03' Classic Prius and scanguageII
Discussion in 'Generation 1 Prius Discussion' started by w2co, Jan 30, 2010.
  1. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Thanks Tom, no hurry. I meant to attach the pinout for your reference in case you need it.
    Thanks Bob, your suspicion is logical. I was thinking of pin 15, L line, which is optional. Anyway, we will get more clues when Tom post his findings.
  2. bwilson4web
    16,540
    The maintenance manual indicates the NHW11 diagnostic bus has these signals:
    Column 1 Column 2 Column 3
    0 pin wire signal
    1 4 bare chassis ground
    2 5 dark blue signal ground
    3 7 yellow Bus Lined/Plus Gen
    4 13 white Tc - tied to CG (chassis ground) flashes two-digit codes
    5 14 brown Ts - tied to CG clears codes
    6 16 Battery voltage
    Toyota maintenance manual
    I have a male solder tail and female pig-tail and will make a pig-tail adapter for the AE ProLine. I should have results before the end of the week. This addresses the Layer 1 problem and hopefully will solve the 'spiking' problem.
  3. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Ok I went through and verified both cables and here is the result - the gen 1 doesn't use the "can" pins at all, they are disconnected in the "classic cable they recently sent. Otherwise all is the same, and it does work good now with no errors, good enough that I trust it to work when the wife is driving it...I instructed her to look at soc before parking from now on and make sure it's at least 57. With an 8 year old battery that is aging now we don't want to park it for very long with less than 50 anyway, that I suspect would be suicide, but it does hold the charge overnight so that's a good thing.
  4. bwilson4web
    16,540
    Perfect!
    Column 1 Column 2 Column 3 Column 4 Column 5
    0 pin wire signal
    1 2 add +SAE-J1850 (clock? arbitration state?) L-line
    2 4 bare chassis ground
    3 5 dark blue signal ground
    4 7 yellow Bus Lined/Plus Gen H-ISO9141 K-line[/B]
    5 10 add -SAE-J1850 (clock? state?)
    6 13 nc Tc - tied to CG (chassis ground) flashes two-digit codes
    7 14 nc Ts - tied to CG clears codes
    8 15 add -Bus lined/Plus Gen L-ISO9141 L-line[/B]
    9 16 red Battery voltage
    Toyota maintenance manual and w2co
    I misunderstood an earlier report that this was RS-232 like. Instead, I have a better understanding that only pins 7 and 15 were needed, the ISO 9141-2 lines.
    I tested my adapter this morning but it only had the K-line of ISO9141. The Ts and Tc lines were disconnected. When I say it didn't work, it failed to connect but there was one success. It didn't 'spike' the Prius and induce false codes!
    I also added a subminature jack to the connector shell and will wire up CG and Ts and Tc to the audio jack pins. This will allow a three-state toggle or two push-to-make switches and mini jack to work as the two-code flashing unit.
    FYI, I reverted to the manual configuration and drove into work, ~25 minutes, without a hang or data problem. In the past, I always had a 2-3 minute data capture before the first pause and a 15 minute data capture before the second pause.
    LATE THOUGHT: Looking at the datasheets for several ISO 9141 drivers, I may only need one additional signal called "ISO L-LINE". This is likely to be pin 15, ISO 9141, L-line . I'll test it tonight.
    joedirte likes this.
  5. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Hi Bob, yes it looks like all that's needed is a single 2pole toggle switch with center position open to read and clear codes. So the "can" lines were the problem, makes sense if it's non-can, then just don't connect any of the can signals. I agree there appears to be two differential pairs, one for clk and one for data, that would coincide with the "twisted pair" method of comms in gen1 as well. Who knows what is on pins 6 and 14 in the gen1, that's what was being spiked..
    Concerning "I also added a subminature jack to the connector shell and will wire up CG and Ts and Tc to the audio jack pins. This will allow a three-state toggle or two push-to-make switchs and mini jack to work as the two-code flashing unit."
