37 MPG?? 2012 Prius C--Three
Discussion in 'Prius c Fuel Economy' started by VCsPriusC, Sep 22, 2015.
  1. VCsPriusC
    VCsPriusC Junior Member
    16
    Los Angeles
    Hello!! I purchased a 2012 Prius C--Three two months ago. The car had 24,800 miles on it when purchased and now has 27,000 (so I've added 2200 miles in 2 months). This car was spotless and well taken care of in terms of the previous owners taking it in as scheduled for servicing. Why am I only getting 37 mpg on average in Los Angeles city driving?? I'm so bummed...
    I commute to and from work in downtown L.A. on the 110 freeway during rush hour traffic. During the day, I also drive around on city streets and the freeway to appointments at least once and sometimes three times per day. I drive to and from Long Beach once per week. My tires are inflated properly, I do use low flow AC always, and I've just in the past week learned about gliding and pulsing--but still getting the hang of it. I just filled up and got 40 mpg this last go around, which is my best so far.
    What am I doing wrong? Did I buy a lemon? How much more can my MPG improve if I work at it (while still using AC)? I thought I did my research and expected much better mileage than I'm getting and didn't expect to have to jump through hoops to get optimal MPG. I do love my Prius C...but had been considering a Nissan Leaf--which probably wouldn't have been a good idea with the kind of driving I need to do for work.
    Any advice would be appreciated!!
    49,058
    welcome! this is a tough one. with node dash lights or codes, it's hard to think what could be wrong. have you taken it to a dealer for examination? i think you should be getting 50.
  3. VCsPriusC
    16
    Los Angeles
    Thanks so much, bisco, for the welcome and the suggestion of taking the car in to get checked!! I plan on doing that soon but figured I should at least get some possibilities to bring up to the dealer/maintenance folks. I don't want to get a song and dance about city driving and how it's the way I drive. I'm not a haphazard driver and really want to learn how to take care of this car in anticipation for the day I can go fully electric. It seems unlikely I could make enough driving adjustments that would increase my current MPG to 50--which would be ideal!!--since road conditions are what they are and remain pretty consistent from one day to the next here in L.A. But, I'm willing to try anything and did see on this forum that YouTube has videos on how to optimize driving a Prius. That's so cool!!
  4. vskid3
    vskid3 Active Member
    773
    228
    How does it do on the trips that aren't in rush hour traffic? While hybrids do better than other cars in heavy traffic, you'll still likely see a mileage hit, especially if you're using AC.
  5. VCsPriusC
    16
    Los Angeles
    vskid3! Thanks for the help! I do get better mileage while driving in regular/off-peak hours around the city, but the best I've ever noticed is maybe 47 mpg...I feel happy when I see 42-43 onscreen. My worst Fuelly mpg calculated after one particular fuel-up was 32. A person should be able to use AC on low when driving...I think the advertised mpg should be adjusted to reflect normal driving conditions.
    Still, others on this forum seem to do pretty well with their cars and hitting the normal or even better-than-normal range. I don't know...I suppose I'm also disappointed because I feel like I made a practical decision in buying a Prius for its great gas mileage and proven reliability. I really wanted to go all-electric with the Nissan Leaf but Leaf batteries can degrade rapidly on even a 2013 pre-owned vehicle, so a 20 minute quick-charge is time consuming if in a rush to get somewhere provided there's even a charging station around. My thinking now is if I have to suffer without AC for the sake of saving energy and range, I'd rather be doing it in an EV. A Prius plug-in is pretty much impossible to find used and is still pricey.
    I got a great deal on my Prius C and will work on getting better mileage. I'm going to check out YouTube tonight. Any other possibilities besides using too much AC?
  6. skayaks
    skayaks Active Member
    123
    106
    Massachusetts
    Hi and welcome VCsPriusC,
    Perhaps you are already using ECO mode, but the most efficient use of AC occurs in ECO mode with the HVAC control set to Auto.
    With the temp set to 76F I find very little effect on my mileage (but I'm in chilly Massachusetts).
