ABS, and VSC and Brake lights on
Discussion in 'Gen 2 Prius Main Forum' started by jonsmilburn, Jul 14, 2010.
  1. jonsmilburn
    jonsmilburn Junior Member
    San Diego
    Just replaced 12 volt battery from a dealer nearby. Got it in OK, but my "!", ABS, and VSC and Brake lights are still on. Pads and shoes look fine. Is there a reset button or mode for these lights. I was under the impression that the display voltage test of 9 volts (dying battery) was causing the lights to come on. Just want to make sure there is no reset on the lights (like after an oil change) before I move on to other testing or the mechanic. The other symptom I've had along with these lights is the yellow arrows coming from the battery don't stop when I come to a stop. I have to put in neutral or park to get them to stop not matter how hard I press on the brake. This happened a couple years ago, along with the lights above, but went away. I wrote it off at the time to a bad connection somewhere.
    Thanks, Jon
  2. Patrick Wong
    18,200
    6,464
  3. jonsmilburn
    San Diego
    Sorry I was out of town. I will try this tonight and post. Thanks, Jon
  4. jonsmilburn
    San Diego
    Patrick, I used the jumper late yesterday and got a whole series of flashing (!), ABS, and VSC lights in a pattern that was too random and fast to keep track of. Somehow I thought I would see actual numbers flash. Am I to count the flashing of each light before it moves on to the next. I had my 14 year old son with me who loves the "Toyota Cheat Codes." He says it's just like a video game. He couldn't even keep up after making a rudimentary spread sheet to make ticks on. I could film it on my iphone and send you the video if that would be OK with you. Thanks, Jon
  5. Patrick Wong
    18,200
    6,464
    Hi Jon,
    Yes, the idea is to count the flashing of each warning light. Just look at one at a time, and see if you can decipher a two-digit code.
  6. jonsmilburn
    San Diego
    Thanks Patrick, For example, I watch just the (!) light and count flashes until a pause and that equals the first digit. Then I watch to see if it flashes after the pause and that would be the second digit? Then, for example I restart the test and watch just the ABS light, do the same and then watch the VSC light? How many possible digits can there be? And it's OK to run the test several times until I capture all the sequences?
  7. Patrick Wong
    18,200
    6,464
    Hi Jon,
    Yes, each code will be two digits long. Pls post the name of the light and the corresponding code(s) produced, as one light may be blinking out multiple codes.
    I think that the codes will repeat indefinitely so you may not need to run the test repeatedly, but do whatever is necessary to retrieve all of the two-digit codes. Then I can tell you what they mean.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Not good idea to post e-mail addresses in a public forum. Better use PM. Jon or Moderator please remove.
  9. connorwes
    connorwes Junior Member
    Ventura
    Hello,
    I am getting the following error codes
    (!) 41, 42, 53, 57
    ABS 42
    VSC 45
    I have not noticed a drop in performance, and braking appears to be responsive like normal. The only possible change I have noticed since these errors started happening is that it seems like the brake actuator is a little hyperactive. Also, when the error codes are not showing and I press on the brake, you can hear the brake actuator making a winding noise, and the error codes pop up.
    If I do need a replacement actuator, has anyone found a more economical choice than the dealer stocked $1800 replacement part? This seems excessive.
    Thanks for your insights!
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  11. Patrick Wong
    18,200
    6,464
    (!) codes are produced by the ECB portion of the skid control ECU.
    41: Low or abnormally high battery voltage
    42: Open circuit in IG2 circuit
    53: Hydro-booster pump motor relay malfunction
    57: Accumulator low pressure malfunction
    I don't find 42 in the ABS section, or 45 in the VSC section.
    How is your 12V battery? Have you had any no-start problems? If the battery is at all questionable I suggest you replace that first.
    Then, I suggest that you test the following four relays: ABS1, ABS2, ABS MTR1 and ABS MTR2. You will need a 12VDC power source and a decent digital multimeter.
    Remove each relay, one at a time.
    Select the ohmmeter function of the DMM, and short the ohmmeter leads together to see what the reading is. That shows you the resistance of the leads.
    Use the ohmmeter to determine which terminals are for the relay coil (you'll probably measure ~100 ohms across the terminals, or so.)
    Apply 12VDC to the relay coil terminals.
    Use the ohmmeter to measure resistance across the switched terminals. When power is applied to the relay coil you should find ~ 0 ohms resistance, and infinite resistance when power is removed. Buy a new relay if resistance > 0.5 ohms (after taking into account the resistance of the ohmmeter leads.)
    After you have verified that all four relays are good, then clear the skid control DTC and try again. If the codes reappear then it is reasonable to expect that your car needs a new brake actuator. Since this is difficult to install and I am not aware of independent Toyota hybrid specialists in your area, I suggest that you have your local Toyota dealer take care of that repair. Good luck.
  12. connorwes
    Ventura
    Patrick,
    As always, thank you for the insightful information.
    My 12v batter was recently replaced, and going through the MFD diagnostic screen, it appears to be cranking out the proper voltage. I have never had any no-start problems.
    The step by step instructions for test the relays was very helpful. To apply the 12VDC to the relay I used the jumper terminal in the engine fuse compartment and a short piece of wire to ground to one of the engine bolts. An assistant helped me use the ohms meter.
    What i found was that 3 of 4 relays were in spec, indicating near 0 ohms resistance when powered. The final relay I tested was the ABS MTR relay and it at first indicated about 0.20 ohms resistance and then occasionally would indicate 1 ohm (open circuit) suggesting that it is not switching on properly when powered. I will replace this ASAP and clear the codes... with my fingers crossed.
    I tried to check the error codes again, but they refuse to remaing blinking now?? As soon as I step on the brake and hear the actuator, they return to solid codes (i assume this is an indication of the code actively being thrown).
    I'll refer to a video i took of the codes to see if the VSC of 45 and ABS 42 were accurate.
    Thank again!
  13. connorwes
    Ventura
    Re: SOLUTION! ABS, and VSC and Brake lights on
    Patrick thank you!
    With your help I have successfully diagnosed and replaced a bad relay! There are four relays for this system and three of them checked out fine indicating ~0.0 ohms. The fourth threw various ohms readings anywhere from 0.01 to 0.25.
    I have read that the VSC computer has no tolerance for voltage fluctuations, so this was clearly the problem.
    Hopefully others have found this to be a cost-friendly fix to this perplexing set of warning lights.
    To reset the error lights put a jumper in pins # 4 & 13 and press the brakes 8 times within 5 seconds. If the problem is fixed, the lights will all blink in tandem repeatedly. When you turn the car off and remove the jumpers, the lights should go out.
    I found that toyotapartszone.com was a great resource in locating affordable parts and have very detailed parts diagrams
    PriFi and dougz4m like this.
  14. connorwes
    Ventura
    Unfortunately, my problems have arrisen again with the same symptoms and no easy fix like a busted relay. This time I am getting the following error codes:
    (!) 41,53,
    ABS 42
    VSC 45
    I took the vehicle to a mechanic who specialized in Prius. He tested the brake system and confirmed that it does not hold pressure when the brake pedal is depress -- final advisory is to replace the brake actuator.
    bummer....
  15. ChapmanF
    15,158
    A followup on this thread concerning the few 'mystery' blink codes that can't be found in some editions of the Gen 2 manual (36 on ECB, 42 on ABS, 43 or 45 on VSC): more here.
