Accessory mode shuts off after 2 minutes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sandiegomom, Apr 29, 2012.
  1. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    So I wanted to play with the nav system (specifically figure out how to make it find POI along my route... why it can't tell me the compass direction along with the distance to the 17 different McDonalds is beyond me) and when I turned the car on in accessory mode (not depressing the pedal) it shut off after two mins. I tried both "levels" of accessory mode and the behavior was the same. The car was plugged in and actively charging. What am I doing wrong?
  2. firepa63
    firepa63 Former Prius Owner
    1,762
    201
    In accessory mode your running on the 12v battery, not the HV battery. Be thankful that it shuts off 2 minutes. Earlier models don't shut off and lead to a depleted 12v battery. In which case, the car cannot be made READY.
  3. ProximalSuns
    ProximalSuns Senior Member
    1,882
    16
    27
    PNW
    Mechanic told me to just leave it running. The engine will turn off and on as needed to keep the 12V battery charged and running down the 12V battery creates a lot of problems.
  4. 9G-man
    9G-man Senior Member
    1,256
    168
    Atlanta, GA
    If you are gonna be plugged in, just go to "ready" mode and play all you want. It wont really be ready mode since you are plugged in.
    ie: step on the brake pedal and power up while you are plugged in.
  5. Sandiegomom
    109
    28
    San Diego
    That makes sense. This is still hard to wrap the old brain around at times!
  6. jbrad4
    jbrad4 Active Member
    474
    145
    Rowlett, TX
    Sandie, If you time it, I think you'll find that it is closer to 1:45 than 2 min. When you stop charging, just put it in READY mode with the car in PARK and you can play with the Nav system.
    It is a pain that it won't stay in accessory mode. You would think that when you are charging the traction battery it could keep the 12v battery charged in accessory mode. I understand this behavior in accessory mode for the normal Prius but not for the Plug-In while it is charging the traction battery. This is something that Toyota should change. If enough of us complain maybe they will. The 12 v battery is so puny, that you don't want to have the car in accessory mode for very long if the 12 v battery is not charging.
  7. Sandiegomom
    109
    28
    San Diego
    Thanks Jim, glad to know it is on purpose, even if annoying!
  8. bfd
    bfd Plug-In Perpetuator
    616
    128
    Close to SDSU in the Far Southwest Corner of Calif
    It is frickin' annoying. I've been futzing with custom images all afternoon - and wouldn't it be nice if the system stayed on longer than a minute and 45 seconds while plugged in?!?!?
  9. o2cool
    o2cool o2cool
    48
    Palo Alto, CA
    And I wondered if it was just me or my PIP. Glad to hear that this is standard operating procedure.
