advice needed: traction light on full time
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TharakaD, May 6, 2015.
  1. xliderider
    xliderider Senior Member
    7,850
    3,103
    Honolulu, HI
    Yes, hot brake discs. If they get really hot, they can also warp, which might make your steering wheel shake when you brake,since it's the front brake rotors.
    TharakaD likes this.
  2. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks xliderider.
    Actually steering wheel issue comes early during morning drive to work. So even with cold disks.
  3. TharakaD
    TharakaD Member
    137
    Colombo
    Dear Mendel, would you think if front pads are worn out in a 70,000km Prius. Can that be the answer for the other issues
  4. Mendel Leisk
    38,303
    With the rims solidly bolted to the rotor heat gets transmitted to outside of wheel pretty efficiently. If the wheel is extremely hot be careful if touching the rotor, it'll be worse, lol.
    With our car I think we could drive all day and the front wheels would only be a little warm. Your case does not sound normal, and is strong suspect for low mpg too.
    Yeah get the brakes thoroughly checked: pad thickness, caliper pin lubrication, caliper piston not seizing in bore, rotor parallelism/thickness.
    Be careful who does it, preferably Toyota: the electronics can be upset, or even piston ejected.
  5. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks Mendel. Let me get Toyota Lanka to have a look at it.
    As usual since it is Toyota itself and not a dealer it can cost me.
    I'm also waiting to my Nissan Leaf to arrive in Colombo from kobe. Was saving for that.. Anyway can't take a chance on brakes...
  6. xliderider
    7,850
    3,103
    Honolulu, HI
    If your steering wheel shakes when brakes applied to cold discs then the damage has been done. They'll need to turn your rotors or replace them if they are too severely warped.
  7. TharakaD
    TharakaD Member
    137
    Colombo
    xliderider / Mendel
    It's apparent now its dragging. I saw in a slight down hill when I just touching accelerator RPM goes beyond 50% engine start
    Mendel, dragging may be due to hard pressing of brake padle?
    This was when I the brake light fuse blew, and then trying to start
  8. Mendel Leisk
    38,303
    You still have traction light on? Yeah, it could be something in the car's electronics malfunctioning, causing the brakes to drag, considering all the symptoms. You mentioned "hill hold" not working too? Frustrating. All I can think is verify the mechanical condition of the brakes is ok, and then have the electronics checked. Seems so far like they are not able to diagnose properly, but willing to take your $'s.
  9. TharakaD
    TharakaD Member
    137
    Colombo
    Hi Mendel.
    traction light is No more. Hill assist is also working well now
    Today I lifted the front wheels and rotated on neutral. The dragging was so clear + left has the hammm I think brake pad worn warning
    Today Toyota is closed. You think normal garage can fix new normal pads. So I can get it fixed by a garage today
  10. TharakaD
    TharakaD Member
    137
    Colombo
    Hi Mendel.
    If at all its a electronic / software issue, which I also think: Replacing pads will not solve the issue?
    Due to hmm in front left I think I should replace pads. Yet it seems abt 3mm. I saw in priuschat can go up to 1mm. Just confused over there also.
    But then, with additional pad width its gonna seal the disk further??
    Or should I do a brake calibration, how can I do it?
  11. TharakaD
    TharakaD Member
    137
    Colombo
    Hi Mendel.
  12. Mendel Leisk
    38,303
    It's not really possible to test brake drag on the fronts, due to the wheels being connected to the transmission. To turn them will always take some effort, so hard to tell. Still, if your wheels are very hot to the touch that's a good clue of drag.
    If you've got 3mm remaining pad thickness that's not very good. 1 mm is the bare minimum, but I tend to be more conservative, would be thinking to replace pads soon. 3 mm remaining indicates brakes with lots of wear, and it seems to me less able to dissipate heat, prone to wear at accelerated rate for the remaining thickness.
    To really see their condition the caliper needs to be pulled off and the pads examined directly. It's also imperative to check the caliper pin condition: they should be pulled out and regreased. If they're drying out it prevents the caliper from "floating", being able to move side-to-side. If that's the case you might see more wear on one pad than the other.
    Anytime the brakes are opened on the Prius it's good to disconnect the 12 volt battery negative lead. It's possible for the car to try to pressurize the brake system, especially when driver's door is opened. After re-assembly of brakes and before reconnect of 12 volt negative cable it's a good idea to pump the brake pedal several times, to pressurize the brake lines, avoid the car's electronics getting upset.
    #52 Mendel Leisk, May 31, 2015
  13. Patrick Wong
    18,200
    6,464
    Yes, but make sure the garage disconnects the 12V battery prior to working on the car, and does not allow air to enter the brake hydraulic system at the brake calipers.
    The purpose of having the brake pads replaced now is to have the mechanic inspect the caliper and the caliper slide pins to determine why the wheel is binding. If the pads are worn to 3 mm they might as well be replaced. It is likely that the inner pad is worn more than the outer, if the wheel is dragging.
    #53 Patrick Wong, May 31, 2015
    TharakaD and Mendel Leisk like this.
  14. Mendel Leisk
    38,303
    Be careful with choice of caliper pin grease. Toyota uses the expression "lithium soap base glycol grease". In North America "Sil-Glyde Brake Lubricant" is an alternative, commonly used caliper pin grease. The correct grease looks kind of like Vaseline or silicon dielectric compound. If the shop is Toyota they should be using the correct grease, Toyota makes a special grease for that application.
  15. TharakaD
    TharakaD Member
    137
    Colombo
    Hi experts
    Bad news
    Lifted rear wheels and saw that two also dragging.
    Of cause without footbrake and ignition off.
    So my all 4 wheels are dragging
    What can be the issue..??
  16. TharakaD
    TharakaD Member
    137
    Colombo
    Hi friends its error code U0155
    Something to do with communication. But brakes... Toyota dealer in Kandy was not sure
  17. TharakaD
    TharakaD Member
    137
    Colombo
    Since error code u0155 meant nothing
    Replaced the front pads.
    But problem continues still its dragging
    Experts please help
    All four wheels are hot after 15km drive and it reduces speed without brake in slight down hills where it used to speed.
    Have to accelerate more.
    #57 TharakaD, Jun 1, 2015
  18. Mendel Leisk
    38,303
    If Toyota dealership can't resolve a brake issue I think you need to talk to someone higher up in Toyota. Hopefully they will listen and get something done for you.
    Codes showing, the initial car wash incident, something is up.
  19. bisco
    49,049
    i wonder if there's an ecu problem, causing light brake pressure?
  20. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    2013 Prius ,isn't this still under warranty
