ScanGuage AE Pig-tail, code flasher, and TechStream
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Jun 11, 2010.
  1. bwilson4web
    16,224
    I'm used to dealing with noisy data but then I looked at the labor it takes to decode the analog and decided to jump to the MSP430 solution. With a watch crystal it will be stable yet I'll have the ability to handle the 5 baud initialization as the 10.4 or 10.5 kbaud (depends upon source) data. I may be able to handle CAN bus eventually. But more importantly I can drive it from the laptop and start an exhaustive survey.
    51,985
  3. bwilson4web
    16,224
    XGauge TXD RXF RXD MTH ID Notes
    1 MIL illumination 8210F10101 031024410501 2801 000100010000 MIL OFF / ON
    2 No. of Engine DTCs 8210F10101 031004410501 2907 000100010000 #EC XXX count
    3 Fuel system status #1 8210F10103 031004410503 2808 000100010000 FSS 1 : Open loop due to insufficient engine temperature
    4 2 : Closed loop using oxygen sensor feedback to determine fuel mix
    5 4 : Open loop due to engine load OR fuel cut due to deacceleration
    6 8 : Open loop due to system failure
    7 16: Closed loop using at least one oxygen sensor but there is a fault in the feedback system
    8 Calculated Load 8210F10104 031004410504 2808 001400330000 LOD XX %
    9 Engine Coolant Temperature 8210F10105 031004410505 2808 00010001FFD8 °cwt +/- XX °C
    10 Engine Coolant Temperature 8210F10105 031004410505 2808 00090005FFD8 °fwt +/- XX °F
    11 Short term fuel % trim-Bank 1 8210F10106 031004410506 2808 00190020FF9C SF1 -100% : Rich 99% : Lean
    12 Long term fuel % trim-Bank 1 8210F10107 031004410507 2808 00190020FF9C LF1 -100% : Rich 99% : Lean
    13 Engine Speed 8210F1010C 03100441050C 2810 000100040000 rpm XXXX rpm
    14 Vehicle Speed 8210F1010D 03100441050D 2808 000100010000 kph XXX kmh
    15 Vehicle Speed 8210F1010D 03100441050D 2808 000500080000 mph XXX mph
    16 Ignition Advance 8210F1010E 03108441050E 2808 00050001FD80 IGN +/- XX.X °
    17 Intake Air Temperature 8210F1010F 03100441050F 2808 00010001FFD8 °cia +/- XX °C
    18 Intake Air Temperature 8210F1010F 03100441050F 2808 00090005FFD8 °fia +/- XX °F
    19 Air Flow rate into Engine 8210F10110 031044410510 2810 000100010000 MAF X.XX gm/s
    20 Throttle Position 8210F10111 031004410511 2808 001400330000 TPS XX %
    21 Oxygen sensors present 8210F10113 031004410513 2808 000100010000 oSP [A0..A3] : Bank 1 Sensors 1-4 [A4..A7] : Bank 2 Sensors 1-4
    22 O2 Sensor Bank1 Sensor1 8210F10114 031004410514 2808 000500010000 o11 XXX mV
    23 O2 Fuel Trim Bank1 Sensor1 8210F10114 031004410514 3008 00190020FF9C f11 XX %
    24 O2 Sensor Bank1 Sensor2 8210F10115 031004410515 2808 000500010000 o12 XXX mV
    25 O2 Fuel Trim Bank1 Sensor2 8210F10115 031004410515 3008 00190020FF9C f12 XX %
    26 OBD standards this vehicle conforms to 8210F1011C 03101441051C 2808 000100010000 obd 01h : OBD-II as defined by the CARB
    27 02h : OBD as defined by the EPA
    28 03h : OBD and OBD-II
    29 04h : OBD-I
    30 05h : Not meant to comply with any OBD standard
    31 06h : EOBD (Europe)
    32 07h : EOBD and OBD-II
    33 08h : EOBD and OBD
    34 09h : EOBD OBD and OBD II
    35 0Ah : JOBD (Japan)
    36 0Bh : JOBD and OBD II
    37 0Ch : JOBD and EOBD
    38 0Dh : JOBD EOBD and OBD II
    39 MIL ON Run Dist 8210F10121 031044410521 2810 000100010000 dml XXXX km
    40 MIL ON Run Dist 8210F10121 031044410521 2810 000500080000 dml XXXX miles
    41 Auxiliary Battery Voltage 8210F10181 031084410581 2808 002800330000 VLT XX.X V
    42 Injector 8210F10182 031084410582 2808
    43 Revised Injector Volume 8210F10183 031044410583 2808
    44 Fuel FB Coef 8210F10184 031044410584 2808
