Adjusting the emergency brake?
Discussion in 'Gen 2 Prius Main Forum' started by gforeman, Sep 8, 2007.
  1. gforeman
    gforeman New Member
    83
    Any how-to here on adjusting the emergency brake? Mine pretty much goes to the floor now. Car only has 5k on it, but I park on a hill and have to set it hard. I just need to take out some cable play.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    An '07, I'd ask the dealer to do it esp. if you're still under the 12mo/12k mile warranty.
  3. gforeman
    gforeman New Member
    83
    <div class='quotetop'>QUOTE(efusco @ Sep 8 2007, 04:36 PM) [snapback]509180[/snapback]</div>
    Dealer is about 30 miles form here, plus sit around in the dealship for an hour....I'd rather just do it myself :rolleyes:
  4. efusco
    19,891
    1,191
    Nixa, MO
    I understand that....still, if you have an oil change coming up or something and have an excuse to be there you could coordinate it.
    I'll take a look under the dash and try to get some photos if Galaxee or someone else doesn't chime in first....it should be a pretty easy procedure.
  5. gforeman
    gforeman New Member
    83
    12 Mo 12k warranty? I thought it was std. with 3 Year 36k?
  6. efusco
    19,891
    1,191
    Nixa, MO
    <div class='quotetop'>QUOTE(G-Man @ Sep 8 2007, 05:57 PM) [snapback]509224[/snapback]</div>
    It may be...the 12/12 is the unofficial "adjustment" warranty where they'll change and fix some minor things...alignment, some changes/programming that can be done with the scantool at customer request, etc. Outside the 12/12 you've gotta pay for that stuff. I'm not sure whether the brake pedal adjustment would be considered a wear thing that they would want to charge for after 12y/12k miles or not.
  7. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(efusco @ Sep 8 2007, 03:07 PM) [snapback]509227[/snapback]</div>
    Hobbit shows here http://www.techno-fandom.org/~hobbit/cars/brkjob/adj.html that the brake should be self adjusting if it is working properly. Backing up has no effect. The back brake and the parking brake use the same shoes, at least on the '04. All that is reqiuired is a few stops which use the friction brakes.
    If that does not correct the problem, it may be a job for the dealer.
  8. efusco
    19,891
    1,191
    Nixa, MO
    <div class='quotetop'>QUOTE(Allannde @ Sep 8 2007, 06:29 PM) [snapback]509235[/snapback]</div>
    I guess I got the impression this was one of those brake cable stretch issues, not a problem with the shoes/calipers.
  9. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    DH has never had to adjust an e-brake cable in the thousands of prius he has serviced.
    he would encourage you to have the whole system checked out, especially since it's under warranty. that does fall under the 12k adjustment warranty.
  10. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(efusco @ Sep 8 2007, 03:41 PM) [snapback]509239[/snapback]</div>
    Evan
    I found the proceedure for taking out Parking Brake cable play in the '06 Repair Manual. It invovles removing the center console, the footrest and adjusting the tension nuts on the parking brake cable. It refers one to four different sections in three different volumes. I still recommend the dealer.
    Perhaps Hobbit or Galaxee will come on with step by step instructions. Not having done it, I can't visualize how hard it would be.
    Allan
  11. efusco
    19,891
    1,191
    Nixa, MO
    <div class='quotetop'>QUOTE(Allannde @ Sep 8 2007, 07:03 PM) [snapback]509251[/snapback]</div>
    Yikes, sounds like it's well worth a 30 mile drive and a wait to me too!!
  12. tnp
    tnp Junior Member
    San Diego
    Johnav posted the parking brake adjustment in another link. For the '07 Prius. it is under the center console.
    To remove the console, pull up on the front cup holders to expose 2 screws at the bottom. There are 2 more 10 mm bolts on the inside toward the rear of the console(under the black felt). The console lifts up to expose the parking brake adjustment cable.
  13. macguyver
    macguyver Dis-Member
    SF Bay Area, CA
    Sounds similar to my old '92 Honda Civic and a slew of other cars.
    My 2006 Prius gets a lot of use on the ParkingBrake (PB) due to daily hill parking. The pedal slowly goes farther down over time until my next service visit. The techs usually adjust it with out my having to ask, which speaks well of their attention to the job.
