A/C problem with no code
Discussion in 'Generation 1 Prius Discussion' started by Wisco, Jul 24, 2014.
  1. Wisco
    Wisco Member
    116
    Hi folks,
    It's getting hot here in Wisconsin, and the A/C in our 2002 is completely nonfunctional (and has been since we bought it a year ago). Unfortunately it also doesn't provide a diagnostic code to point me in the right direction. So yet again, I'm turning to you all for ideas on where to begin.
    When the A/C is turned on, the light begins flashing immediately, and the air is not cold. I've tried it while the engine is at high RPMs, and idling in the driveway with no change in results. When I put it in diagnostic mode there still aren't any codes (except the solar sensor if it is dark).
    If the ICE is off when I turn on the A/C, the ICE fires up briefly then shuts down.
    The mechanic we bought it from suspected the compressor. I hoped it was really the clutch (seems common), and that I could just put in shims to adjust the spacing.
    The only code I have gotten from it was for the cabin air intake servo motor shortly after we bought it. I found a mouse nest in the cabin air filter, which I figured was causing the problem. After replacing the filter the code went away but the A/C still wouldn't work.
    I'm wondering..
    Is there anything else I can do to trigger a DTC? Are there any specific problems that wouldn't have a DTC?
    Would a compressor/clutch problem certainly trigger a DTC? Can I test it when there is no functionality? (It seems more common to have intermittent trouble with that)
    If some of the mouse nest was sucked into the A/C system, could it cause this?
    Thanks for your time.
  2. Wisco
    Wisco Member
    116
    I did a little exploratory surgery today.
    The cabin air filter had a lot of debris stuck in it, so I brushed it off. There were some leaves that had gotten past the filter (perhaps from last time) so I expect some debris did get through. But the fan works fine, and the servo motor opens and closes the damper fine.
    I poked around the A/C clutch a bit. I watched it as the A/C was turned on and didn't see any movement. I did notice, however, that the outermost plate (the pressure plate?) appears bent. I'm still studying my clutch anatomy, so I'm not sure how much to make of that. The maximum gap between that plate and the pulley is over a millimeter, well beyond the .5mm specified by Toyota. I made a video of it spinning.. View My Video
    The clutch is my main suspect at the moment, but the lack of a DTC bothers me. From what I understand there is a code for when the compressor doesn't rotate at the expected speed when the clutch is engaged. I would expect that code if the compressor doesn't spin at all..
    I might try testing the clutch, first by checking that the magnet gets power when the A/C is turned on, and then by supplying 12v directly to it to see if the clutch engages (and if it engages with 12v and a push).
    #2 Wisco, Jul 24, 2014
    bwilson4web likes this.
  3. Wisco
    Wisco Member
    116
    The plot thickens..
    I popped off the connector to the A/C clutch and found that there isn't power applied to the clutch when the A/C is turned on. I checked it with two different multitesters, then pulled the wires out and checked again. There is a good conduction to ground, but no power.
    To me that means either the car tries to engage and can't (bad connection somewhere or a safety switch is opening the circuit), or some other sensor is indicating a problem somewhere else and the car doesn't try to engage the clutch.
    On top of that, the clutch is in rough shape. With 12v applied the pressure plate twitches but doesn't really engage. Even when I push by hand as well it only partially connects, and I can still spin it easily.
    I've resigned myself to replacing the clutch, and it's time for a new serpentine belt anyway. But I'm not confident that will resolve the problem.
    I'll try to find a wiring diagram.. I assume there is a freon low pressure switch, that might be my next stop. Though I would expect a code from that as well..
    Chime in if you have ideas, I'm stabbing in the dark here. :)
  4. ChapmanF
    15,105
    It might be worth getting the clutch shimmed to proper clearance to see what happens before you replace the whole thing. When I reshimmed mine it was pulling something like 1.3 mm, more than double (pushing triple!) what the clearance is supposed to be, and the magnetic field is weak at that distance. Twelve volts on the coil would only make the pressure plate sort of lean in on one side. It has not given me any trouble since I changed the shims.
    I'm not saying there's no way you could need total clutch replacement, but shimming's a much easier job to start with, and then you'll know.
    The whole wiring diagram manual ought to be on techinfo.toyota.com, as well as the shop manual which will have step-by-step tests and decision trees in volume 1. The relay powering the clutch is labeled CLR MG in the box up in the driver's side corner under the hood. You could check whether its coil terminals get power when you ask for A/C. You're probably on the right track looking at the pressure switches....
