4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. Mendel Leisk
    38,269
    3rd gen EGR is prone to build-up. Hope they address that.
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    ALL EGR systems are prone to build-up. It's simply a service item.
  3. Trollbait
    11,333
    True, but some are worse than others.
    I can imagine a cooled EGR having a quicker build up of deposits than the traditional type. Dropping the gas temperatures could lead to more solids coming out of solution.
  4. Mendel Leisk
    38,269
    Well, it's an arduous, undocumented maintenance item. Everything from the exhaust manifold, through the EGR and the intake manifold is prone to tarry build- up.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    If 7% more exhaust gas is recycled, the warm up time should be shorter too, as more exhaust heat recovery is possible.
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  7. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Just curious:
    I have not measured the 2015 Prius v, but might the "pouty lips" add about 6" to the otherwise same size predecessor? Visually, they do.
  8. bisco
    49,010
    what is this build up you speak of? my '04 has 135,000 miles or so, with no ill effects.
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    It's a tar-like 'coke' accumulation that gradually builds up inside the EGR system...unseen...until its presence chokes proper EGR operation off.
  10. bisco
    49,010
    thanks, what causes it, and when does it typically become an issue?
  11. Trollbait
    11,333
    It's basically the ash from the fuel. The same stuff that turns the inside of the tailpipe black.
  12. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    All the more reason to own a PiP! ;)
  13. Sergiospl
    3,938
    1,351
    28
  14. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Does the dealer bend you over with or without lube at the time of purchase?
  15. bisco
    49,010
    is it worse in some parts of the country?
  16. Trollbait
    11,333
    I don't think there is enough difference in gasoline formulations. Perhaps, ethanol produces less?
  17. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    The ethanol dissolves the buildup. Higher percentage ethanol in your gas the less buildup will remain.
    I use 100% gas almost exclusively but I do run some ethanol laced gas a few times a year to remove buildup.
    How often I need to do it I don't know but since it is similar in cost per mile it isn't a big loss for me to do it too often.
    Check out puregas.org for stations near you that have 100% gas with no ethanol then compare gas prices vs the 5% or 10% or whatever% ethanol in your area. Figure you'll lose gas mileage at about the percentage of ethanol in a Prius (10 % ethanol might drop your mileage by 15% at most, likely will be less). So if the gas prices are $2.20 for 10% ethanol or $2.40 for 100% gas I'd get either gas because it is about a 9% price difference, If the comparison is $3.30 for 10% ethanol vs $3.50 for 100% gas I get the 100% gas because it is about a 6% price difference. The bigger the price difference the more it makes sense to use the ethanol, the less price difference the more it makes sense to use pure gas.
  18. bisco
    49,010
    just doesn't seem to be much of an issue in the first one or two hundred thousand miles. am i wrong?
  19. dhanson865
    851
    188
    TN, USA
    I'm not an expert on EGR but general knowledge leads me to this path of thought:
    Engine temp / Catalytic temp affect how full / complete the combustion is. The lower the temp of combustion the more particulates left behind to cause the buildup.
    Thus short trips and/or cold environment will increase buildup. Long drives / hot environment will help prevent it (but not remove existing build up).
    OK here is a blurb to back that up
    Thus the change in engine design was to reduce smog at the expense of increasing carbon build up inside the engine. If the fuel combusted completely there would be less solids / more gases but the gases are toxic so they made the adjustment.
    I'm not sure how accurate the changing the oil part is. I'm just quoting it for the temperature of combustion line of thought.
    So back to your question on hundreds of thousands of miles. It might happen to one driver in 40,000 miles and it might happen to another driver in 300,000 miles. Just depends on temps vs miles.
    Though since the Prius is very adamant about running the gas engine to warm up the catalytic converter ASAP maybe the Prius just won't be very susceptible to this as a major issue at any number of miles?
    Reading back up thread someone said Gen 3 was more susceptible than Gen 2. I wonder how much more if any?
    #4639 dhanson865, May 24, 2015
  20. bisco
    49,010
    when you see people reporting that they pull over and shut down the car and restart to spoof the warmup, i suppose there could be any number of whacky things happening.
Thread Status:
