Adding big amp under seats. Run cable from inverter?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by R-P, Jan 21, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    480
    For anyone serious about installing an amp like this in a Prius, the 12V system would have to be upgraded accordingly. My guess would be that it would more than double the cost.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Not necessary. My battery and system are 4+ years old and counting.
  3. GregP507
    3,002
    480
    #23 GregP507, Jan 26, 2015
  4. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Just something to throw into your calculations.
    You are assuming that the voltage drop from the dc/dc converter along the supply wire will leave the voltage at the battery lower. The battery voltage however is monitored by a sense wire going back to the converter.
    If the battery voltage is sensed low the converter increases it's output to compensate until the voltage measured by the sense wire at the battery is at the correct level. There will always be a voltage drop in the converter supply wire depending on load, but the voltage at the battery will "within reason" remain at the required charging voltage.
    This effect can be seen by monitoring the battery voltage on the MFD in ready mode. If you turn on the headlamps the battery voltage does not fall in fact it often goes up as the dc/dc converter sees the voltage drop via the sense wire and compensates. The load on the dc/dc converter with the car in ready mode and the lights on is around 30 amps depending on the state of charge of the 12 volt battery. This is without any other accessories running.
    John (Britprius)
    #24 Britprius, Jan 26, 2015
    ftl likes this.
  5. R-P
    R-P Active Member
    804
    288
    Netherlands
    You're not helping... ;)
  6. GregP507
    3,002
    480
    It's not polite to judge, but when you see someone rushing headlong into a mess, it's only right to say something.
  7. R-P
    R-P Active Member
    804
    288
    Netherlands
    Not sure how to read that, but if it was a reaction to my reaction to Britprius: I hope he 'knows' me well enough to see the intended irony of my remark. :ROFLMAO:
    I had just about figured out how to add an extra safety feature, then he comes along and wrecks my ideas with something as insignificant as facts about the electronics in the Prius...:LOL:
  8. Britprius
    5,194
    1,912
    I did completely understand the ironic humor in you rely.
    I think Greg has possibly misunderstood your remarks due to slight differences in in humor between the continents. No disrespect intended towards Greg in that remark.
    England and America two great nations separated by a common language.
    John (Britprius)
    #28 Britprius, Jan 28, 2015