    45 A/F Learn 8210F10185 031004410585 2808
    46 Purge Learn 8210F10186 031004410586 2808
    47 KCS Feedback 8210F10187 031084410587 2808
    48 Request Engine Power 8210F10188 031044410588 2808
    49 Engine Run Signal 8210F10189 031024410589 2F01 000100010000
    50 Engine Warming Up Signal 8210F10189 031024410589 2E01 000100010000
    51 ACC Racing Signal 8210F10189 031024410589 2D01 000100010000
    52 Engine Run Permission 8210F10189 031024410589 2C01 000100010000
    53 RAM Monitor 8210F10189 031024410589 2B01 000100010000
    54 FC Status 8210F10189 031024410589 000100010000
    55 Engine Stop Limit 8210F10189 031024410589 000100010000
    56 Throttle Close Duty 8210F101B2 0310444105B2 4808
    57 Throttle Open Duty 8210F101B2 0310444105B2 5008
    58 Throttle Pos 2 8210F101B2 0310444105B2
    59 Throttle Target 8210F101B2 0310444105B2
    60 Throttle Motor On 8210F101B3 0310244105B3 2F01 000100010000
    61 ETCS Mag Clutch 8210F101B3 0310244105B3 2E01 000100010000
    62 Misfire RPM 8210F101E2 0310044105E2 2808
    63 Misfire Load G_Rev. 8210F101E2 0310044105E2 3008
    64 Fuel Injection time for cyl #1 8210F101E4 0310444105E4 2808 001900020000 inj X.XX ms
    65 Abnormal Revolution Variation Cyl 1 8210F101E9 0310044105E9 2808 000100010000 vc1 XX %
    66 Abnormal Revolution Variation Cyl 2 8210F101E9 0310044105E9 3008 000100010000 vc2 XX %
    67 Abnormal Revolution Variation Cyl 3 8210F101E9 0310044105E9 3808 000100010000 vc3 XX %
    68 Abnormal Revolution Variation Cyl 4 8210F101E9 0310044105E9 4008 000100010000 vc4 XX %
    69 Ignition Cnt 8210F101EB 0310044105EB 2810
    70 A/C Clutch Sig 8210F101EF 0310244105EF 3401 000100010000
    71 EVAP VSV 8210F101EF 0310244105EF 3301 000100010000
    72 Fuel Pump 8210F101EF 0310244105EF 3601 000100010000
    73 VVT Ctrl B1 8210F101EF 0310044105EF 000100010000
    74 O2 RL B1 S2 8210F101F2 0310044105F2
    75 Engine DTC 1 (emission related) 8110F103 03101443 2010 000100010000 ec1 XXXX hex.
    76 Engine DTC 2 (emission related) 8110F103 03101443 3010 000100010000 ec2 XXXX hex.
    77 Engine DTC 3 (emission related) 8110F103 03101443 4010 000100010000 ec3 XXXX hex.
    78 Engine DTC 1 (emission & non-emission related) 8310F113FF00 03101453 2010 000100010000 EC1 XXXX hex.
    79 Engine DTC 2 (emission & non-emission related) 8310F113FF00 03101453 3010 000100010000 EC2 XXXX hex.
    80 Engine DTC 3 (emission & non-emission related) 8310F113FF00 03101453 4010 000100010000 EC3 XXXX hex.
    81 MIL illumination 8216F10101 031624410501 2801 000100010000 MIL OFF / ON
    82 No. of HV DTCs 8216F10101 031604410501 2907 000100010000 #HC XXX count
    83 Engine Coolant Temperature 8216F10105 031604410505 2808 00010001FFD8 °CWT +/- XX °C
    84 Engine Coolant Temperature 8216F10105 031604410505 2808 00090005FFD8 °FWT +/- XX °F
    85 Engine Speed 8216F1010C 03160441050C 2810 000100040000 RPM XXXX rpm
    86 Vehicle Speed 8216F1010D 03160441050D 2808 000100010000 KPH XXX kmh
    87 Vehicle Speed 8216F1010D 03160441050D 2808 000500080000 MPH XXX mph
    88 Intake Air Temperature 8216F1010F 03160441050F 2808 00010001FFD8 °CIA +/- XX °C
    89 Intake Air Temperature 8216F1010F 03160441050F 2808 00090005FFD8 °FIA +/- XX °F
    90 Distance traveled with MIL on 8216F10121 031604410521 2810 000100010000 DML XXXX km
    91 Distance traveled with MIL on 8216F10121 031604410521 2810 000500080000 DML XXXX miles
    92 INFO. Code 2 8216F101AA 0316044105AA 2810 000100010000 ic2 XXX
    93 INFO. Code 3 8216F101B1 0316044105B1 2810 000100010000 ic3 XXX
    94 INFO. Code 4 8216F101B7 0316044105B7 2810 000100010000 ic4 XXX
    95 INFO. Code 5 8216F101BD 0316044105BD 2810 000100010000 ic5 XXX