    Keep in mind that with a jack like that you will have to "plug in or out" while the car is off. This is because when inserting the plug, it could momentarily spike those lines again. I like your idea on the two momentary push buttons, and I would just permanently wire them into the test box. Just my 2c.
  6. bwilson4web
    16,540
    The more I look at the interface circuits, the more it looks as if the L-line is not clock but just a line to indicate the bus is active. One stinkin' wire and my adapter probably would have worked.
    I found a Radio Shack part, 275-711, a center off, single-pole, double throw, switch that will be perfect for the Ts and Tc control. This looks to be a seriously useful addition to the OBD shell. TONIGHT!
    Since I will be adding the switch and cable, adding the L-line of ISO 9141 should complete the project, the brass board.
  7. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Bob, I changed my mind on the momentary buttons, they could be pressed at the same time causing who knows what. Stay with the three position toggle switch then there's no question.. Also when clearing the Tc line -I would only momentarily short it to gnd, don't hold it there for longer periods, after all this signal is generated by the ecu so we don't need to stress it. Who knows what value of pullup resistance they designed into this.
  8. vincent1449p
    894
    332
    Singapore
    OK, I made a custom adapter since only pin 1,6,7 & 8 are all that is needed. I've also added a 9V battery connector to supply power for offline editing/recording. There is a diode at Pin 8 to prevent the 12V from charging the 9V battery during plugging in the battery.
  9. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Thanks for that great idea Vincent. I have powered the scangauge w/external bench supply (unplugged from vehicle) just for this purpose - not having to power in the car w/ ign on..It runs down the 12v battery if you take too long editing etc. Good thought!
    Now to another question : since you seem to be the most experienced with scangauge on the gen1, how good is it at reading/clearing any dtc's that come up? I have not had any (real) dtc's yet while I've had the scangauge running. It would be very handy if away from home (and AE system) to be able to do that. Have you had any experiences with this and scangauge? My guess is it will only handle standard generic engine OBD codes and nothing from the HV or BATT or HYbrid vehicle ecu's. I think when Linear Logic states "reading and clearing codes" they mean only when it's connected to a CAN buss.
    But still it is a great tool to have on any GENx prius I would say.
    Thanks
  10. bwilson4web
    16,540
    Just a thought but how about incorporating the functions of the Toyota 'SST' tool that uses Tc and Ts to 'flash' two-digit codes and clear codes?
    Nothing more than a simple jumper to ground, this might provide a rapid fix.
  11. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Yes I plan on building a small interface box similar to vincents' above for the scangaugeII and will incorporate the 3-way switch and led for flashing the two digit codes. That will be great for gen1's.
    Not much time around here lately, but I'll work it in..
  12. vincent1449p
    894
    332
    Singapore
    Hi Tom,
    I've no experience either.
    Looking back at post #30, TexomaEV can read out 3006 & 3021 so I believe it is not limited to CAN bus. However, there is another DTC 1800 which is not documented in the repair manual so I wonder whether the DTC can be trusted?
  13. vincent1449p
    894
    332
    Singapore
    Hi Bob,
    I 've thought about that too but the SGII cable doesn't use pin 13 which means I can't modify at the RJ45 end, it has to be at the J1962 end. It is not easy to find OBDII socket and plug in Singapore, that is why I dropped the idea and went with RJ45 socket and LAN cable which I 've on hand.
  14. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    I've clipped the connection to #6 & #14 on the Scangauge II's cable, and so far, no more weird codes have popped up. I still need to install the momentary toggle switch to those pins to gnd though.
  15. vincent1449p
    894
    332
    Singapore
    After experimenting with more PIDs, I discovered a problem when monitoring 2 PIDs with the same [RXF] even though the [TXD] are different.
