Airbag light on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HDuncan, Apr 13, 2015.
  1. HDuncan
    HDuncan Member
    122
    30
    Just bought a new 2006 prius and the airbag light is stuck on. Previous owner says it was caused when he installed a new clockspring and broke it by overturning the wheel. He didnt have the computer needed to clear the code, and says the airbag light wont go away until the code is cleared with an SRS scanner.
    Is there a way to ensure the clockspring/spiral wire/airbag are installed and operational, and to clear this airbag light?
    Thanks!
  2. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    The cheapest way, and a way of avoiding trips to the dealer to read any future codes is to buy a Mini VCI with Techstream software from Ebay (about $30). This with an old preferably Windows XP laptop will be capable of clearing and reading any Toyota, Lexus, and Scion codes as well as all service tasks.
    This will not only clear the codes, but it will inform you if the problems still exist.
    John (Britprius)
  3. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Check every button on the steering wheel and horn operation. Turn the wheel from stop to stop and make sure it moves freely. You will still need a mini VCI or comparable code reader to see what code is current and if it can be cleared or there is still a problem.
    valde3 likes this.
  4. HDuncan
    HDuncan Member
    122
    30
    Will this work?
  5. Patrick Wong
    18,200
    6,464
    Yes, that is what I bought. The price is a bit lower compared to when I bought my unit.
  6. HDuncan
    HDuncan Member
    122
    30
    Ok, I think I'll order the scanner..
    In the mean time I tried to use the DTC clearing technique you mentioned on another thread about airbag lights.. I couldn't get my airbag light to flash but other lights would.
    Here's the light, it's just solid everyday:
    Here's the jumper I made out of solder:
    And here are the three Amber lights that were flashing, but the airbag light remained solid:
    Sezy likes this.
  7. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    270
    550
    Dallas -Fort Worth
    If your seats are airbag equipped (they will have SRS tags sewn into them) make sure that the yellow plugs under the seats are securely connected. If it is a connection issue the light will clear on it's own when you fix the problem. I had this issue because I replaced the seats in an 05' but the new seats did not have airbags so there were none to plug in.
    HDuncan likes this.
  8. HDuncan
    HDuncan Member
    122
    30
    I checked and unfortunately all is well
    Under the seat :(
    Sezy likes this.
  9. HDuncan
    HDuncan Member
    122
    30
    So, I'm sitting here with a laptop I borrowed from a friend because the text stream cable only seems to work on windows 32 bit machines. As I'm installing the driver, antivirus is going nuts..
    I whisper gently to the laptop "trust me, it will all be over soon"
    I've installed, uninstalled, reinstalled the driver, software, and have plugged in the cable to every USB port I can find.
    I keep getting "error, unable to connect to the VIM".
    I've tried version 7, version 10... nothing works.
    Any ideas?
  10. JC91006
    16,470
    8,385
    Maybe your anti virus needs to be disabled when you install the driver and program.
  11. HDuncan
    HDuncan Member
    122
    30
    I just uninstalled AVG.
    Restarted
    Installed tech stream 10
    Installed TIS key
    Installed mvci driver
    Restarted
    Plugged in cable to car
    Pressed power button on car twice without brake
    Plugged vci into laptop - recognized as serial converter
    Opened techstream
    Clicked "connect to vehicle"
    Says "initializing usb communication"
    Throws up application error
    Close techstream
    Reopen techstream
    Click connect to vehicle
    Initializing USB comm
    Error "unable to connect to VIM"
    Change Configuration to : North America, English, "111" in all reg fields, hit Ok
    Initializing USB Comm..
    "Connecting to vehicle"
    That window just vanishes.
    Program unresponsive
    Ctrl alt del kill techstream
    Reopen techstream
    Run cable Check
    kill/reopen
    Techstream won't open
    Restart
    Open techstream
    Connect
    Initializing usb
    Some kind of memory error
    cry and eat sandwich
    Try generic odbII
    initializing usb
    Memory error
    Configure change back to 'Murica
    Generic ODB II
    INITIALIZING USB
    MEMORY ERROR (always mention main menu .exe)
    Don't care
    close program
    Reopen
    Won't open.
    homicidal thoughts
    Restart
    Debating whether to end my life or another sandwich.
  12. JC91006
    16,470
    8,385
    This is odd, I didn't have any issues with the 2 that I Did. I didn't have antivirus and I installed driver first, then program.
    I wonder if your cable is bad or obd is messed up
    Try connecting to your other prius
    HDuncan likes this.
  13. HDuncan
    HDuncan Member
    122
    30
    Tried on other Prius and got similar runtime error
    Installing older version of techstream
  14. JC91006
    16,470
    8,385
    Your car has to be on where the dash lights up, Windows roll up
    HDuncan likes this.
  15. HDuncan
    HDuncan Member
    122
    30
    It is, I press power twice so there are ABS VSC check engine lights on dash, windows work, but no engine activity because I didn't press brakes
    Is that correct?
  16. JC91006
    16,470
    8,385
    Yeah that is correct. So it's a program driver error or cable error
    HDuncan likes this.
  17. HDuncan
    HDuncan Member
    122
    30
    Uninstalled and reinstalled driver from a different .exe.....
    Same issue.
    Going to find a different computer to infect.
  18. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
  19. HDuncan
    HDuncan Member
    122
    30
  20. JC91006
    16,470
    8,385
    Just think, you'll be a Toyota (Prius) expert by the time you're done with this thing.
    HDuncan likes this.
