Dismiss Notice
The Prius Prime may be the best Prius ever. Find out why in PriusChat's first drive review from Japan.
Am I understanding this correct?
Discussion in 'Prius c Technical Discussion' started by South_Bay_Surfer, Mar 26, 2012.
  1. South_Bay_Surfer
    South_Bay_Surfer New Member
    Los Angeles
    Drive - Regular driving
    B - Down hill driving store up Hybrid battery.
    EV Mode - Traffic 25 MPH and below.
    Eco Mode - Prevents vehicle from fully opening up when driving to save energy.
  2. ksstathead
    ksstathead Active Member
    1,244
    237
    Kansas
    Not quite:
    Drive ok
    EV mode mostly to move around the parking lot or driveway. In certain conditions you can drive EV up to 25 mph, but remember, that energy comes from gasoline, so you can over do the EV.
    B mode is only to waste energy coming down a mountain when your battery will be full at the bottom. It saves your friction brakes compared to Drive, but reduces regen by spinning the engine to use the friction to slow the car. In normal down hills and decelerations, use Drive and your brake pedal to maximize regen.
    Eco mode and normal mode (and Power mode on the liftbacks) each offer the same power, but map the pedal response differently for a different feel. Eco makes you push the throttle further for the same response. Eco also moderates climate control in certain conditions to reduce energy loss, such as at idle.
    5 people like this.
  3. tlhamon
    tlhamon New Member
    30
    Flat Rock, MI
    I agree that the "B" is confusing. But, since the car has a CVT it doesn't really have a low gear like a normal transmission. I assume there is some type of limiter on the conical gears that prevents the belts from moving along so your engine has more torque (like a downshift). In other words, it allows the engine to rev higher without moving faster, thus the engine breaking. I've owned a lot of cars, and I can't say I have ever put any of them in "L" other than by mistake.
  4. meehow09
    meehow09 New Member
    42
    Chicago
    I can drive in EV mode up to 39mph.
  5. JimN
    JimN Let the games begin!
    6,505
    750
    South Jersey
    B mode isn't needed on the mountains I've encountered in VA or PA, all probably under 3000 feet. You are probably using it on Mt. Washington or Pike's Peak.
  6. kocho
    kocho Member
    134
    Maryland
    Note that the cvt gears on the prii are not conical and there are no belts in it (or for that matter anywhere in this engine, except the timing chain). This is a "power split" design as opposed to the conical-belt style cvt that Honda and some others use.
  7. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    The Prius PSD design is an eCVT. There are no belts etc. All "torque conversion" and controlling the speed of the ICE whether for acceleration or engine braking is done via the two motor/generators. There are many good threads on this in Priuschat, but my favourite site for understanding how the PSD accomplishes this is:
    Toyota Prius - Power Split Device
  8. tlhamon
    tlhamon New Member
    30
    Flat Rock, MI
    I didn't realize that. Very good website. Thanks.
  9. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    672
    184
    "Glacial" Maine
    PSD is true gear genius!
  10. Todd Fury
    Todd Fury New Member
    FL
    Interesting...what are your settings, just regular old EV mode?
  11. xpcman
    xpcman Senior Member
    1,289
    264
    California - SF Bay area
    No "belts" in the Prius. B turns the ICE into a air pump. The gas engine is made to do work by pumping air through it.
  12. meehow09
    meehow09 New Member
    42
    Chicago
    Yes, I just used regular EV mode. I never press the EV button to engage the EV mode, I engage it by keeping it under the Eco/EV line on the small LCD display.
    I drive about 45% EV and 55% gas and electric mode for the rest.
  13. Mocmylov
    Mocmylov Junior Member
    Escondido
    I can maintain "ev" as well up to 45 mph the same way if the ground is completely flat or a slight downhill
    RocMills likes this.
  14. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,147
    365
    Whereabouts Unknown
    Well stated!
  15. Todd Fury
    FL
    Awesome! So do you have it in ECO mode and you just go light on the gas to keep it under the line in the display, or is ECO mode off?
  16. meehow09
    meehow09 New Member
    42
    Chicago
    I keep Eco mode on all the time and from a stop, I press the gas pedal for about 2 seconds to accelerate slowly in electric mode, then I accelerate more and stay in the ECO range of the bar in the LCD dashboard display. I accelerate to just over the speed limit and then let go of the gas and reapply to engage EV mode and gradually slow to under the speed limit. I then accelerate with the gas engine and repeat.
    Also, when I am almost home, I use EV mode completely for about .6 miles on a 35mph road and then about .3 miles on a 20 mpg road to my house. This really brings up my mpg.
  17. Todd Fury
    FL
    I guess I've been doing the same thing without even knowing I was doing it. Since I got the car on wednesday, I've just kept it in ECO mode and I've tried to stay around 35-50 mph, usually going as many back roads as I can so I can go slow. I've been getting insane MPG.
  18. Erikon
    Erikon Active Member
    819
    103
    Rochester, NY
    Unless you have a good downhill slope to recharge the battery with brake regen after using EV, it's the ICE that will have to work harder and burn more gas to do that. Remember, the electricity comes from the gasoline in a non plugin hybrid! It's long been considered the most fuel efficient method to keep the battery as full as possible, reducing the ICE workload. But learn the terrain, take advantage of EV when you know you can get a "free" recharge going down the next hill!
    robertmaria and Todd Fury like this.
  19. qbee42
    qbee42 My other car is a boat
    18,040
    2,984
    Northern Michigan
    EV driving produces a false sense of economy. You get great mileage while doing it, but you have to pay it back with interest to recharge the battery.
    It's like living high off your credit card: Everything is free for a month, and then you have to start paying it back, with interest.
    Use EV wisely to avoid unnecessary use of the ICE, but don't expect EV driving to save gas in normal use.
    Tom
  20. dig4dirt
    dig4dirt MoonGlow
    234
    25
    Lancaster Co PA
    2014 Prius c
    Also look and learn on the otherhand...
    When the ICE is running, take advantage and use the engine power to take to the top of the eco line.
    If the ICE is running, it is running, so use a bit to get up to speed, or gain some MPH to coast later.
    Mark323 likes this.