    Let's look at an e.g.:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8
    0 XGauge TXD RXF RXD MTH NAME Notes
    1 HV Battery Voltage 8216F101D1 044105D1 2808 000200010000 btV XXX Volts
    2 Battery Temperature Sensor 4 82D5F101D1 044105D1 2808 00010001FFD8 TS4 +/- XX °C
    The display can show 4 gauges at a time. The sequence of display seems to be as below:
    (1) Top Left (First)
    (2) Top Right
    (3) Bottom Left
    (4) Bottom Right (Last)
    If both the above gauges were to be selected, e.g. (2)btV & (3)TS4, only the one at the top of the sequence (2) get displayed, the other one (3) will be blank. However, since (3)TS4 has sent a request to the Battery ECU ($D5), a response from ($D5) will be received by SGII ($F1). When SGII use [RXF] to filter the responses, the 4th byte ($41) and the 5th byte ($D1) also matches the [RXF] of (2)btV. Since (2) is at the top of the scanning sequence, the data for TS4 get wrongly displayed at (2). As a result, the data at (2) starts to toggle rapidly between the actual data and the wrong data.
    Now, let's say I change (1) to display TS4. Since (1) is at the top of the scanning, (1) will start to toggle rapidly and (2) will be blank.
    To overcome this limitation, I 've reprogrammed all the [RXF] to add a 3rd criteria for the responding ECU.
    HV ECU ($16)
    1 Engine Coolant Temperature 8216F10105 031604410505 2808 00010001FFD8 °CWT +/- XX °C
    2 Engine Coolant Temperature 8216F10105 031604410505 2808 00090005FFD8 °FWT +/- XX °F
    3 Engine Speed 8216F1010C 03160441050C 2810 000100040000 RPM XXXX rpm
    4 Vehicle Speed 8216F1010D 03160441050D 2808 000100010000 KPH XXX kmh
    5 Vehicle Speed 8216F1010D 03160441050D 2808 000A00100000 MPH XXX mph
    6 Intake Air Temperature 8216F1010F 03160441050F 2808 00010001FFD8 °CIA +/- XX °C
    7 Intake Air Temperature 8216F1010F 03160441050F 2808 00090005FFD8 °FIA +/- XX °F
    8 Distance traveled with MIL on 8216F10121 031604410521 2810 000100010000 DML XXXXX km
    9 Distance traveled with MIL on 8216F10121 031604410521 2810 000A00100000 DML XXXXX miles
    10 MG2 RPM 8216F101C2 0316044105C2 2810 000100010000 M2R +/- XXXX rpm
    11 MG2 Torque 8216F101C2 0316044105C2 3810 000100010000 M2T +/- XXX Nm
    12 Regen Brake Execution Torque 8216F101C3 0316044105C3 2808 000A00100000 reT XXX Nm
    13 Regen Brake Request Torque 8216F101C3 0316044105C3 3008 000A00100000 rrT XXX Nm
    14 MG1 RPM 8216F101C4 0316044105C4 2810 000100010000 M1R +/- XXXX rpm
    15 MG1 Torque 8216F101C4 0316044105C4 3810 000100010000 M1T +/- XXX Nm
    16 Request Engine Power 8216F101C5 0316444105C5 2810 000100010000 Pe XX.XX kW
    17 Target Engine Revolution 8216F101C6 0316044105C6 2810 000100010000 ter XXXX rpm
    18 Engine Speed (similar to RPM) 8216F101C7 0316044105C7 2810 000100010000 rpm XXXX rpm
    19 Master Cylinder Control Torque 8216F101C8 0316044105C8 2810 000100010000 mcT - XXX Nm
    20 State-of-Charge 8216F101C9 0316844105C9 2808 00C800330000 soC XX.X %
