2015 Prius v Aftermarket Sunroof
Discussion in 'Prius v Accessories and Modifications' started by AdamLD, Aug 28, 2015.
  1. AdamLD
    AdamLD Junior Member
    Seattle, Washington USA
    2015 Prius v wagon
    As part of the purchase of my Prius v Five, I got an aftermarket sunroof installed. It's a Webasto Hollandia 735 Comfort which cost about $1,500 including installation.
    The "comfort" model has one-touch (as opposed to keep-holding) open and close buttons, and automatically closes when the car is turned off. (You can override all automatic modes with a second button press.)
    It was installed by "Auto Trim Design" near Seattle, Wash., and it comes with a limited lifetime warranty, which requires yearly inspection and maintenance (the first three years of which are free).
    I'm pleased with the installation job and the operation of the sunroof, and I thought I'd mention it here for those looking for sunroof options. I've no affiliation with the manufacturer or the installer, just with my Prius. :)
    1_Closed_Side.jpg 2_OpenPosition_Side.jpg 3_Open_Front.jpg 4_VentilationPosition.jpg 5_Interior.jpg 6_Switch_Closeup.jpg
    CLUBGUY, RichardY and JAvendan like this.
  2. Air_Boss
    Air_Boss Senior Member
    3,917
    1,069
    New Yawk
    Nice! Engineering and fitting the frame to the complex curvature of the roof, not to mention trimming the roof, must be a challenge.
  3. RichardY
    RichardY Junior Member
    23
    El Monte, CA
    2014 Prius v wagon
    very nice!!!!
  4. Michael Leary
    Michael Leary Junior Member
    39
    22
    Kansas, U.S.
    If I didn't have the moon roof, Id get this. It looks perfect.
  5. E46Prius
    E46Prius Active Member
    314
    218
    Costa Mesa
    Looks good. Do they simply replace the headliner with a factory part? The headliner looks factory. How about drainage... how do they address that?
  6. AdamLD
    2015 Prius v wagon
    I didn't get to watch the installation process, so I don't know the answer to either question. The headliner seems the same, so I am guessing that they cut that hole smaller than the actual roof opening, and tucked the edges under the sunroof's rubber trim. As for the drainage, I'm being vigilant about looking for water ingress, but haven't found any after rains and car washes.
  7. Kona Kolohe
    Kona Kolohe Junior Member
    Lisle, Illinois
    2013 Prius v wagon
    Seriously thinking of getting the sunroof installed on my 2013 Prius V. How well has the sunroof held up over the last year?
  8. AdamLD
    2015 Prius v wagon
    It's been great; no mechanical problems or water ingress. In a couple of months it'll get its first annual inspection and maintenance; I'll post info on that.
    #8 AdamLD, Jun 26, 2016
  9. bisco
    49,002
    amazing what can be done for 1500 bucks. i'm not a sunroof guy, but that is beautiful craftsmanship. thanks for the update, all the best!(y)
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    That looks great, but I just can't get myself up for allowing somebody to cut a big hole in my roof.
    Several years back I looked into having a sunroof installed aftermarket on my Honda Fit. I went and talked to the installer. And that is really I think the key. The product isn't as important as who is installing it. You want a good quality product, but who is actually doing the work is I think more important. The components can be fine, but if it's installed badly, you'll have a world of problems.
    Anyway the guy was telling about how they would install the sunroof, and then he said "It's Chemically Bonded To The Roof".
    To which I reply, " You mean it's glued? ".
    He looked a little sheepish, then said Yes, glued.
    Well, I just can't talk myself into allowing someone to cut a hole in roof and glue in an insert.
    FBear likes this.
  11. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
  12. AdamLD
    2015 Prius v wagon
    I'm reporting back after one year. So far, no problems whatsoever; no mechanical issues, no water ingress issues. Today I brought the car to the place that installed it for the first of three free yearly inspections to maintain the warranty, and the sunroof received a clean bill of health.
    I learned that there are two drainage tubes, one driver's-side front and one driver's-side rear, and they go down their respective pillars to the wheel wells. Part of the inspection is making sure that those tubes haven't become blocked, or clearing them if they have.
    #12 AdamLD, Aug 23, 2016
  13. AdamLD
    2015 Prius v wagon
    Reporting back after the second year. The only problem I've had was a "click" that developed as the sunroof started its retraction sequence. The installer fixed that at the free inspection. No water problems at any time, and we had a record wet Seattle spring (followed by a record dry summer).
    black Sunshine and bisco like this.
  14. bisco
    49,002
    this should be a sticky.(y)
