5.5" rim size when 195/60/15 calls for 6" rim?
Discussion in 'Gen 2 Prius Main Forum' started by kryztuh, Jun 2, 2010.
  1. kryztuh
    kryztuh New Member
    East Coast
    So I've spent a crazy amount of time reading threads and trying to make the best tire choice to replace the Integritys, being a complete tire novice.
    I thought I was good choosing the 195/60/15 HydroEdges. I went to Sam's club and they gave me huge hassles and refused to install the tires.
    So here I am re-reading threads and doing tire size calculators and I have one last question I haven't resolved.
    My 2006 Prius has 5.5" rims. The 195/60/15 tires call for 6" rims. This isn't a problem?
    Thanks in advance.
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I have hydroedges in the stock 185/65/15 size on my 07 and they work fine. Why not just use the original size and be done with it?
  3. Patrick Wong
    18,199
    6,464
    As-is, the Prius tends to show greater tire wear on the shoulders compared to the center of the tread. If you use narrower wheels then recommended, this actually might help the uneven treadwear, as the narrow wheels would tend to push the center of the tread out compared to the shoulders.
    Most tire shops will not be eager to install non-standard tire sizes due to liability concerns. If you choose to use a non-standard size and can find a tire store that will help you, don't be surprised if you are asked to sign a waiver that shows you accept liability for any problems that may result.
  4. kryztuh
    kryztuh New Member
    East Coast
    I have read in this thread (although I did not go through all 46 pages, I did read quite a bit of it), and many other threads that the 195/60/15s were preferred.
    I didn't see the rim size addressed, but I will re-read and find out if maybe drivers who upsized really have a 6" rim and not a 5.5"...
  5. kryztuh
    kryztuh New Member
    East Coast
    Thanks.
  6. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I have 195/60/15 TripleTreds on the stock 2004 rims, and they're great. No problems at all, and no waiver, though the first shop did try to talk me out of it. I'm very glad I didn't listen to them.
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    In that Tire Upgrade thread you linked, nyprius says the 15" wheels have a 6" wide rim.
    Where did you get the info that the wheels were 5.5" wide?
    In any event, I've had 195/60R15 Goodyear Assurance TripleTreds on my Prius since 2007 and haven't noticed any issues. In fact, everything seems great.
  8. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Both Costco and Sam's Club will not mount any tire that is not the same size and speed rating as specified in the owner's manual. They changed the policy around 97-98, before that I have no problem mounting any size tire on my cars.
    You are trying to mount a wider tire than the OEM tire, so they give you the run around about the rim size, the 195/60/15 can be mounted on rims from 5.5" to 7".
  9. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    195/60 tires fit the stock 15 inch wheels just fine. The rims look like they were made for 195 tires.
    I just took some rough measurements. The stock wheels on my '06 appear to be at least 6" at the bead seat. It also looks like they are the same width as the wheels that are on the base 2010 model, which comes from the factory with 195/65 tires. I was able to directly compare the two.
    Just find somewhere else to have them mounted. I used Discount Tire and had no issues with them installing the wider tires.
    The 195/60 is only about 13mm wider (at the tread) than the 185/65. It's not like you're trying to put seriously over-sized tires on the car. More like the car came with under-sized tires.
  10. Boo
    5,051
    483
    97
    Flushing, NY
    Yup.
    And I just checked my Gen II 2007 Prius Owner's Manual -- it says that the rim width is 6".
  11. sktn77a
    sktn77a Member
    294
    NC
    I've had 205/60R15 Potenzas on my 2005 for 3 years with no problems in terms of fitment but I did take a hit on ride quality and mileage.
  12. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Here in Australia 195/60/15 is the recommended tire size! (as per the owners manual)
  13. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    If you go to Tire Rack and get your tires, you can get the size and rating you want and use one of their authorized installers in your area, most of them will install what you want. Sam's , Walmart and the bigger chains won't put anything but the size AND rating specified in their book. I have an '08 Camry Hybrid w/16in wheels. This is a HYBRID now..... It is rated for a V rated tire.... 140 miles and hour rating. Am I ever going to go 140...NO! V rateds are softer and have less mileage warranty. Sam's had the right size in stock but lower rating...no go. For mine it would have been $180 more for the set, installed. My installer said the same "Are you gonna drive that 140mph?" He said to get what I wanted and he would install. I could go 2 rating lower an dit would work just fine. Instead of a V rating and 4yr/50k warranty, I got T rating and 5yr/75k warranty. It is not a sports car, I don't need that soft and sticky a tire, I want long mileage