    21 WOUT Control Power 8216F101CA 0316844105CA 2808 0010000A0000 Pwo XX.X kW
    22 WIN Control Power 8216F101CA 0316844105CA 3008 0010000A0000 Pwi XX.X kW
    23 Drive Situation ID 8216F101CC 0316044105CC 2808 000100010000 dID 0 : Engine stopped
    24 1 : Engine about to be stopped
    25 2 : Engine about to be started
    26 3 : Engine operated or operating
    27 4 : Generating power or load driving
    28 6 : Revving up in P position
    29 MG1 Inverter Temperature 8216F101CD 0316044105CD 2808 00010001FFCE Ti1 +/- XX °C
    30 MG1 Inverter Temperature 8216F101CD 0316044105CD 2808 00090005FFC6 Ti1 +/- XX °F
    31 MG2 Inverter Temperature 8216F101CD 0316044105CD 3008 00010001FFCE Ti2 +/- XX °C
    32 MG2 Inverter Temperature 8216F101CD 0316044105CD 3008 00090005FFC6 Ti2 +/- XX °F
    33 MG1 Temperature 8216F101CE 0316044105CE 2808 00010001FFCE TM1 +/- XX °C
    34 MG1 Temperature 8216F101CE 0316044105CE 2808 00090005FFC6 TM1 +/- XX °F
    35 MG2 Temperature 8216F101CE 0316044105CE 3008 00010001FFCE TM2 +/- XX °C
    36 MG2 Temperature 8216F101CE 0316044105CE 3008 00090005FFC6 TM2 +/- XX °F
    37 Motor Current V 8216F101CF 0316044105CF 2810 000100010000 M2v +/- XXX A
    38 Motor Current W 8216F101CF 0316044105CF 3810 000100010000 M2w +/- XXX A
    39 Generator Current V 8216F101D0 0316044105D0 2810 000100010000 M1v +/- XXX A
    40 Generator Current W 8216F101D0 0316044105D0 3810 000100010000 M1w +/- XXX A
    41 HV Battery Voltage 8216F101D1 0316044105D1 2808 000200010000 btV XXX V
    42 HV Battery Current 8216F101D2 0316044105D2 2810 000200010000 BTA +/- XXX A
    43 Shift Sensor 2 8216F101D3 0316844105D3 2810 000100050000 spS P : approx. 0.5 V
    44 R : approx. 2.8 V
    45 N : approx. 3.4 V
    46 D : approx. 4.0 V
    47 B : approx. 4.5 V
    48 Shift Sensor 1 8216F101D4 0316044105D4 2808 000100010000 spM P : 1
    49 R : 2
    50 N : 4
    51 D : 8
    52 B : 16
    53 Acceleration Sensor Main 8216F101D5 0316844105D5 2808 000100050000 acM X.X V
    54 Acceleration Sensor Sub 8216F101D5 0316844105D5 3008 000100050000 acS X.X V
    55 Battery Cell Temperature Max 8216F101D6 0316044105D6 2808 000100010000 Thi +/- XX °C
    56 Battery Cell Temperature Max 8216F101D6 0316044105D6 2808 000900050020 Thi +/- XX °F
    57 Battery Cell Temperature Min 8216F101D6 0316044105D6 3008 000100010000 Tlo +/- XX °C
    58 Battery Cell Temperature Min 8216F101D6 0316044105D6 3008 000900050020 Tlo +/- XX °F
    59 Vehicle Speed (Similar to KPH) 8216F101D7 0316044105D7 2808 000200010000 kph XXX kmh
    60 Vehicle Speed (Similar to MPH) 8216F101D7 0316044105D7 2808 000500040000 mph XXX mph
    Battery ECU ($D5)
    1 State-of-Charge 82D5F10191 03D584410591 2808 000A00020000 soc XX.X %
    2 Main Battery low 82D5F10197 03D504410597 2810 000100010000 nlo XXXXX
    3 No. of Battery DTCs 82D5F1019C 03D50441059C 2810 000100010000 #TC XXXXX
    4 HV Battery Current 82D5F101A3 03D5044105A3 2810 00010064FF80 btA +/- XXX A