    96 MG2 RPM 8216F101C2 0316044105C2 2810 000100010000 M2R +/- XXXX rpm
    97 MG2 Torque 8216F101C2 0316044105C2 3810 000100010000 M2T +/- XXX Nm (need to divide by 8)
    98 Regen Brake Execution Torque 8216F101C3 0316044105C3 2808 000100010000 reT XXX Nm
    99 Regen Brake Request Torque 8216F101C3 0316044105C3 3008 000400010000 rrT XXX Nm
    100 MG1 RPM 8216F101C4 0316044105C4 2810 000100010000 M1R +/- XXXX rpm
    101 MG1 Torque 8216F101C4 0316044105C4 3810 000100010000 M1T +/- XXX Nm (need to divide by 8)
    102 Request Engine Power 8216F101C5 0316444105C5 2810 000100010000 Pe X.XX kW
    103 Target Engine Revolution 8216F101C6 0316044105C6 2810 000100010000 ter XXXX rpm
    104 Engine Speed (similar to RPM) 8216F101C7 0316044105C7 2810 000100010000 rpm XXXX rpm
    105 Master Cylinder Control Torque 8216F101C8 0316044105C8 2810 000400010000 mcT - XXX Nm
    106 State-of-Charge 8216F101C9 0316844105C9 2808 00C800330000 soC XX.X %
    107 WOUT Control Power 8216F101CA 0316844105CA 2808 000800050000 Pwo XX.X kW
    108 WIN Control Power 8216F101CA 0316844105CA 3008 00080005FE68 Pwi - XX.X kW
    109 Discharge Request to adj. SoC 8216F101CB 0316444105CB
    110 MG1 RPM 8216F101C4 0316044105C4 2810 000100010000 M1R +/- XXXX rpm
    111 MG1 Torque 8216F101C4 0316044105C4 3810 000100010000 M1T +/- XXX Nm (need to divide by 8)
    112 Request Engine Power 8216F101C5 0316444105C5 2810 000100010000 Pe X.XX kW
    113 Target Engine Revolution 8216F101C6 0316044105C6 2810 000100010000 ter XXXX rpm
    114 Engine Speed (similar to RPM) 8216F101C7 0316044105C7 2810 000100010000 rpm XXXX rpm
    115 Master Cylinder Control Torque 8216F101C8 0316044105C8 2810 000400010000 mcT - XXX Nm
    116 State-of-Charge 8216F101C9 0316844105C9 2808 00C800330000 soC XX.X %
    117 WOUT Control Power 8216F101CA 0316844105CA 2808 000800050000 Pwo XX.X kW
    118 WIN Control Power 8216F101CA 0316844105CA 3008 00080005FE68 Pwi - XX.X kW
    119 Discharge Request to adj. SoC 8216F101CB 0316444105CB 2810 0001000A0000 Pd X.XX kW
    120 Drive Situation ID 8216F101CC 0316044105CC 2808 000100010000 dID 0 : Engine stopped
    121 1 : Engine about to be stopped
    122 2 : Engine about to be started
    123 3 : Engine operated or operating
    124 4 : Generating power or load driving
    125 6 : Revving up in P position
    126 MG1 Inverter Temperature 8216F101CD 0316044105CD 2808 00010001FFCE Ti1 +/- XX °C
    127 MG1 Inverter Temperature 8216F101CD 0316044105CD 2808 00090005FFC6 Ti1 +/- XX °F
    128 MG2 Inverter Temperature 8216F101CD 0316044105CD 3008 00010001FFCE Ti2 +/- XX °C
    129 MG2 Inverter Temperature 8216F101CD 0316044105CD 3008 00090005FFC6 Ti2 +/- XX °F
    130 MG1 Temperature 8216F101CE 0316044105CE 2808 00010001FFCE TM1 +/- XX °C
    131 MG1 Temperature 8216F101CE 0316044105CE 2808 00090005FFC6 TM1 +/- XX °F
    132 MG2 Temperature 8216F101CE 0316044105CE 3008 00010001FFCE TM2 +/- XX °C
    133 MG2 Temperature 8216F101CE 0316044105CE 3008 00090005FFC6 TM2 +/- XX °F
    134 Motor Current V 8216F101CF 0316044105CF 2810 000100010000 M2v +/- XXX A (need to multiply by 2)
    135 Motor Current W 8216F101CF 0316044105CF 3810 000100010000 M2w +/- XXX A (need to multiply by 2)
    136 Generator Current V 8216F101D0 0316044105D0 2810 000100010000 M1v +/- XXX A (need to divide by 2)
    137 Generator Current W 8216F101D0 0316044105D0 3810 000100010000 M1w +/- XXX A (need to divide by 2)
    138 HV Battery Voltage 8216F101D1 0316044105D1 2808 000200010000 btV XXX V
    139 HV Battery Current 8216F101D2 0316044105D2 2810 000200010000 BTA +/- XXX A
    140 Shift Sensor 2 8216F101D3 0316844105D3 2810 000100050000 spS P : approx. 0.5 V
    141 R : approx. 2.8 V
    142 N : approx. 3.4 V
    143 D : approx. 4.0 V
