2016 Prius 20% improvement in MPG?
Discussion in 'Gen 4 Prius Main Forum' started by iplug, Sep 10, 2015.
  1. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The base charges are a pain but make sense to help cover making the infrastructure available to deliver electricity to you whenever you want. That cost is still there to the provider even if you use none.
  2. Mendel Leisk
    41,463
    Yeah, I think they're a mix. The descriptions are anything but informative. And "regional transit levy", that sounds like "we have a captive audience we can ding with impunity".
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    What many people don't realize is that that is about half of the cost to utilities of delivering electricity to your house. It includes the distribution network as well as the ancillary services needed to keep the grid working. The cost of the electricity itself is usually half or even less than half of the total cost at a residential meter.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Both my electricity and natural gas are like that. My home is energy efficient. Actual gas charge year-round average is about $20 per month. But the bill averages $100. Ditto for electricity. If you don't pay for the infrastructure you can end up like some utilities in the US. They are in big trouble with crumbling infrastructure.
    I have no use for the 400 Watt "block heater". I didn't see any benefit on Pearl. In Alberta, you HAVE to buy it. But Pearl S, purchased in Alberta, came from Courtney B.C. I asked the dealer to not put in the block heater. They complied. Saved $150 on something I would never use.
    A -proper- block heater is an immersion type, rated in the 700-1000 Watt range. The one Toyota supplies has problems with overheating. Not interested!
  5. Mendel Leisk
    41,463
    There seems to be an inverse relation between climate and interest in the block heater, lol. Doug (ex member here) was from Alberta, same mind-set.
    I've had a Honda block heater on more than one occasion. They're immersed in the coolant. All were 400 watt. Didn't skip a beat going to the Prius style, which (as you say) is not immersed, just adjacent to the coolant mass.
    So far no overheating problems, and if it's not happening with our usage, don't know what it'd take.
  6. Trollbait
    12,542
    But you are using a timer. The issue may arise with those that plug the car in as soon as they get home, and leave it on all night.
  7. Mendel Leisk
    41,463
    That's happened inadvertently, once. It was ok, but it had me worried. The coolant temp stabilizes, but I'm concerned the wiring or plug may be problematic. Especially if you do it repeatedly.
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    a short answer;
    It is not 50kg difference, but 110kg.
    a long answer;
    The JP JC08 testing load of the dynamometer is not linear.
    The 1360kg load is applied to a vehicle between 1196kg and 1310kg.
    The 1470kg load is applied to a vehicle between 1311kg and 1420kg.
    Therefore, the load is increased 110kg even the vehicle weight is 1311kg.
    Ken@Japan
    pakitt, giora, Grus and 2 others like this.
  9. Tideland Prius
    16,559
    Welcome back!!
    ken1784 likes this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Shouldn't 1360kg load be applied to a vehicle between 1311kg and 1420kg?
    1470kg load between 1420kg and 1530kg(?).
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    A nice point!
    You're right those numbers look strange, but they are correct.
    The testing weight has another 110kg for two passengers.
    Another words...
    The 1360kg load is applied to the testing weight between 1306kg and 1420kg.
    The 1470kg load is applied to the testing weight between 1421kg and 1530kg.
    The next load category is...
    The 1590kg load is applied to a vehicle between 1421kg and 1530kg.
    The 1590kg load is applied to the testing weight between 1531kg and 1640kg.
    source: http://www.mlit.go.jp/common/000163736.pdf#page=5 (Japanese only)
    edit add
    source: http://www.mlit.go.jp/jidosha/kijyun/saimokubetten/saibet_042_00.pdf#page=2 (Japanese only)
    Ken@Japan
    #111 ken1784, Sep 26, 2015