    If you haven't tried ECO mode yet it may take some time to adjust as it will feel like there's less power on tap, but that's just because it remaps the throttle setting. It makes no difference in performance when you ask for full power by flooring it.
    You mention proper tire inflation - is that per the door sticker? Many here run much higher inflation - up to the maximum recommended on the tire sidewall. That may not work for you if you find the ride too rough. You might try 42 psi front, 40 psi rear and see if that is acceptable. (I use 52/50 in the summer but I'm a nutcase.)
    Perhaps most importantly, your pulsing and gliding will improve with practice and make a huge difference - in light traffic. If you seldom see light traffic you'll need to work with what you've got: getting off the gas a little sooner to roll up to stop lights, try leaving a larger gap in front of you to reduce braking or allow gentle braking that includes more regen.
    Most of these techniques aren't limited to a Prius. If you have an Electric vehicle some day your new-found driving skills should help increase your EV range.
  7. DKTVAV
    DKTVAV Active Member
    510
    101
    Something might be wrong with yours, my 12 with two people plus camping gears up to Big Bear at over 7,000 ft still get more than 40 MPG easily every year.
    Is there anything blocking the battery vent under rear seat behind the driver?
  8. VCsPriusC
    16
    Los Angeles
    Hey, skayaks!!
    Thanks for the suggestions. I'm almost always in ECO mode. My AC is set to Auto, but I like it cool...70 most of the time. I'm really going to try the techniques I've been reading about here and elsewhere. It couldn't hurt, right? Plus it's good to learn these things if it helps with range. I just bought a digital tire gauge (because I needed a new gadget) and saw that the digital reading has me at 45 psi all around, whereas my regular stick gauge shows 42. I'll make adjustments as suggested on the front and rear tires but figure the thing that will increase my mpg will be my driving technique, especially braking and accelerating. I read an old post on the other Prius forum that mentions taking advantage of cruise control can also help if done as suggested...
  9. VCsPriusC
    16
    Los Angeles
    Thanks, DKTVAV! 40 MPG with a full load going to Big Bear?? I'm so jealous! I'm going to look at the battery vent under the rear seat. Based on what I've been reading over the past couple of days, it seems like making even small changes to my driving style to accommodate the Prius could make a bigger difference in mpg than I originally thought.
    I feel like I've got a bit more understanding for when I have the car checked at the dealership, but I can tell I'm going to be on a mission now to get the highest MPG possible. I feel like it's my right to get super great mileage stats with this car because I spent so much time agonizing over buying a Hybrid vs. an EV. Thanks again for the suggestion! I sure hope there's nothing wrong with the car...
  10. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    The first two and easy to check suspects for low mileage are tire pressures and the condition of you 12 volt battery, after that the dealer is your best bet. II drove my Prius lift back a2011 2 without regard to mileage and averaged 44 mpg over 30k miles.
  11. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    You always have to hold up your end of the bargain in order to optimize MPG. If you accelerate and brake hard and drive at high speeds on the freeways then you'll never see as good fuel economy as someone else who accelerates gently, brakes gently ahead of time so as to avoid having to come to a complete stop, and avoids the excessive speeds that drag down fuel efficiency.
    The issue isn't so much whether 37MPG is "good" or not, it's whether or not it's better than some other car that you'd drive the same way.
    CR94 likes this.
  12. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    I purchased my 2015 Prius C 2 weeks ago in Florida. While driving in Florida on the Interstate I was getting 38.1 mpg on Florida gas. After I got to central Ga and filled up, I started noticing the mpg going up and driving on I-75 thru Nothern Ga and Tennessee. By the time I got to Knoxville, I was getting 46-47mpg. It could just be the gas you are using; I am not familiar with California...