    144 B : approx. 4.5 V
    145 Shift Sensor 1 8216F101D4 0316044105D4 2808 000100010000 spM P : 1
    146 R : 2
    147 N : 4
    148 D : 8
    149 B : 16
    150 Acceleration Sensor Main 8216F101D5 0316844105D5 2808 000100050000 acM X.X V
    151 Acceleration Sensor Sub 8216F101D5 0316844105D5 3008 000100050000 acS X.X V
    152 Battery Cell Temperature Max 8216F101D6 0316044105D6 2808 000100010000 Thi +/- XX °C
    153 Battery Cell Temperature Max 8216F101D6 0316044105D6 2808 000900050020 Thi +/- XX °F
    154 Battery Cell Temperature Min 8216F101D6 0316044105D6 3008 000100010000 Tlo +/- XX °C
    155 Battery Cell Temperature Min 8216F101D6 0316044105D6 3008 000900050020 Tlo +/- XX °F
    156 Vehicle Speed (Similar to KPH) 8216F101D7 0316044105D7 2808 000200010000 kph XXX kmh
    157 Vehicle Speed (Similar to MPH) 8216F101D7 0316044105D7 2808 000500040000 mph XXX mph
    158 Auxiliary Battery Voltage 8216F101D8 0316844105D8 2808 002800330000 vLT XX.X V
    159 INFO. Code 1 8216F101DF 0316044105DF 2810 000100010000 ic1 XXX
    160 # Codes 8216F101E1 0316044105E1 2810 000100010000 #hc XXXX count
    161 XTEST SW 8216F101EC 0316244105EC 2801 000100010000 XTH XTEST switch signal
    162 ECU Type 8216F101FE 0316044105FE 2F01 000100010000 het ECU Type
    163 HV DTC 1 (emission related) 8116F103 03161443 2010 000100010000 hc1 XXXX hex.
    164 HV DTC 2 (emission related) 8116F103 03161443 3010 000100010000 hc2 XXXX hex.
    165 HV DTC 3 (emission related) 8116F103 03161443 4010 000100010000 hc3 XXXX hex.
    166 HV DTC 1 (emission & non-emission related) 8316F113FF00 03161453 2010 000100010000 HC1 XXXX hex.
    167 HV DTC 2 (emission & non-emission related) 8316F113FF00 03161453 3010 000100010000 HC2 XXXX hex.
    168 HV DTC 3 (emission & non-emission related) 8316F113FF00 03161453 4010 000100010000 HC3 XXXX hex.
    169 MIL illumination 82D5F10101 03D524410501 2801 000100010000 MIL OFF / ON
    170 No. of Battery DTCs 82D5F10101 03D504410501 2907 000100010000 #BC XXX count
    171 No. of Battery Block 82D5F1016F 03D50441056F 2808 000100010000 #BB XX count
    172 State-of-Charge 82D5F10191 03D584410591 2808 000500010000 soc XX.X %
    173 Onboard Charge Time 82D5F10197 03D504410597 2810 000100010000 noc XXXX (cumulative no. of times of on-board uniform charging)
    174 Battery Low Time 82D5F10198 03D504410598 2810 000100010000 nlo XXXX (cumulative no. of times of low uniform charging)
    175 DC Inhibit Time 82D5F10199 03D504410599 2810 000100010000 dcI XXXX (Accumulated time of DC Inhibit)
    176 Estimate of Ex Chrg Hour 82D5F1019A 03D58441059A 2810 00010001FFDC ecH XX Hr (Extimation of time to finish off board charging)
    177 Ignition Off Hour 82D5F1019B 03D50441059B 2810 000100010000 igH XX Hr (Avg. time of IG OFF)
    178 Ignition On Hour 82D5F1019C 03D54441059C 2810 000100010000 inH X.XX Hr (Avg. time of IG ON)
    179 HV Battery Current 82D5F101A3 03D5044105A3 2810 00010064FF80 btA +/- XXX A
    180 HV Battery Current (-99.9A to 999A only) 82D5F101A3 03D5844105A3 2810 0001000AFB00 bta +/- XX.X A
    181 Battery Block 1 Voltage 82D5F101A4 03D5444105A4 2810 000100010000 V01 XX.X V
    182 Battery Block 2 Voltage 82D5F101A4 03D5444105A4 3810 000100010000 V02 XX.X V
    183 Battery Block 3 Voltage 82D5F101A5 03D5444105A5 2810 000100010000 V03 XX.X V
    184 Battery Block 4 Voltage 82D5F101A5 03D5444105A5 3810 000100010000 V04 XX.X V
    185 Battery Block 5 Voltage 82D5F101A6 03D5444105A6 2810 000100010000 V05 XX.X V
    186 Battery Block 6 Voltage 82D5F101A6 03D5444105A6 3810 000100010000 V06 XX.X V
    187 Battery Block 7 Voltage 82D5F101A7 03D5444105A7 2810 000100010000 V07 XX.X V
    188 Battery Block 8 Voltage 82D5F101A7 03D5444105A7 3810 000100010000 V08 XX.X V