    -Chap
  5. Wisco
    Wisco Member
    116
    Thanks Chap,
    That relay gets power for about a second when the A/C is turned on. I tested the relay, it works fine.
    I got a 2 day subscription to techinfo.toyota.com, which has helped a lot. It had me check the compressor lock sensor. I read .25 ohms from pins 2 and 4, the spec is 160-320. The solution offered is replacing the compressor. Eek!
    I'm confused about 'compressor lock', and what that refers to. Step 1 (before checking the sensor) was 'Check if the compressor does not lock during operation..'. Is 'locking' the clutch engaging? Or the compressor locking up? Or is it just referring to when DTC 22 occurs?
    Thanks again.
  6. Wisco
    Wisco Member
    116
    And the dual pressure switch tested fine, so I'm scratching that off the list.
  7. ChapmanF
    15,105
    Looking in my manual (2001, could be slightly different) there's a discrepancy between vol 1 and vol 2 on the correct resistance for the lock sensor: 65 to 125 Ω on page DI-888, 160 to 320 Ω on page AC-37. Either way, 0.25 Ω is way out of range, so somehow your pickup coil is shorted (or the short section of wire from the connector on top of the compressor to the pickup itself, more on the bottom forward?).
    What they mean by 'locking' is the compressor sometimes seizing/slowing/failing to turn even with the belt turning and the clutch engaged. Ordinarily whenever it's turning, that sensor coil picks up pulses to confirm it's turning. If your pickup coil is shorted, the controller is never getting confirmation that the compressor turns, and when it thinks the compressor has locked, it releases the clutch after a second or so, which sounds kind of like what you're seeing.
    I'm curious what could make a sensor like that short ... it's not like much ever happens to it. Seems almost more likely to me that the wires from the sensor to the connector could have been damaged if there was ever a front-end collision or the like.
    Page AC-37 is written as if the lock sensor might be replaceable on its own without the whole compressor. The pictures certainly show it just bolted on.
    It isn't shown anywhere as a separately purchasable part - but then, if it's as easy to remove from your compressor as the picture makes it look, it's probably that easy to remove from a salvage compressor too. Even if you end up buying a whole salvage compressor to get one, you still save all the labor of changing the compressor itself, evacuating/recharging, etc. If you're lucky you might scrounge one off a compressor that's toast. If you can find collision damage (or whatever kind of damage) to the exposed wiring, you might be able to fix that without buying anything.
    ... unless the bore the sensor mounts in somehow connects to the internal passages and you lose the refrigerant by taking the sensor out. I really can't imagine they would build it that way, but it would be an annoying surprise.
    -Chap
  8. Wisco
    Wisco Member
    116
    Annoying surprise indeed. I pulled off the sensor and got blasted in the face with refrigerant! If anyone else is poking around in there, be aware: the compressor lock sensor is under pressure. I wore safety glasses all day, except when removing the one thing I knew could be under pressure. Sheesh. Fortunately after a good eye flushing, I think I'm fine.
    I don't think it vented out the system, but it may have (there go all my environmentalist credits). I could see the compressor shaft inside, hopefully the internal seals kept all but a small pocket inside. I'll check the pressure switch tomorrow to see if it fell out of range.
    Anyway, that sensor is bad. I poked the wires at the sensor and got the same .25 reading as before. As you said, Chap, no one seems to sell the sensor. If I can find one though, it might just solve the problem (assuming I haven't created a larger one).
    I also pulled the clutch off. There was only one washer in there, it's about 1mm thick. It seems I'm not the first to adjust it. Since the plate was about 1mm past spec, I'll just reinstall without the washer and see if that does it. Oriely's couldn't get me the shim kit, they said Toyota had "locked down" that part.
    I'm taking my mildly irritated eyes to bed. Tomorrow I'll reinstall the clutch and a new serpentine belt. Until I can find that sensor we'll just have to roll down the windows.
  9. ChapmanF
    15,105
    Oy... there's a nasty surprise. Well, now we know. Before anything else, please call your eye doc. The stuff may have insta-chilled your corneas, and some treatment may be recommended even if they feel ok.
    Here's hoping you're right about the internal shaft seals. Did it feel like just a small poot of gas that had leaked past the seals over the years?
