For Sale 400 watt Pure Sine Power Inverter - Use Prius as a generator!
Discussion in 'Private Sales' started by mediahound, Feb 3, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I have a Wagan EL2601 400w Pure Sine Power Inverter for sale. It's 100% like new and includes both a cigarette lighter plug as well as battery terminal plugs. This unit has 2 AC power jackets as well as USB jacks to charge your iPhone/iPad.
    This can be used very effectively to use your Prius as a generator when your power is out, and to charge up your laptop while you are on the road, in addition to your iphone, gameboy, etc.
    It's this one: Wagan EL2601 Elite 400W Pro Pure Sine Inverter : Amazon.com : Automotive
    Two 120 Volt AC outlets plus a 2.1 amps USB power port (compatible with iPad/tablets and Kindle/e-readers)
    Provides 400 Watts continuous power and 800 Watts peak surge power
    Built in mounting brackets
    Run your home appliances from your vehicle
    asking $80. + shipping, or you can pick it up if you are local (SF Bay Area).
  2. tf4624
    tf4624 Active Member
    526
    51
    not bad.. i like the "battery charging" jail broken mod.. but i think if im going to have ac in my car.. needs at least 700watts
  3. mediahound
    903
    155
    Still available.
  4. tf4624
    526
    51
    that "battery charging" picture.. what theme is that from on your Ipad?
  5. mediahound
    903
    155