    189 Battery Block 9 Voltage 82D5F101A8 03D5444105A8 2810 000100010000 V09 XX.X V
    190 Battery Block 10 Voltage 82D5F101A8 03D5444105A8 3810 000100010000 V10 XX.X V
    191 Battery Block 11 Voltage 82D5F101A9 03D5444105A9 2810 000100010000 V11 XX.X V
    192 Battery Block 12 Voltage 82D5F101A9 03D5444105A9 3810 000100010000 V12 XX.X V
    193 Battery Block 13 Voltage 82D5F101AA 03D5444105AA 2810 000100010000 V13 XX.X V
    194 Battery Block 14 Voltage 82D5F101AA 03D5444105AA 3810 000100010000 V14 XX.X V
    195 Battery Block 15 Voltage 82D5F101AB 03D5444105AB 2810 000100010000 V15 XX.X V
    196 Battery Block 16 Voltage 82D5F101AB 03D5444105AB 3810 000100010000 V16 XX.X V
    197 Battery Block 17 Voltage 82D5F101AC 03D5444105AC 2810 000100010000 V17 XX.X V
    198 Battery Block 18 Voltage 82D5F101AC 03D5444105AC 3810 000100010000 V18 XX.X V
    199 Battery Block 19 Voltage 82D5F101AD 03D5444105AD 2810 000100010000 V19 XX.X V
    200 Lowest Battery Block Voltage 82D5F101AE 03D5444105AE 2810 000100010000 Vlo XX.X V
    201 Lowest Battery Block Number 82D5F101AE 03D5044105AE 3808 000100010000 blo XX
    202 Highest Battery Block Voltage 82D5F101AF 03D5444105AF 2810 000100010000 Vhi XX.X V
    203 Highest Battery Block Number 82D5F101AF 03D5044105AF 3808 000100010000 bhi XX
    204 Battery Inhaling Air Temperature 82D5F101B2 03D5044105B2 2808 00010001FFD8 TBi +/- XX °C
    205 Battery Inhaling Air Temperature 82D5F101B2 03D5044105B2 2808 00090005FFD8 TBi +/- XX °F
    206 Battery High Time 82D5F101B4 03D5044105B4 2810 000100010000 nhi XXXX (Cumulative no. of times of too high battery voltage)
    207 VMF Fan Voltage 82D5F101B5 03D5844105B5 2808 00C800FF0000 vmf XX.X V
    208 Auxiliary Battery Voltage 82D5F101B7 03D5844105B7 2808 002800330000 vlt XX.X V
    209 WIN Control Power 82D5F101B9 03D5844105B9 2808 00020001FED4 pwi - XX.X kW
    210 WOUT Control Power 82D5F101BA 03D5844105BA 2808 000200010000 pwo XX.X kW
    211 Delta State-of-Charge 82D5F101BC 03D5844105BC 2808 000500010000 dSC XX.X %
    212 SBL Fan Stop Request 82D5F101C1 03D5244105C1 2B01 000100010000 SBL SBL cooling fan stop request signal
    213 EQTR Charge Start Sig 82D5F101C2 03D5244105C2 2E01 000100010000 ECS EQTR uniform charging start signal
    214 EQC0 Front Relay 82D5F101C2 03D5244105C2 2D01 000100010000 EFR EQC0 dead front relay
    215 CCTL 82D5F101C2 03D5244105C2 2C01 000100010000 CCT CFRS outer air intake request signal
    216 Cooling Fan Lo 82D5F101C2 03D5244105C2 2B01 000100010000 FLo OFF / ON
    217 Cooling Fan Mid 82D5F101C2 03D5244105C2 2A01 000100010000 FMi OFF / ON
    218 Cooling Fan Hi 82D5F101C2 03D5244105C2 2901 000100010000 FHi OFF / ON
    219 Cooling Fan Speed 82D5F101C2 03D5044105C2 2903 000100010000 Fan Off : 0
    220 Low : 1
    221 Mid : 2
    222 High : 4
    223 Normal Status 82D5F101C3 03D5244105C3 2F01 000100010000 NOR Normal status
    224 Pre Onboard Charge 82D5F101C3 03D5244105C3 2D01 000100010000 POC Pre-On-board charging status
    225 Onboard Charge Status 82D5F101C3 03D5244105C3 2C01 000100010000 OCS Outside uniform charging status
    226 Off Ave Charge Status 82D5F101C3 03D5244105C3 2901 000100010000 FCS Outer charging status
    227 Battery Block 1 Resistance 82D5F101CA 03D5044105CA 2808 000100010000 R01 XX mOhm
    228 Battery Block 2 Resistance 82D5F101CA 03D5044105CA 3008 000100010000 R02 XX mOhm
    229 Battery Block 3 Resistance 82D5F101CA 03D5044105CA 3808 000100010000 R03 XX mOhm
    230 Battery Block 4 Resistance 82D5F101CA 03D5044105CA 4008 000100010000 R04 XX mOhm
    231 Battery Block 5 Resistance 82D5F101CB 03D5044105CB 2808 000100010000 R05 XX mOhm