  13. Habnar
    Habnar Junior Member
    43
    Oakley, CA
    2019 Prius Prime
    Short trips will kill your mileage as the engine has to run to warm up. Cold weather will kill your mileage even more. When you are on surface streets make gradual starts and when you get up to about 35 mph let off the gas pedal to go into ev mode then gradually ease in some throttle to maintain speed in ev mode. Watch the green flow bar on the HSI display. If the battery starts getting low, run the engine but, keep the green flow bar as close to the middle or lower as you can. Always try to maintain speed using as little throttle input as you can. If you have a full battery and you are going downhill, lift off the gas pedal and then gently push on it until the flow bar disappears. You are not charging or discharging. This will allow you to coast farther and if you are slow enough to be in ev mode you will really boost the mpg! Don't try to start off in ev mode, that is what the engine is for and coast (foot off of pedal to charge) as long as possible when you have to stop. All of this becomes second nature after awhile and you find yourself trying to do it while driving other cars. Of course, if you are driving in traffic, then you have to go with the flow. That usually kills your mileage too.
  14. VCsPriusC
    16
    Los Angeles
    Haven't logged in for quite a while! Thanks for the tips, Munpot 42. I find that following people's suggestions helped me increase the MPG but not by as much as I had hoped. The best mileage I've gotten thus far at 30,000 miles is 46 mpg. I really have to be conscientious about my driving to get up to the higher end of the scale mileage-wise...which in the long run is a good thing. Also stopped using AC in the heat and rolled down the windows...which I actually got used to comfort-wise.
    I've come across other Prius C owners in L.A. and found that their overall MPG isn't as great as they had hoped either. I think it's an L.A. thing. Taking the car to the dealership for servicing was a hoot--actually, it wasn't a hoot--but I feel it gave me a great baseline from which to start wherein I believe every possible problem was looked at and taken care of even if it didn't need taking care of. Now, I'm keeping records and optimizing driving and still improving on MPG. Ultimately, I love this car!!
  15. VCsPriusC
    16
    Los Angeles
    Sean!
    Yeah, I hear you on this fact when it comes to optimizing MPG. There have been days when I've been on the road and thinking about work or what have you only to realize I'm not being very conscious about my driving...and it's reflected on my dashboard. I'm not hard on my car but certainly drive "better" when I'm thinking about it how my driving and certain traffic conditions affect my MPG and desire not to waste gas or $$. Plus, concentrating on driving techniques actually becomes more of a meditative experience and helps relieve stress from work...if that makes any sense. Thanks for the input!! --V.C.
  16. VCsPriusC
    16
    Los Angeles
    Hey, davidc83! Congrats on your purchase...hope it's going really well for you! When I buy Shell gasoline, my car seems to get better mileage, so I've been buying Shell. I believe there's some additive in Shell but previously never payed attention to the chemical composition of different gasoline sources from one fill-up to the next. Your point is an interesting one which I came across online recently. That was what made me notice the difference with Shell despite using the same octane of all the brands I would buy.
  17. VCsPriusC
    16
    Los Angeles
    Happy Holidays, Habnar! Your tips will certainly be used...I've been doing better with my Prius since watching YouTube and paying attention to my driving habits. I noticed the other day that when I tried to switch to actual EV mode, a message came up on the screen that says my acceleration is too high to switch to EV mode via the button. I used to be able to switch to EV mode before. but I pretty much drive consistently with Eco mode turned on and spend as much time driving in the EV range on the monitor. I have to look into the EV mode button which I usually don't touch. Maybe I just forgot how to do it...Thanks a lot for the in-depth tips!
    Take care all!!
    V.C.
  18. Dinesh Jayasinghe
    Dinesh Jayasinghe New Member
    Colombo
    Full EV mode disables automatically when you reach 60 KM/h or above.
  19. Sean Nelson
    421
    182
    How fast you can go in EV mode depends partly on the speed and partly on how much power is needed to maintain it. I've been able to stay in EV mode in my 2012 Prius C up to 74 km/h in situations where I didn't have to apply more throttle than the "EV limit" mark on the information display. Those are pretty uncommon situations, though.
  20. Dinesh Jayasinghe
    Colombo
    What I meant by EV mode is through selecting the car to be on EV mode all the time. There is a button where you can enable it when the battery is at least half full. The normal EV mode can be used in speeds of up to 70 km/h. I have done this several times, cruise within the eco segment and you can utilize this.