    5 HV Battery Current (for <100A only) 82D5F101A3 03D5844105A3 2810 0001000AFB00 bta +/- XX.X A
    6 Battery Block 1 Voltage 82D5F101A4 03D5444105A4 2810 000100010000 V01 XX.X V
    7 Battery Block 2 Voltage 82D5F101A4 03D5444105A4 3810 000100010000 V02 XX.X V
    8 Battery Block 3 Voltage 82D5F101A5 03D5444105A5 2810 000100010000 V03 XX.X V
    9 Battery Block 4 Voltage 82D5F101A5 03D5444105A5 3810 000100010000 V04 XX.X V
    10 Battery Block 5 Voltage 82D5F101A6 03D5444105A6 2810 000100010000 V05 XX.X V
    11 Battery Block 6 Voltage 82D5F101A6 03D5444105A6 3810 000100010000 V06 XX.X V
    12 Battery Block 7 Voltage 82D5F101A7 03D5444105A7 2810 000100010000 V07 XX.X V
    13 Battery Block 8 Voltage 82D5F101A7 03D5444105A7 3810 000100010000 V08 XX.X V
    14 Battery Block 9 Voltage 82D5F101A8 03D5444105A8 2810 000100010000 V09 XX.X V
    15 Battery Block 10 Voltage 82D5F101A8 03D5444105A8 3810 000100010000 V10 XX.X V
    16 Battery Block 11 Voltage 82D5F101A9 03D5444105A9 2810 000100010000 V11 XX.X V
    17 Battery Block 12 Voltage 82D5F101A9 03D5444105A9 3810 000100010000 V12 XX.X V
    18 Battery Block 13 Voltage 82D5F101AA 03D5444105AA 2810 000100010000 V13 XX.X V
    19 Battery Block 14 Voltage 82D5F101AA 03D5444105AA 3810 000100010000 V14 XX.X V
    20 Battery Block 15 Voltage 82D5F101AB 03D5444105AB 2810 000100010000 V15 XX.X V
    21 Battery Block 16 Voltage 82D5F101AB 03D5444105AB 3810 000100010000 V16 XX.X V
    22 Battery Block 17 Voltage 82D5F101AC 03D5444105AC 2810 000100010000 V17 XX.X V
    23 Battery Block 18 Voltage 82D5F101AC 03D5444105AC 3810 000100010000 V18 XX.X V
    24 Battery Block 19 Voltage 82D5F101AD 03D5444105AD 2810 000100010000 V19 XX.X V
    25 Lowest Battery Block Voltage 82D5F101AE 03D5444105AE 2810 000100010000 Vlo XX.X V
    26 Lowest Battery Block Number 82D5F101AE 03D5044105AE 3808 000100010000 blo XX
    27 Highest Battery Block Voltage 82D5F101AF 03D5444105AF 2810 000100010000 Vhi XX.X V
    28 Highest Battery Block Number 82D5F101AF 03D5044105AF 3808 000100010000 bhi XX
    29 Battery Inhaling Air Temperature 82D5F101B2 03D5044105B2 2808 00010001FFD8 TBi +/- XX °C
    30 Battery Inhaling Air Temperature 82D5F101B2 03D5044105B2 2808 00090005FFD8 TBi +/- XX °F
    31 Main Battery high 82D5F101B4 03D5044105B4 2810 000100010000 nhi XXXXX
    32 Delta State-of-Charge 82D5F101BC 03D5844105BC 2808 000A00020000 dSC XX.X %
    33 Battery Block 1 Resistance 82D5F101CA 03D5044105CA 2808 000100010000 R01 XX milli-ohms
    34 Battery Block 2 Resistance 82D5F101CA 03D5044105CA 3008 000100010000 R02 XX milli-ohms
    35 Battery Block 3 Resistance 82D5F101CA 03D5044105CA 3808 000100010000 R03 XX milli-ohms
    36 Battery Block 4 Resistance 82D5F101CA 03D5044105CA 4008 000100010000 R04 XX milli-ohms
    37 Battery Block 5 Resistance 82D5F101CB 03D5044105CB 2808 000100010000 R05 XX milli-ohms
    38 Battery Block 6 Resistance 82D5F101CB 03D5044105CB 3008 000100010000 R06 XX milli-ohms
    39 Battery Block 7 Resistance 82D5F101CB 03D5044105CB 3808 000100010000 R07 XX milli-ohms
