1. Offline
    SZ92 New Member
    Start a Conversation
    Aug 15, 2008
    43
    Your Vehicle Year:
    How would you go about adjusting the headlights on a 2010 prius with led lights.
  2. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,171
    Alaska
    Your Vehicle Year:
    Good question. The have an auto-leveler but I suspect the base line should still be adjustable. There is an adjuster on the non-LED type for vertical alignment only. I along with others here had to adjust ours because it was too low from the factory.
  3. Offline
    Aug 14, 2006
    18,123
    3,437
    Sacramento, CA.
    Your Vehicle Year:
    Do you know how to properly align them?
    A lot of people come from running halogen lights in reflector housings so they don't realize that projector style headlights have a sharply defined cutoff that blocks light from going to high. I just want to make sure you know how they work.
  4. Offline
    Aug 14, 2006
    18,123
    3,437
    Sacramento, CA.
    Your Vehicle Year:
    Here is how Tumbleweed did it:
    Here is a link to HIDPlanet that explains how to do it legally: HOW TO: aim HID headlights
    To remain safe and legal you should make sure that your lights do not shine above the trunk of most passenger cars or above the door line (shining into the driver's side window).
  5. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,171
    Alaska
    Your Vehicle Year:
    You talk'n to me? If so, I was working with Tumbleweed on aiming the headlights about what a year and half ago. And now that you mention it, he has a V so probably LED lights. So if that worked for him and worked for me (halogen) guess we are covered.
    Now to whether they are adjusted to specification I couldn't tell you, I just keep adjusting till I could actually see far enough ahead to be safe. I have not had anyone flash me so I think it is OK.
  6. Offline
    Aug 14, 2006
    18,123
    3,437
    Sacramento, CA.
    Your Vehicle Year:
    Nah, the OP. I figured you already knew how to do it and didn't need instruction. :)
  7. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,418
    1,299
    Northern California
    Your Vehicle Year:
    Here's the adjustment.
    The instructions F8L posted look universal and should work on any car with that type headlights
    1 people like this.
  8. Offline
    • Moderator
    Sep 22, 2005
    6,974
    1,739
    N.Y.
    Your Vehicle Year:
  9. Offline
    lenjack Member
    Dec 1, 2006
    622
    16
    Pennsylvania USA
    Your Vehicle Year:
Share This Page