    232 Battery Block 6 Resistance 82D5F101CB 03D5044105CB 3008 000100010000 R06 XX mOhm
    233 Battery Block 7 Resistance 82D5F101CB 03D5044105CB 3808 000100010000 R07 XX mOhm
    234 Battery Block 8 Resistance 82D5F101CB 03D5044105CB 4008 000100010000 R08 XX mOhm
    235 Battery Block 9 Resistance 82D5F101CC 03D5044105CC 2808 000100010000 R09 XX mOhm
    236 Battery Block 10 Resistance 82D5F101CC 03D5044105CC 3008 000100010000 R10 XX mOhm
    237 Battery Block 11 Resistance 82D5F101CC 03D5044105CC 3808 000100010000 R11 XX mOhm
    238 Battery Block 12 Resistance 82D5F101CC 03D5044105CC 4008 000100010000 R12 XX mOhm
    239 Battery Block 13 Resistance 82D5F101CD 03D5044105CD 2808 000100010000 R13 XX mOhm
    240 Battery Block 14 Resistance 82D5F101CD 03D5044105CD 3008 000100010000 R14 XX mOhm
    241 Battery Block 15 Resistance 82D5F101CD 03D5044105CD 3808 000100010000 R15 XX mOhm
    242 Battery Block 16 Resistance 82D5F101CD 03D5044105CD 4008 000100010000 R16 XX mOhm
    243 Battery Block 17 Resistance 82D5F101CE 03D5044105CE 2808 000100010000 R17 XX mOhm
    244 Battery Block 18 Resistance 82D5F101CE 03D5044105CE 3008 000100010000 R18 XX mOhm
    245 Battery Block 19 Resistance 82D5F101CE 03D5044105CE 3808 000100010000 R19 XX mOhm
    246 Battery Temperature Sensor 1 82D5F101D0 03D5044105D0 2808 00010001FFD8 TS1 +/- XX °C
    247 Battery Temperature Sensor 1 82D5F101D0 03D5044105D0 2808 00090005FFD8 TS1 +/- XX °F
    248 Battery Temperature Sensor 2 82D5F101D0 03D5044105D0 3008 00010001FFD8 TS2 +/- XX °C
    249 Battery Temperature Sensor 2 82D5F101D0 03D5044105D0 3008 00090005FFD8 TS2 +/- XX °F
    250 Battery Temperature Sensor 3 82D5F101D0 03D5044105D0 3808 00010001FFD8 TS3 +/- XX °C
    251 Battery Temperature Sensor 3 82D5F101D0 03D5044105D0 3808 00090005FFD8 TS3 +/- XX °F
    252 Battery Temperature Sensor 4 82D5F101D1 03D5044105D1 2808 00010001FFD8 TS4 +/- XX °C
    253 Battery Temperature Sensor 4 82D5F101D1 03D5044105D1 2808 00090005FFD8 TS4 +/- XX °F
    254 The Stored DTC Num 82D5F101E1 03D5044105E1 2810 000100010000 #bc XXXX count
    255 XTEST SW 82D5F101EC 03D5244105EC 2801 000100010000 XTB XTEST switch signal
    256 Battery DTC 1 (emission related) 81D5F103 03D51443 2010 000100010000 bc1 XXXX hex.
    257 Battery DTC 2 (emission related) 81D5F103 03D51443 3010 000100010000 bc2 XXXX hex.
    258 Battery DTC 3 (emission related) 81D5F103 03D51443 4010 000100010000 bc3 XXXX hex.
    259 Battery DTC 1 (emission & non-emission related) 83D5F113FF00 03D51453 2010 000100010000 BC1 XXXX hex.
    260 Battery DTC 2 (emission & non-emission related) 83D5F113FF00 03D51453 3010 000100010000 BC2 XXXX hex.
    261 Battery DTC 3 (emission & non-emission related) 83D5F113FF00 03D51453 4010 000100010000 BC3 XXXX hex.
    262 80 80000000 0 0 TFC
    263 0 80000000 0 0 AVG
    My thanks to "vincent1449p" who worked tirelessly to assemble this table.
    #23 bwilson4web, Sep 13, 2012
  4. Cor
    Cor Junior Member
    2002 Prius
    Bob,
    Are you using Chassis Ground or the (more logical) Signal Ground for the first of the 4 connections in the Ethernet pigtail?
    I bought a male OBD2 plug and plan to wire it directly to an Ethernet cable to plug into the ScanGauge2
    Cor.
  5. bwilson4web
    16,224
    With the OBD connector, I would have used signal ground. Frame ground is probably OK but I have a lot of respect for common noise risks. The signal ground is not immune since it is also the current return path but I try to do 'the right thing.'
    In this case, the pins are the RJ-45 signals that come from the ScanGauge2 connector and if I remember correctly they provide only one ground that is also the signal and power ground. I don't remember ohming out their cable.