    40 Battery Block 8 Resistance 82D5F101CB 03D5044105CB 4008 000100010000 R08 XX milli-ohms
    41 Battery Block 9 Resistance 82D5F101CC 03D5044105CC 2808 000100010000 R09 XX milli-ohms
    42 Battery Block 10 Resistance 82D5F101CC 03D5044105CC 3008 000100010000 R10 XX milli-ohms
    43 Battery Block 11 Resistance 82D5F101CC 03D5044105CC 3808 000100010000 R11 XX milli-ohms
    44 Battery Block 12 Resistance 82D5F101CC 03D5044105CC 4008 000100010000 R12 XX milli-ohms
    45 Battery Block 13 Resistance 82D5F101CD 03D5044105CD 2808 000100010000 R13 XX milli-ohms
    46 Battery Block 14 Resistance 82D5F101CD 03D5044105CD 3008 000100010000 R14 XX milli-ohms
    47 Battery Block 15 Resistance 82D5F101CD 03D5044105CD 3808 000100010000 R15 XX milli-ohms
    48 Battery Block 16 Resistance 82D5F101CD 03D5044105CD 4008 000100010000 R16 XX milli-ohms
    49 Battery Block 17 Resistance 82D5F101CE 03D5044105CE 2808 000100010000 R17 XX milli-ohms
    50 Battery Block 18 Resistance 82D5F101CE 03D5044105CE 3008 000100010000 R18 XX milli-ohms
    51 Battery Block 19 Resistance 82D5F101CE 03D5044105CE 3808 000100010000 R19 XX milli-ohms
    52 Battery Temperature Sensor 1 82D5F101D0 03D5044105D0 2808 00010001FFD8 TS1 +/- XX °C
    53 Battery Temperature Sensor 1 82D5F101D0 03D5044105D0 2808 00090005FFD8 TS1 +/- XX °F
    54 Battery Temperature Sensor 2 82D5F101D0 03D5044105D0 3008 00010001FFD8 TS2 +/- XX °C
    55 Battery Temperature Sensor 2 82D5F101D0 03D5044105D0 3008 00090005FFD8 TS2 +/- XX °F
    56 Battery Temperature Sensor 3 82D5F101D0 03D5044105D0 3808 00010001FFD8 TS3 +/- XX °C
    57 Battery Temperature Sensor 3 82D5F101D0 03D5044105D0 3808 00090005FFD8 TS3 +/- XX °F
    58 Battery Temperature Sensor 4 82D5F101D1 03D5044105D1 2808 00010001FFD8 TS4 +/- XX °C
    59 Battery Temperature Sensor 4 82D5F101D1 03D5044105D1 2808 00090005FFD8 TS4 +/- XX °F
  16. bwilson4web
    16,540
    Rats! You made me read the Scangauge programming manual. Now I somewhat understand the syntax. <GERRRRRR> Do you have any idea how long ago I programmed in hex using toggle switches? . . . 1974!!! And I got a check for $600 for doing it!
    Ok, it looks like you figured it out but this is how I see it:
    • RXF - needs to have a source ECU identifier that appears to be offset "03" and then match to the second byte of TXD, the destination ECU
    This is how I see the corrected entry:
    1 HV Battery Voltage 8216F101D1 0316044105D1 2808 000200010000 btV XXX Volts
    2 Battery Temperature Sensor 4 82D5F101D1 03D5044105D1 2808 00010001FFD8 TS4 +/- XX °C
    The blue hex in RXF provides the flag to match the response to the data request. This should always be the case:
    03zz (RXF first match byte) = 82zzF1 (TXD first hex bytes)
    In one respect, your PID table provides exactly the data needed to understand how the Auto Enginuity is broke. More importantly, I can now quickly scan their values versus the ones in your table and confirm which ones match.
