800 mile per tank challenge
Discussion in 'Gen 4 Prius Fuel Economy' started by cproaudio, Jan 28, 2016.
  1. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I am no expert, but from what I understand, Octane has nothing to do with energy content. There should be no difference between 87 octane and 92 octane. The 92 octane can support much higher compression ratios however.
  2. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    That's absoluely correct, however, one way to add octane is to add higher energy aromatics. So you could have better energy ...just not guaranteed.
  3. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    All righty then. How do I get my hands on some high quality aromatics? Sounds like they should be illegal.:p
  4. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Pretty expensive these days I thought about fiddling but expensive. Toluene/Xylene typical. I think STP.
    92 octane E0 is the best shot at it
    #24 wjtracy, Feb 26, 2016
  5. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Yesterday I posted my first tank on Fuelly. Then I looked under 2016 Priuss and didn't see my entry listed. I went back today and got the same result. Then I read the comment above the distribution chart:
    "Below you can see a distribution of the fuel-ups with 1 outliers (5.88%) removed."
    So now I am an outlier! I can understand the need to do that after only one tank, but maybe after a few tanks Fuelly will take me seriously.
  6. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    Tell them and point out your total mileage. If it was a 100 mile fillup that could be explained by a pump difference, but a full tank is an entirely different story.
  7. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Statistic maniacs. I've seen that a couple of years ago with Spritmonitor rejecting a tank of 1.5l/100km with a Prius PHV. It has changed since, because of complaints.
  8. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...bummer!
  9. bwilson4web
    16,195
    Patience my friend. The grinding of bureaucracy is slow but inevitable.
    krmcg likes this.
  10. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Indicated:
    873.4 miles indicated/11.438 gallons pumped = 76.36MPG
    81.8/76.36 = 7.1% error (Not corrected for Odometer error)
    Corrected (with Odometer error of -1.9% (measured via google maps on 3 occasions):
    873.4*1.019 = 890.0 actual miles/11.438 gallons pumped = 77.81 MPG Corrected
    81.8/77.81 = 5.1% total error.
    Fuel warning came on at 794 miles.
    Range went to zero at 844 miles.
    Driving time was 25 hours and 45 minutes, 34.56 MPH average speed
    56% in EV mode. Spring has sprung in Raleigh.
    #30 krousdb, Mar 11, 2016
  11. cjecpa
    cjecpa Member
    160
    58
    Pretty amazing I would like to see what the highest miles for one tank is for nonstop highway trip. I drive 24 hours straight to Dallas every year.
  12. bwilson4web
    16,195
    The primary determinant is highway speed. We are getting enough information about the Prius that we may soon have an effective trip planner. From what we're seeing so far, take these numbers and add 10% to get a rough, rule of thumb . . . for now:
    So if your speed is say 80 mph, adding 10% would be:
    • 40 MPG * 1.10 ~= 44 MPG
    • 44 MPG * 11 gallons ~= 484 miles
    You'd be looking at about 500 miles without reserve.
  13. cjecpa
    cjecpa Member
    160
    58
    Thanks figuring 75mph which will be on some long stretches but overall average is closer to 63 mph so around 50 mpg so probably closer to 500 miles between fill ups. Figuring I am not going to let it get to the warning light. Still better then my 300 miles between fill ups.
  14. bwilson4web
    16,195
    Remember the car burns the gas so use its cruise speed which should always be higher than elapsed speed and even what shows up on a dash trip meter . . . unless you reset it upon reaching cruising speed.
    Now the Gen-4 may be too new to show up in rental fleets but I'm sure the Gen-3 is available. You might consider renting one long enough to find out if it works for you . . . knowing the Gen-4 is a much nicer ride (not that I have any direct experience, yet.)
    GOOD LUCK!
  15. cjecpa
    cjecpa Member
    160
    58
    Thanks. Looking for better gas mileage than my current vehicle. Once made the trip in a 2012 Honda Fit.
    bwilson4web likes this.
  16. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I will post details tomorrow.
    #36 krousdb, Apr 4, 2016
  17. fuzzy1
    10,409
    A 1000 mile tank already? That didn't take long. Summer hasn't even arrived yet.
  18. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Actually now is the best time to get highest miles per tank. Any later then it'll be too hard to achieve this kind of number due to using AC.
  19. fuzzy1
    10,409
    Maybe for you. With snow and slush on Stevens Pass today, and a winter traction tire advisory, our AC season is still a fair way off.
  20. vince22
    vince22 Active Member
    205
    249
    califorinia