  6. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    w2co did ohm out the SGII cable in this thread. Pin 4 & 5 are tied together.
    Vincent
  7. bwilson4web
    16,224
    I intend to make this the 'go to' thread for OBD scanners working with the NHW11. So with that in mind, here is an excellent post about the TechStream/miniVCI (WARNING: assume there are virus in the software package!):
    Author: sterbenlicht
    Source: Offical TechStream software thread( settings and such) - Page 65 - TundraTalk.net - Toyota Tundra Discussion Forum
    Techstream ABCs and 123s: Reference point for all new users
    In the beginning, getting a personal working version of Techstream up and running was a tricky trial and error process. With more experience, some of the difficulties have been worked out. Fortunately for those just joining the group, it's easier now. But through the research process, you might not realize this. Here is the most basic start to finish setup process to save time and redundant Q&A exchanges.
    _____First_____
    Decide if you're installing this software on a 32 bit or 64 bit system. Some of the cables only have 32 bit drivers available, but tweaking the files to install them on 64 bit systems is possible if your abilities allow it. Depending on your confidence level and computer knowledge, your choice may already be made.
    To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
    • Open System by clicking the Start button Picture of the Start button,
      • right-clicking Computer, and
      • then clicking Properties.
    • Under System, you can view the system type.
    • If your computer is running Windows XP, do the following:
      • Click Start.
      • Right-click My Computer, and then click Properties.
      • If you don't see "x64 Edition" listed, then you're running the 32-bit version of Windows XP.
      • If "x64 Edition" is listed under System, you're running the 64-bit version of Windows XP.
    For the easier setup, go with a 32 bit windows system, a 64 bit system that you can run a 32 bit virtual machine on, or get one of the cables that have 64 bit drivers available. The simplest gig would be to find an old 32 bit XP laptop, or fork over another week's allowance for a Mongoose MFC so you can use Techstream on a 64 bit laptop easily. The descriptions for the cables and the available drivers for each is below. This decision will dictate which cable is best for you.
    _____Second_____
    Get yourself a cable. Getting Techstream won't do you any good without something to connect to a car. The cable you choose will set the stage for what extra work will be necessary to get the Techstream software functional.
    Drew Technologies Mongoose Pro MFC - Most expensive, but most likely highest quality and best supported of all aftermarket cable options. It will be any cable looking like this that you can find by searching for Mongoose Toyota Techstream etc on eBay and Amazon. 32 and 64 bit driver downloads are available on the manufacturer's website as well as in my link later in this post making for easy setup on any computer.
    http://i.imgur.com/AjAeb5C.jpg
    Drew Technologies Mongoose MFC (not Mongoose Pro) - Originally used by dealerships for Techstream Lite, they range in price from $50ish to about as much as about $400-500 depending on who is selling it and how ignorant they are about the item they have. Under $100 is an awesome price for any original Mongoose MFC though. They're much more difficult to track down online because there aren't as many of them out there and they have been discontinued for a while. 32 and 64 bit driver downloads are still available on the manufacturer's website as well as in my link later in this post making for easy setup on any computer.
    http://i.imgur.com/jQWGQkx.jpg
    Chinese MVCI - Most commonly used in these forums. These cables all look mostly the same although the font on the sticker seems to switch between normal and italic depending on where it's made, but they all usually say the same stuff on the label (Mini-VCI J2534 Standard OBDII Interface). Tons of these from all over the place (mostly China/Hong Kong) can be found on eBay and Amazon by just searching for Techstream. The available driver for these cables requires 32 bit system only. To tweak the files for 64 bit installation, refer to this thread post: http://www.toyota-4runner.org/genera...-8-64-bit.html
    If this is within your abilities, this is the most affordable cable and can be used on 32 bit and 64 bit systems.
    http://i.imgur.com/dOf99Yw.jpg
    XHorse MVCI - More affordable than the Mongoose products. The Chinese MVCI cable is a clone of the guts of this XHorse cable which is why their cables come with a disc with XHorse drivers.
    http://i.imgur.com/RVBmDyz.jpg
    All of these cables have been used by experienced DIY Techstream users and information for setting them up is readily available throughout this thread as well as in the instructions below.
    _____Third_____
    Now you need the software. Techstream software can be found all over the place, and there are many versions floating around in the various Techstream threads in different forums. The version updates are simply bug fixes and new model support. With bug fixes and version updates, new bugs arrive, so the biggest benefit to the newer versions is simply model support. The current latest version supports all models through 2014.
    Here (hopefully) is a consolidated source for the software as well as simple setup instructions and common cable drivers:
    Dropbox - Techstream
    If this link doesn't work, the availability of Techstream software is still pretty good. The sources for downloading it change, drop, respawn elsewhere and so on and so forth. You no longer need the patch files, TISKEY files or anything else to activate the software. Just follow the instructions below. Digging through the forum threads for links to download is the best start for the software if you can't get it here.
    _____Fourth_____
    Put it all together. This is information from the dropbox file available above but included here as a clean walk through.
