32 MPG average on the last 10 000km
Discussion in 'Gen 2 Prius Fuel Economy' started by morglum, Dec 26, 2014.
  1. bisco
    49,003
    the only way to know is to charge it and see if it maintains.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    12V is OK, but do give it a charge if you can, just to be sure. The rear toe in can't be adjusted except through the use of special shims, and is a bit of work. I don't know how much mpg improvement to expect if those toe ins (the major area of concern, front is probably OK), are reduced, but given your accelerated tire wear, I would pursue it further.
    #22 nh7o, Jan 6, 2015
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Excessively large toe-in at the front makes your car track straight and feel more stable on the highway, but causes accelerated tire wear and decreases the gas mileage. Good you had that corrected .
    - Alex
  4. morglum
    morglum Junior Member
    45
    gatineau,qc
    just noticed these emails - thanks everyone for the tips.
    MPG has been going crazy: I'm at 8.6L/100 km / 27 MPG since I did the repairs 3 weeks ago (700-800 km ?)
  5. Patrick Wong
    18,200
    6,464
    Another member recently posted that his front brake calipers were binding on the discs, which was the cause of his poor fuel economy. I suggest you raise up the front end of the car and make sure you can rotate the front tires by hand. If not, that might be part of your car's problem.
    Even if the car is IG-OFF and the gear selector is in P, you should be able to rotate the tires. As you rotate one tire in one direction, the other tire will rotate in the opposite direction.
  6. morglum
    45
    gatineau,qc
    good call, I'll try jacking the car when the weather is better.
  7. wrothgar
    wrothgar Junior Member
    77
    16
    oakville, ontario
    don't know if I missed this early in your thread, but isn't Gatineau pretty hilly?
  8. daniel boro
    daniel boro Junior Member
    israel afula
    in my car (second hand 2008) at 110 KPH i get ~6.5 l/100Km
    for a 450Km drive at 120 KPH i think 6.5 is not a bad number
    #28 daniel boro, Mar 25, 2015
