A/C condesation inside Prius
Discussion in 'Gen 3 Prius Main Forum' started by Jeff Parriott, Jul 14, 2013.
  1. Jeff Parriott
    Jeff Parriott New Member
    La Crosse, WI
    2011 Prius+ MPV
    I had water dripping out from the dashboard, running onto the floor of my Prius today, anyone every had this happen to them.
    I've drove this car with A/C on before and never noticed this problem, but this evening when returning home one of my floor mats actually had standing water on it when I removed it! YIKES
  2. El Dobro
    El Dobro A Member
    6,972
    3,209
    Sounds like the drain for the evaporator case is clogged.
  3. Jeff Parriott
    La Crosse, WI
    2011 Prius+ MPV
    Any idea how to get at the drain?
  4. El Dobro
    El Dobro A Member
    6,972
    3,209
    By ramps or a lift. More than likely, you'll have to find it from under the car, around the heater box.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Pull back the carpet from the top left corner on the passenger side floor, see if you find it there.
  6. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    If your car is under warranty bring it to the dealer
    Jeff Parriott likes this.
  7. Jeff Parriott
    La Crosse, WI
    2011 Prius+ MPV
    Nope, no longer under warranty
    JMD likes this.
