2016 Prius open questions
Discussion in 'Gen 4 Prius Main Forum' started by civicdriver06, Nov 22, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    ...well Gen3 has the smaller button battery CR1632 vs. the bigger CR2032 in the Gen2 fob. Just a couple days ago I was posting I don't know how the smaller battery lasts so long. so maybe the power is weaker.
  2. Tideland Prius
    16,081
    In the Gen 4 manual, it says the battery in the fob has a life expectancy of 1 to 2 years so it looks like they've kept the smaller battery. The Gen 2 battery lasts longer than my Gen 3 (which starting to get weak again).
  3. Trollbait
    11,368
    It is just a question of power to the antenna in the fob, balanced against battery life. GM's have the longer range only in the ones for cars with factory remote start.
    49,078
    why the bigger fob if the battery is small?
  5. Trollbait
    11,368
    Style? More buttons?
    Another thing to consider is that the fob likely doesn't have a separate broadcasting system for the SKS from the rest of what you can do with it. So a long range can have the fob and car constantly pining each other, while you are home, draining the battery of both.
  6. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Well, it's one or the other, but not both.
    2 cm is just shy of .8 inches, not .2 inches (an inch is not 10 cm folks!).
  7. bisco
    49,078
    thanks. i think i meant 'is the answer', not 'isn't.' :oops:but i can hardly remember yesterday, never mind what i meant on 11/23/15.:p either way, it's .2" or about 5mm, according to kgall in post #35.
  8. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Ah, okay. I just saw the error in the table and searched to see if anyone else had commented on it. One way or other, civicdriver06 or the moderators should get that corrected. The difference would matter to anyone who cares if clearance fell by nearly an inch - especially since it didn't!
  9. bisco
    49,078
  10. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    My gen 3. has been noting me on the MFD that the battery of the key is weak the past half year !
    I got a new one now,but actually the key was still working perfectly.
    I own my gen. 3 now for 3 1/2 years so I call that a quite good battery life !
    The manual says that even if the key-battery is depleted you can start the Prius by holding the Toyota logo of the key towards the start button .
    Wonder how that works ?
  11. bisco
    49,078
    i replaced mine at 3 1/2 years also. i'd rather have a smaller fob than a smaller battery, but oh well.
  12. Tideland Prius
    16,081
    Fixed. Answered a couple more questions.
    Vike likes this.
  13. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Answering the above:
    The new screens are gorgeous and quite bright. I was test driving in various directions on a sunny New Mexico afternoon (and that's at least as bright as it sounds) and never saw them washed out, though I don't recall if that was strictly a matter of brightness or good cowling/inset.
    The moonroof cuts a bit into headroom in back, but not where it counts. To explain - there's a "bubble" in the headliner to accommodate the moonroof that ends well in front of where passengers' heads will be, back at the headrests, where the headliner is back to full height. I guess someone right at the limit might be able to brush the trailing edge of the lowered headliner if they sit bolt upright and lean forward, but I don't think that's a practical concern. I didn't measure to confirm, but it didn't seem to me the moonroof affects front seat headroom at all, and might actually slightly increase it when the shade's open.
    kgall likes this.
  14. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Is there rear HVAC in any edition of the 2016 Prius?
  15. Surferboy
    Surferboy Junior Member
    Los Angeles
    Agreed on the moonroof not cutting into headroom. The way the car slopes won't effect the rear headroom and the front headroom seems the same to me as without it. With the moonroof cover open feels even more spacious to me while driving and I'm 6'3".
  16. Tideland Prius
    16,081
    No rear A/C vents. (Heater ducts are standard in most North American spec cars)
  17. PeterKG
    PeterKG Member
    62
    79
    Playa Vista, CA
    Four Touring
    There is a setting in which you can set the A/C to focus on the front seats if no one is in the rear. Or you can set it to both front and back seats.
  18. krmcg
    2,592
    2,389
    Whittier, CA
    It provides focus for the "Driver-only"
  19. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Thank you kindly.
  20. Tideland Prius
    16,081
    You're welcome.
