amber light under glove box
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sebdoc, Jul 9, 2014.
  1. Sebdoc
    Sebdoc Junior Member
    CA
    There is an amber light glowing under the glove box. Does this have to do with the A/C cabin filter? Maybe needing a change. Couldn't find any info anywhere.
    Thanks
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    There should be a couple settings in vehicle customization for these. Its a courtesy light that comes on when you open a door, etc., and stays on for a while. I think there are LED replacements for them also if you want them brighter. Anyhow they are very dim.
  3. Sebdoc
    CA
    Thanks but it is not the courtesy light but a small amber bulb about 1/4 inch and is on all the time on the very bottom of the panel below the right side glove compartment. Could it have to do with the cabin filter?
  4. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Part of the courtesy lighting system.
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    If you look, it's only on when the headlights or parking lights are on. It lets you see into the lower glove box.
  6. Dokroma
    Dokroma Junior Member
    Australia
    i-Tech
    Can you not read the question? It is not the courtesy lights. It is a small orange light under the glovebox, look at the area where the passenger places their feet. Please read the question properly.
    I also have yet to find out what this light is.
  7. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    If it's not too bright, it's the footwell light.
  8. Dokroma
    Australia
    i-Tech
    Why would that be? It seems pretty useless as a footlight since it's so dimly lit, and why would the passenger side need a footwell light too?
  9. AzusaPrius
    AzusaPrius Senior Member
    1,673
    772
    Look under the drivers side too, you will find another light just like it, they are just footwell lights.
    You have to manually check the cabin filter without the help of any light or sound.
  10. ChapmanF
    15,110
    There have been some hasty conclusions on everyone's part so far.
    That one could indeed have been avoided by reading the question more closely, as it was not about the light in the glove box, but about the one below the glove box that shines into the passenger footwell.
    Those are two different lights (③ and ② in this drawing, respectively), though they both use the same part number.
    The parts are LEDs already. Under normal settings, they go very dim (but still not quite off) when you shift into driving gears, and they brighten when you shift into Park.
    If I remember right, by cross-referencing the corresponding Lexus part numbers, you can get versions using white LEDs rather than amber.
    Even after reading the question properly, though, "footwell courtesy light" is the answer.
  11. Dokroma
    Australia
    i-Tech
    If they are courtesy lights, they seem pretty useless as they're not very bright at all. Why even have that light there in the first place? The whole reason I discovered this light is because I saw it while hardwiring my dashcam.
  12. ChapmanF
    15,110
    Well, I don't know; mine seem bright enough in Park for me to notice if I'm leaving something behind in the footwell, which I think is more or less what they're for. As mentioned, they dim way down when shifted out of Park.
    I don't remember for sure, but there might be brightness choices for them accessible with Techstream.
  13. AzusaPrius
    1,673
    772
    I changed mine out with the lexus white ones.
    Much better and matches my 6000K led setup. 20211029_060912.jpeg 20211029_060944.jpeg 20211026_142324.jpeg