    Setup Instructions for 32 bit MVCI, 32 bit XHORSE, and 32 or 64 bit Mongoose
    Please make sure your windows system is 32bit(Windows xp or 7) or that you have a Mongoose cable in which case you'll have the 32 or 64 bit driver for your cable as needed and these instructions will work fine, or refer here: http://www.toyota-4runner.org/genera...-8-64-bit.html for 64 bit MVCI/XHORSE cable installation instructions.
    step1. install "TIS_Techstream_Setup.exe"
    step2. After the installation, don't run the Techstream software.
    2.1 Install the cable driver for whichever cable you're using such as MVCI (xhorse) driver or Mongoose cable driver.
    2.2 If you ran the MVCI driver, this step will probably not be necessary, but other cable drivers may require you to change Techstream Function value. Now is the time to check the function setting by following these instructions:
    To activate any version of techstream, install whichever techstream .exe you choose, then open My Computer, C: Program files\Toyota Diagnostics \Techstream\Env
    open IT3System.ini file and scroll down to
    AVAILABLE FUNCTION SETTING
    Switch TISFunction=1 to TISFunction=0
    Click File, and Save.
    step3. Now run the Techstream software. Again in this case, the MVCI driver may bypass this, or if you opened Techstream before installing those drivers, these fields may show up. If they do:
    3.1 Select any region.
    3.2 Select the language you want,
    3.3 Put anything you want in the registration fields then OK.
    step4. Interface Select
    4.1 Click the [Setup] menu, then click the [VIM Select], then select the cable you're using in the drop down list of "Interface Setup", then Click [OK]
    _____Fifth_____
    Techstream? What is it good for?
    This software is used by the dealers to communicate directly with the on-board computers in all 1996-present Toyota, Scion, and Lexus models.
    Start by connecting to the vehicle. Turn your ignition key ON and click the Connect to Vehicle button at the left. Various fields may be required at the first connection prompt. TMMK product (Toyota Motor Manufacturing Kentucky) can be found on the inside of the door jamb if this applies. VSC or w/o VSC, Smark Key or w/o Smart Key, and Laser cruise or w/o Laser Cruise are some of the most common options asked for in this first menu. For newer models, the majority of these fields auto-populate, but for some older models, you may need to manually select all information for the vehicle you're connecting to.
    Once connected, you'll see a window displaying all of the ECUs your vehicle has. Most didn't realize their car had this many computers. All of these ECUs are expensive, so now you know exactly which parts some of those monthly car payments are paying for. The legend describes the status of each ECU. Yellow for all unknown ECU status, White means communication with ECU is normal, White with asterisk means the software either isn't connecting properly to this particular ECU, or your car doesn't have this ECU but it was included in the list like many generic ECUs are.
    From the start, they will all show up yellow because you haven't actually connected specifically to any of them yet. Running a health check (blue button near the left edge) will actually force the software to dig through each ECU one by one to check for stored information such as diagnostic trouble codes. You will probably wait a minute or two for this depending on how many ECUs your vehicle has. Having the vehicle running usually makes the health check more complete. The health check report will display a new window with the ECUs found and give you any Diagnostic Trouble Codes stored in each one. You can now click System Select near the top left tab to go back to the display of all ECUs and their status.
    Each ECU controls a particular part of the car whether it be the engine, the anti theft, or the tire pressure monitor system TPMS. Double clicking any ECU or clicking once and clicking the green arrow at the lower right will take you to the list of DTCs for that ECU. Hopefully you'll have none. Pending or Current codes are current problems. Pending means it has identified a problem, but the system may be set up to wait until it sees it again to confirm it is a problem that you should be made aware of by storing it as Current and turning the Check Engine Light or Message Indicator Light MIL on.
    You can also enter most ECUs and check the Utility button to the left of the screen. You may find individual customization options within each that you wish to change. If you aren't sure what it is, it's best to leave it alone.
    Techstream is capable of far far more than these simple things, but for first time use, those simple tasks will at least get you more familiar with the software and how to navigate it.
    NOTE: All new software should be treated as 'virus infected' until proven otherwise. If you can, use a standalone, virtual machine for this software with nothing else. Initially, turn off your network access to the Internet which can be turned on after some confidence it is safe. Pre-scan for virus before installing and after. Don't be afraid but cautious. Many of us use this software without a problem AFTER we checked it out.
    #27 bwilson4web, Jun 23, 2015
    mroberds and depriusoto like this.
  8. bwilson4web
    16,224
    The question was 'How to increase recording depth:'
    This removed any arbitrary limit.
    One thing I would caution is that it may interfere with the ability to export. I conducted a test using the Active Test option that enables one to command the fan speed, and the duration for that test defaulted to 20 minutes. I had it on max, and I used up the majority of the 20 minutes. That's the run in my post that I couldn't export. That data file included the charge cycle, some driving, etc.
    I address it by saving completely separate data files. I'll capture the charge cycle, save that, start a new file and run the discharge test.
    Nice work!
