A/C Noise Problem
Discussion in 'Gen 2 Prius Technical Discussion' started by Caleb302105, May 27, 2015.
  1. Caleb302105
    Caleb302105 Junior Member
    29
    Bend, OR
    Hello,
    I first noticed a strange noise coming from the engine compartment a day ago. I had left the car to sit in the sun for a few hours. When I got in the A/C was set to on and the system was on auto. I tested to see if the noise went away when I turned off the A/C and it did. I turned it back on and it returned. I know the A/C operates at different speeds based upon cooling needs and that it can get sort of noisy but I didn't think that it could/should get this loud. The system seems to begin working quickly and it does seem to put out cold air. Is anyone else's A/C as loud as this one? If the noise is unusual do you think that it indicates another underlying problem in the A/C system?
    Just to clarify, the ICE is not running in the video. The cabin fan is set to low and the temperature is set to low. The person in the car presses the A/C button and the cooling fans in the engine compartment come on as well as the A/C unit.
    The sound gets louder a few seconds in.
    Here is the link to the recording I made of the sound.
    Thank you so much for your help.
    #1 Caleb302105, May 27, 2015
  2. JC91006
    16,470
    8,383
    I think my car makes that noise.
  3. Caleb302105
    29
    Bend, OR
    Are you able to hear it over the ICE when it's running?
  4. JC91006
    16,470
    8,383
    I can hear that sound really loud and clear on my 2010 too. I can't hear it much inside the car, outside the car, my 2010 is very loud
  5. ChapmanF
    15,110
    I'm not convinced the ICE is running in most of that vid. The water pump pulley looks stationary to me when you zoom in on it. That would mean the sounds are just compressor and fans....
    -Chap
  6. Caleb302105
    29
    Bend, OR
    You're right. The ICE is not running. I was meaning can JC91006 here his when it's running.
  7. Caleb302105
    29
    Bend, OR
    Does anyone think that this sound could be indicative of a problem with the unit?
    Thank you.
    #7 Caleb302105, May 27, 2015
  8. Patrick Wong
    18,199
    6,464
    Yes, the air conditioner compressor sounds quite loud.
    Look at the sight glass on the high pressure side of the system (this is near the windshield washer reservoir) while the AC compressor is running to make sure that you don't see bubbles. If there are no bubbles and the system is generating uncomfortably cold air when the cabin air temp is set to MAX COLD and the fan speed is on the fastest position, then it has sufficient refrigerant.
    In that case, I would not worry about the noise because the sound likely is caused by the compressor motor bearing clearances being a bit looser than normal. The only reasonable action that you could take is to replace the compressor. You'd might as well wait until the system has an actual failure - why incur a four-digit repair bill just for a noise.
    #8 Patrick Wong, May 28, 2015
  9. Caleb302105
    29
    Bend, OR
    Thank you so much for getting back to me. I really appreciate it. I wasn't sure if there was anything maintenance or fluid orientated that could be attended to in order to help it feel better :). One more question if you have time. When do we usually have to recharge these A/C systems or do we never have to unless there is a leak? Thanks again.
  10. Patrick Wong
    18,199
    6,464
    My 2004 has 196K miles and the refrigerant has never been recharged. There is no need to do that unless a leak develops, and then of course the leak first has to be identified and fixed before the system is recharged - for a permanent solution to the problem.
  11. Caleb302105
    29
    Bend, OR
    Okay, thanks again for the advice. I appreciate you spending the time to help me.
    Have a good evening. :)
    theshark likes this.
  12. Caleb302105
    29
    Bend, OR
    Thanks everybody for your input. I guess I won't worry about the sound and I'll just wait for the compressor to come to the end of its life. That solves that problem. :)
