30k Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kp sunil, Jan 9, 2013.
  1. kp sunil
    kp sunil New Member
    Hello
    so far I have been following the maintenance schedule by the book (which basically turns out to be only oil /filter changes and tire rotations). I am sitting at 36k/3.3 years on my 2010 Prius. When is the recommended transmission fluid changes and all that? My dealer is quoting $520 for a "30k" maintenance.
    Prius manual is very quiet on most of the fluids. It says only to inspect. This is quite unlike my MDX which spells out exactly at what interval the fluids need to be changed. What is the bare minimum required for this interval?
    Thanks
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Never let your dealer choose your service items, go by the warranty book.
    I would add the ATF change in the transaxle, it should be well under $150
    Check installation of driver’s floor mat
    Clean cabin air filter (solar power ventilation system only)
    Inspect and adjust all fluid levels
    Replace cabin air filter (except solar power ventilation system)
    Replace engine air filter
    Replace engine oil and oil filter
    Rotate tires
    Inspect the following:
    __ Automatic transmission fluid
    __ Ball joints and dust covers
    __ Brake lines and hoses
    __ Brake linings/drums and brake pads/discs
    __ Drive shaft boots
    __ Engine/Inverter coolant
    __ Exhaust pipes and mountings
    __ Front differential oil
    __ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    __ Fuel tank cap gasket
    __ Radiator, condenser and/or intercooler
    __ Steering gear box
    __ Steering linkage and boots
    Note: Driving in heavy traffic, on dirt roads or in urban, dusty or desert areas may
    shorten the life of the cabin air filter. Replacement may be needed if you notice reduced
    air flow from the air conditioner and heater or if the windows fog easily when you use
    the Fresh mode. Consult your dealer if any of these conditions occur.
    Additional Maintenance Items for Special Operating Conditions
    Driving on dirt roads or dusty roads:
    Tighten nuts and bolts on chassis and body
  3. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I've seen in the maintenance schedule and I see above an entry for "Front Differential Oil". Can someone please explain how that differs from the Transaxle fluid change and how to go about changing that oil? I see no entry in PC on a search for "differential". And the Haynes book I have doesn't explain that either. Thanks.
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    On a front wheel drive front engine vehicle, the differential is part of the transaxle, the "axle" part having the differntial in it.
    In a transaxle, the automatic transaxle fluid flows through the differntial gear case, as they are integrated into one.
    Only rear drive and four wheel drive vehicles haveing a mid mounted transmissions have a separate front (for four wheel drive) and a separate rear differential controlled by a four wheel drive transfer case.
  5. Yakoma
    470
    125
    sss
    Thanks, Mike...that's kinda what I figured so it seems curious that "Front Differential Oil" would be an item on the list. I guess even Toyota makes cut/paste errors.
  6. Mike500
    2,593
    767
    You're very welcome.
    In the days of rear wheel drives, most all differentials used 80w90 lubricant.
    I recall how that stuff would smell to high heaven.
  7. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    Add brake fluid flush and brake service (inspect, clean, lube and adjust) to your every 30K.
    The Critic likes this.
