ups and topped off.
  2. JC91006
    16,500
    8,411
  3. orenji
    orenji Senior Member
    5,884
    3,486
    Our Benz does the same thing, only way to fill up, is to push in and pull up on the handle.....it sucks.
  4. JC91006
    16,500
    8,411
    I feel it's the pump, sometimes it happens to me, sometimes it doesn't........and I fill up at the same place almost all the time.
  5. orenji
    5,884
    3,486
    I agree, its the new pumps, that have been set up to capture the fumes.....
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    hold the nozzle half way out and side ways so you can hear air coming out as the gas is going in...its the only way to fill it, I fill up every 300 miles to be on the safe side..i get 140 miles before it drops below full then 60 miles full to half ..I don't trust the gauges
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Previous owner may have had the habit of topping off at every fill. Do this enough times and the charcoal canister in the evaporative emission system can get clogged. Had this on a Camry...$475!! Should be no charge fix on a certified car.
  8. bisco
    49,811
    topping off is a bad idea, as lenjack says.^^^ i round up to the nickel and call it quits.
  9. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Why, receipt prints better ???
  10. bisco
    49,811
    good question. i just hate pennies.:cool:
    szgabor likes this.
  11. szgabor
    993
    175
    Oceanside NY
    What pennies ... haven't paid cash for gas for (ever) ?
  12. bisco
    49,811
    on my credit card bill. i know, whacky.:p
    Mendel Leisk and szgabor like this.
  13. HaminusMaximus
    Los Angeles
    Thanks for all the help guys, decided I'm taking it to the dealer, just waiting to get my Wifes Camry back from a recall job before taking my Prius to them.
    Beachbummm - I tried that on my last fillup, didn't help at all.
  14. Beachbummm
    1,160
    392
    then im out of ideas unless the rubber bladder inside the tank collapsed
  15. RRxing
    RRxing Senior Member
    2,521
    1,793
    NEPA
    No bladder on the Gen III...
  16. Beachbummm
    1,160
    392
    then that's not the problem
