Actual MPGs - Anyone Filled Up, Calculated?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cycledrum, Mar 9, 2012.
  1. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    Just another reason to love California...
  2. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    Yeah it does make a big diff obviously how far you drive on trips and how you can charge. My wife has a 70 mile roundtrip commute with no ability to charge. So her mileage tends to be closer to 50. On our weekend errands and when i drive to work it's 100% EV. And yes this is our first Prius so developing driving habits and learning at the same time. But 36 bucks to fill up was a lot cheaper than the Audi... :)
  3. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Shocking?
    Try 1.8 EUR / liter in the EU. That's 8,98 $ / US gallon!!!
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    That is Horrifying!
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    We won't see the true result until next month. If you need to put gas now, you're driving it as a regular Prius. Many converted Prius go 1-2 months without fill up. Sometimes more. I would imagine PiP is the same. Let's see who can go 1000 miles between fill up.
  6. Ichiro
    Ichiro Member
    335
    SF
    I'm curious to see what the effective usable tank capacity is on the PHV.
    On the GenII Prius it was about 9-10 gallons between fill-ups.
    Is the PHV still using the flexible bladder?
  7. bisco
    48,999
    no, there hasn't been a bladder since 2010 gen III.
  8. bisco
    48,999
    you won't get elected in this country if you talk about raising gas prices, even the dems don't want to hear it.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Can you guys that reported 64+/- MPG tell us about your daily commute? The numbers are a little disappointing -- a GII with an Enginer kit will do better than that for commutes up to 30 miles. There is perhaps a learning curve here, being adept to use HV/EV to make sure that the ICE provides the majority of power for hill climbs and acceleration, let the battery blend in a lot of power for cruising, and use EV for only low speeds. Anything more than 100 amps in EV mode, I'd say you'd be better off in HV mode, due to efficiency losses on the electric side.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Consider hundreds of 10/11 Prius owners reporting actual MPGs on fuelly.com .... averaged out, has not reached 48 MPG. Short trips, 1 mile hops to the corner store bring hybrd FE to its knees, 43 MPGs or less ...
    PiP will run all EV on short trips. But, will 6x MPGs be widely reported among PiP owners?
    I think 48 to 64 MPG is 25% improvement.
    (((1/48) - (1/64)) / (1/48)) x 100 = 25%
  11. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    True the short trips have poor MPG, but then they are short and in the overall MPG computation have a small impact. If small trips are say 5% of total miles travel, the 50mpg Prius would get .05*43 + .95*50 = 47.5mpg
  12. p626808
    p626808 New Member
    292
    4.31 a gallon ouch!!:eek: still paying 3.45 here in NJ
  13. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    That first picture is 161mi EV 27%.
    Gas Receipt:
    8.311 Gallons @ 4.259
  14. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    585 mi / 8.311 = 70.38 MPG actual ??
    Does this indicate a little gage error given CONS 72 MPG?
    No biggie, it's only one data point.
  15. plugged-in
    plugged-in Junior Member
    22
    irvine
    Really depends on your commute. So far I am getting 78mpg. I have a 84 mile roundtrip commute to work, and I am only able to charge at home. I have approx. 12% EV usage only. Still on first tank of gas. Can't confirm how accurate the computer is yet though the 2 other posts suggest it is spot on.
  16. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Actually, it did stop automatically at 8.1 gallons and I forced a little more in. 8.1 would be 72. So it is right on. That's pretty cool. I guess without the bladder it can get more accurate.
  17. drinnovation
    2,027
    586
    65
    CO
    8.311 is what she put in.. not necessarily what he burned. Maybe the fill at the dealer was a little light.
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    8.311 is what SHE put in :)
  19. cproaudio
    2,401
    758
    CA
    I'm still waiting for someone with 1000 mile tank or even 1500 mile tank with 100+ actual MPG. I refuse to believe that a cheap nice person Enginer kit gets higher mileage than the OEM plugin.
  20. HillCountryEVer
    HillCountryEVer New Member
    75
    Kerrville, Texas
    Soon, I bet...:)