    In any case, I would re-seal the hole (maybe just by sticking the sensor back in, does it use an O ring?) while hunting for a donor compressor with a good sensor. If you were wrong about the seals and this vented the whole works, you'll at least prevent any more moisture from getting in. When recharging, shop practice would probably be to replace the receiver/dryer too, though I'm not sure that's available as a part for this car. If the whole charge escaped, probably some oil did too, the hole being where it is, low on the compressor; some wizard advice might be needed to estimate how much oil to add with the charge.
    Too bad O'Reilly's doesn't sell the shim kit, but with Toyota gouging the price all the way up to $1.21, maybe O'Reilly didn't think they could save you enough to be worth it.
    -Chap
  10. Wisco
    Wisco Member
    116
    Everything seems fine. I had the same thought about moisture and put the sensor back after I tested it.
    The pressure switch didn't drop out of range, so I'm fairly certain it was just a pocket of compressed refrigerant I let out. If a person knew about it before hand they could pull the sensor out safely. Just don't crawl under the car and stick your face next to it. :)
    I cleaned up and reassembled the clutch. A few extra thin washers I had laying around got it to the perfect spacing. I engaged it with a spare battery and it locked down great.
    The hunt for the sensor begins..
    P.S. While I had access to tech.toyota I downloaded the repair manual. It was a chore to do it (nearly page by page) but that thing is a treasure trove.
  11. MchEngNrd
    MchEngNrd Junior Member
    Indiana
    2002 Prius
    I
    Did you happen to find that sensor? I'm considering replacing it myself, because it seems to be the source of the oil leak on my compressor.
    Or better yet, did you happen to see a replaceable o-ring on the sensor when you had it out? I would look, but I'd rather not have R-134a in my eyes ;)
  12. Wisco
    Wisco Member
    116
    Yes and yes. There weren't any for sale, but I contacted a half a dozen eBay sellers who had Prius compressors. A few had them.. the lowest price I was offered was $20 (10 for sensor, 10 for shipping) from Jensen Auto Inc on the east coast USA. It hasn't arrived yet. I was actually quoted $30, but the person I talked to said $20 and I didn't object.
    The sensor does have an O-ring. I'd be happy to measure it next time I have it pulled out of the car (looks like early next week).
    It's leaking oil, you say? I know there is some oil in the refrigerant.. I wonder how that is oozing out. Are you losing refrigerant pressure too?
    My face did feel a bit oily afterwards :)
  13. MchEngNrd
    Indiana
    2002 Prius
    I
    Thanks! Yes, there's some oil in the system that gets carried along with the refrigerant. R-134a boils at standard temperature and pressure (in open atmosphere), so if there is a leak, you can only tell by looking for the oil (or UV dye/HFC detectors). My system, after being fully charged, will quit running due to the leak after about 1.5 weeks.
    As chapman pointed out, based on your experience, a leak from the sensor may be in part due to a leak from the shaft seals inside the compressor (Name that Part! A/C Compressor Sensor. Replaceable? | PriusChat). Still, an o-ring is a few bucks, and a compressor is a couple hundred, so I'll probably give that a shot.
    #13 MchEngNrd, Aug 2, 2014
  14. Wisco
    Wisco Member
    116
    Well, I got the sensor today. I tested it and got .248 K Ohms (248 Ohms). I had a sickening feeling when I saw that because I realized I had misread my multimeter when I tested the original! It wasn't .250 Ohms, it was 250 Ohms. Another test confirmed my error.
    Ohm my goodness that was silly!
    I swapped them out anyway, and for some reason the AC is marginally better. Instead of flashing as soon as it is turned on, the AC light stays solid. Even took it for a drive and it stayed on, as does the MAX light. The air coming out seems to be ambient temperature though. But here's the odd thing: the clutch still isn't engaging. But instead of flashing the light, the car acts like it is doing a great job of keeping me cool.
    I'm going back to the manual to see what else could be interrupting power to the clutch.
    This isn't by-the-book, but I wondered about manually engaging the clutch with another battery while the engine is running to see if the clutch can do its job and if that gets some cold air coming out. I now have two wiring harnesses, so it'd be an easy test. I don't want to cause any damage, is there anything else in the AC system that could be damaged by the compressor engaging when it might not be expected?
    I've attached a pic of the O-ring, I'll let you interpret the size, Mch.[​IMG][​IMG]
    #14 Wisco, Aug 2, 2014
  15. Wisco
    Wisco Member
    116
    And the sensor looks like this.
