2016 Hyundai Sonata Hybrid starts at US$26,825
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Jul 3, 2015.
  1. bisco
    49,018
    and catch up to the sonata in mpg's too!
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Hyundai Sonata PHEV Gets Up To 27 Miles Of Electric Range, According To EPA
    post comparing the Sonata PHEV to the Ford Fusion Energi and Honda Accord Plug-In Hybrid.
    #42 Sergiospl, Oct 5, 2015
    49,018
    how big is the trunk? how much does it cost?
  4. Sergiospl
    3,938
    1,351
    28
    No MSRP yet!
  5. bisco
    49,018
    thanks, looks decent, but you have to see it in person. it's easy to fudge cubic feet.
  6. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    If you do the math on the plugin version's 99 MPGe, 27 miles of range, and 9.8 kWh pack it implies they are squeezing the battery to provide a bit over 80% of its nominal capacity. The new Volt has a battery also made with LG Chem cells that is twice the size and gets 53 miles of range at 106 MPGe efficiency. The Volt is using 76% of its nominal battery capacity.
    As a general rule, smaller batteries need to use a smaller portion of their nominal capacity because they are likely to go through more full charging cycles and thus see more degradation of their ability to hold and release energy. I would guess that the Sonata and Volt are using similar chemistry and cell designs but they aren't exactly the same since 1/2 of the Volt's 18.4 kWh would be 9.2 kWh and the Sonata is getting 9.8 kWh from exactly half the number of cells used in the new Volt.
    One mystery is how the Sonata battery temperature is being managed. Is it liquid cooled like the Volt, air cooled like the Ford Energi or Prius Plugin, or passively cooled like the LEAF? I can't find any information about that in any of the review articles I've read or on Hyundai's website. Anyone know?
    #47 Jeff N, Oct 5, 2015
  8. bisco
    49,018
    no question a company that has cheated in the past can't be trusted. only time will tell. good luck to the alpha users. glad to see hyundai offering options though.
  9. Sergiospl
    3,938
    1,351
    28
    So, Hyundai has "Lifetime Hybrid Battery Warranty" to owner # 1 only, second owner: 10/100,000 miles
    America's Best Warranty
  10. dipper
    dipper Senior Member
    1,242
    252
    This is for none CARB states, right? They are not exempt for CARB rules of 10yr/150k miles.
  11. dipper
    1,242
    252
    Hyundai already volunteering to recall to check bad motors for the Sonata without NHTSA forcing them to. Maybe in wake of VW problem they are doing this?
  12. bisco
    49,018
    could be, and gm ignition switch scandal. many are taking a prophylactic approach.
  13. hill
    8,075
    ooop - you forgot another UBER low CD vehicle - & it's a crossover. Unbelievable;
    The Model X has a drag Coefficient of 0.24. I wouldn't have believed that was even possible for an SUV. : teslamotors
    But - is it a plugin with a large trunk?
    Segway'ing back to the OP - it blows me away that Hyundai's traction pack warranty is lifetime to the original owner. In reality I wonder how it works - for example - how can it have 100% capacity after 8 or 10 or 15 years.
    #53 hill, Oct 11, 2015
  14. Tideland Prius
    16,075
    Come on Hill, one step at at time :)
    It's the first full hybrid sedan with proper split folding rear seats. The 2016 Sonata now also has split folding rear seats. Up til now, hybrid sedans had fixed seat backs except for the Camry Hybrid with a passenger side slit for skis/snowboards or similar equipment or the Malibu BAS "hybrid" which didn't have a big enough battery to impede trunk pass through in the first place.
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Don't you mean the first hybrid sedan rather than the first hybrid?
    Tideland Prius likes this.
  16. hill
    8,075
    I'm still waiting to figure out how that lifetime warranty works with Hyundai's plugin. Oh yeah, and I'm waiting for the first Lexus plug in .... big trunk or not.
    I'd rather be saying "you go Lexus" , but I guess I'm stuck having to say "you go Hyundai" .
  17. austingreen
    13,533
    4,063
    Austin, TX, USA
    They will repair or replace the battery pack as long as you own the car. When you sell it reverts to 10 years (100,000 mile in non carb, 150,000 miles in carb states). Pretty simple. Hyundai thinks their battery will last over 300,000 miles, and by the time it fails the car won't be on the original owner. If they replace a lot at 300,000 miles its great marketing for internet ads, so they can't really lose unless the battries last less than 200,000 miles.
  18. Tideland Prius
    16,075
    Yes. Dang it! I was careful to write out "first full hybrid" but I still miss something. Thanks, I'll edit it!
  19. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    My sister bought the 2016 base SE model a few weeks ago. Sales must not be stellar because they're already discounting the current model year. It's a very roomy, comfortable car. When I looked under the hood I was a little disappointed to see a serpentine belt drive some of the auxiliary loads. However, it looks like it's fairly easy to access things. There's room to work and the hood is supported with hydraulic lifts which is cool. Strangely, the back seat does not fold down on the SE model which hurts its utility. My sister regularly gets in the low 50s around town just by being light on the throttle. I don't know what she gets on the road. I drove it for a few miles around town and I would not say that she carries her 3500 lbs well. It reminded me of the domestic boatmobiles of yesteryear. Between the funky hybrid throttle and funky hybrid brakes and the numb electric power steering, I didn't enjoy it's handling. I suppose you could get used to it, but I had an epiphany when I got back in my own aging Acura RSX--don't ever buy any car that weighs more than 2800lbs.
  20. bisco
    49,018
    i guess the 50 mpg is the most important thing, especially for hyundai.