    Thanks,
  17. vincent1449p
    894
    332
    Singapore
    Hi Bob,
    Thanks for taking the time to lookup the SG manual.:)
    My apologies for leaving out too many details. Pls allow me to explain again.
    Let's go back to my e.g.
    The original RXF has only 2 criteria:
    0 Name RXF Response String Offset 1 Match 1 Offset 2 Match 2
    1 btV 044105D1 83F11641D18D29
    04​
    41​
    05​
    D1​
    2 TS4 044105D1 83F1D541D14AA5
    04​
    41​
    05​
    D1​
    Offset 1 says the 4th byte (starting with the 1st byte being 01) must be 41 (Match 1).
    Offset 2 says the 5th byte must be D1.
    Since both Match 1 & Match 2 meet the criteria, wrong data are being displayed.
    The corrected RXF has a 3rd criteria:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8 Column 9
    0 Name RXF Response String Offset 1 Match 1 Offset 2 Match 2 Offset 3 Match 3
    1 btV 0316044105D1 83F11641D18D29
    03​
    16​
    04​
    41​
    05​
    D1​
    2 TS4 03D5044105D1 83F1D541D14AA5
    03​
    D5​
    04​
    41​
    05​
    D1​
    Now all 3 criteria must be matched so will avoid the previous problem.
    One more thing to add. The SG manual also mentions Special RXF values.
    When you append extra characters to RXF, it will affect this special values. For e.g.:
    0 XGauge RXF Remarks
    1 State-of-Charge 04418591 Old values
    2 State-of-Charge 03D584410591 New values
    Pls take note the special characters must remain in the same position.
  18. bwilson4web
    16,540
    Ah, I see.
    So the range of offsets are 0-127 and the upper nibble is used for some other SG specific operation? That clears up one of the RXF fields.
    This discussion of SG, my testing of OBD scanners, Auto Enginuity's wretched support and my audio recording of ISO-9141 has got me thinking of a new project:
    • Audio based, laptop OBD scanner for ISO-9141 vehicles
    A simple set of linear amplifiers, OBD connector, stereo audio input and output could with the right software could become a poor man's OBD scanner. The beauty of this approach is the software could also do a 'survey' scan of a vehicle's OBD. This survey of a range of ECUs combined with a survey of a range of commands followed by any responses would let the vehicle dump the non-stateful status.
    Having identified the responding ECUs and their range of values, we can then conduct operational and non-operational tests to find those that change and back-door into decoding what is actually there.
    Implemented as 'open source,' we multiply the hands and minds available so we can literally 'take back' the information about the vehicles we own. In theory, it would also be a powerful OBD diagnostic but that is another branch.
    Fortunately, I have enough on my plate that this will have to wait. But one last question:
    Does the SG allow bi-directional configuration and reading of the settings?
    If it does, a program could just use the SG for the interface device and conduct the survey more efficiently than manual programming.
  19. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Hi Bob,
    Concerning "Does the SG allow bi-directional configuration and reading of the settings?"
    I believe that the SG is mainly a monitoring device, but supposedly it can reset any codes that come up as well, that is a rather simple system toggle, but one could also just disconnect the 12V batt. to do this as well. When that time comes will probably use AE to better document the failure first before any reset is done. As far as actually controlling any specific systems directly - I highly doubt it, AE would work better then for what it's worth. So we have all these tools that some do this and some do that, but none really do it all except for that high $$ system. We'll manage I suppose.
  20. bwilson4web
    16,540
    I wasn't clear.
    I don't know how SG programming is done. I was wondering if a program could be written on a laptop that could use the SG as a device to poll different codes and responses . . . a general purpose OBD interface.