    There was a much smaller release of gas this time, supporting the theory that it gradually builds up by slipping past the internal seals.[​IMG]
  16. ChapmanF
    15,105
    Hmm. And you already tested the CLR MG relay and it was fine. You're certain you put it back in after testing it? :)
    You don't need a separate battery for this test ... one thing I have lying around was sold to me long ago as a "remote starter switch". It's nothing but a big pushbutton in a fist-sized egg-shaped case with several feet of wire and two big alligator clamps. It should be used as a detonator for cartoon bombs, but really the idea was you'd put the clamps on the battery terminal and solenoid coil terminal on an old car and use it to crank the engine, say if you were doing a compression test.
    I've probably used it more times for other stuff than I ever used it for what it was made for.
    If you pull CLR MG back out of the relay box, stick two metal strips down into the two (wider) terminals of the socket, and clamp a starter switch to them, you've got your own big cartoon clutch-actuation switch that works whenever the key is on.
    I'd probably go back to the test you were doing earlier, where you noted when the controller was sending juice to the CLR MG coil terminals and when it wasn't. You could twist up a resistor and a big ol' LED to stuff into the narrower terminals of the CLR MG socket, and see it from across the room. :)
    -Chap
  17. MchEngNrd
    Indiana
    2002 Prius
    I
    Thanks for posting that picture. That o-ring is in bad shape!
    I went and got the o-ring from ace hardware. I've heard standard Nitrile/Buna-N o-rings do alright with R-134a ( Automotive AC Information Forum - ACKITS.COM). The new one seems to fit pretty well. When I swapped mine out, there wasn't much pressure built up behind it, but then again, my pressure was low to begin with. From what I saw, I would estimate you had a couple milliliters of oil spray you in the face (just in case you're trying to keep count of how much you've lost).
  18. Wisco
    Wisco Member
    116
    Okay, I'm not sure what make of this:
    I bypassed the relay by running a wire between the large blades (one of which has 13v) and the clutch does not engage.
    I went one step further and jumpered the hot terminal to the clutch connector pulled from my old sensor. I ran the other clutch wire to ground. When I completed the circuit the clutch locked down great and the compressor spun.
    Seems like there's a problem between the relay and the clutch.. I'll redo the test tomorrow to be sure.
    Revisiting my previous relay test seems like a great idea. I had an assistant turn the AC on and off while watching the smaller pins with my multitester. I'm not sure what to look for, but there wasn't any voltage between them at any point. One of the pins has 13v (to ground) as long as the car is on. Does the other make a ground connection to engage the relay?
    Swapping the relay with the one for the horn had no effect either (same numbers on them).
    I did the LED test too, and it didn't light up. But it's fairly cool now, would the AC amplifier still engage the relay?
    I'll redo all the tests tomorrow when it is hot and well-lit. These tests seem to point in two different directions (wiring from relay to clutch/ AC amplifier not engaging the relay). But I can't rule out human error, as evidenced by my blunders so far.
    Glad you found an O-ring, Mch. Hope it seals the leak.
  19. Wisco
    Wisco Member
    116
    No change today. I jumped the big slots of the relay connector and the clutch did not engage.
    I checked for continuity from the relay connector to the clutch connector and also to the larger compressor connector where it joins the wires from the sensor. Nothing.
    Double checked the ground, good.
    Double checked for voltage between the smaller relay blades when AC is turned on, nothing.
    If I'm reading the wiring diagram correctly, it is a straight shot from that relay to the clutch connector. So the fact that there is no continuity is a matter of a broken wire, loose connector, etc.
    I don't know what to make of the fact that the amplifier does not engage the relay. There is supposed to be a DTC if the amplifier is acting up (22), otherwise I'd suspect that.
    Maybe I'm in over my head.
    I manually engaged the clutch and ran the car for a while, curious if it would cool the cabin. The air certainly wasn't cold, I couldn't tell if it was cooler than ambient. I left the wiring in place to try again at peak heat tomorrow.
    I even wondered if charged up the AC and wired a switch for the clutch if I could get some cold air manually. Obviously I'd be risking roasting my serpentine belt if the compressor ever locked up.. But aside from servo motors directing airflow (which seem to react when I adjust the controls) the compressor is the only active component in the system..
  20. MchEngNrd
    Indiana
    2002 Prius
    I
    Your system is fully charged with R-134a, right? The clutch will not engage if the pressure sensor detects a low pressure reading. Sorry, I don't remember what you did so far (an your post has become quite the epilogue), but since you just said "I wonder if I charged up the AC..." I figured I'd point this out.
