Another case of "Can't open the hood" (and 12V batt replacement)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [H]ackerK, Feb 22, 2015.
  1. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Just this afternoon, I was able to open the hood once to check windshield fluid. It popped open smoothly as expected and I closed the hood.
    When I return with a jug of windshield fluid, I can't pop the hood again.
    There are still some tension on the hood release cable from under the dash, so I assume the cable is not broken. I have spend ~30 minutes keep trying pulling and releasing it, no go.
    I have read some posts saying using a small thin screw driver, try to 'hit' the latch under the hood. Still no go (or maybe I am not catching it right)
    Question: If the hood doesn't even pop up, assume I can 'hit' the latch (the one you normally 'touch' under the hood when it pops up a bit), will I still be able to pop the hood?
    Can anyone post some photos of the latch under the hood so I can get an idea where things are? (It is difficult to see)
    08 Gen II Prius.
    Thanks.
    p.s. where I am at, I can't lift up the car or go under as one post suggested. Nor I have any clue what I am suppose to reach even if I can get under, some photos might help.
  2. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Is it possible frozen shut , I don't see what part of the country ur from
  3. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Great White North, and it wasn't even that cold today. But I doubt it was frozen shut, because from the time able to open to second try which fails was under 5 minutes in an underground garage.
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If the problem is that hood release leaver gets all the way out before opening the hood. If you pull hood release leaver all the way out and look from underside of it can you see the cable? Can you hook into it with pliers? Just pull it a bit more. Or even pushing it with finger might be enough. If you can’t you will need to disassembly it a bit. Then when you get this done you should adjust he cable.
    Other thing that you can do is that you can try pushing the hood down a bit while somebody tries to pull the leaver. But you have to be very careful not to dent the hood. When you get this open you should clean and lubricate. And if the release lever was completely out adjust the cable.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    find someone to thump on the hood while you pull the release handle. that works on many cars and trucks; never had to do it to a prius.
  6. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Sadly, another attempt this afternoon still without any luck. Tried to thump on the hood, pulled the cable with pliers (Can't seems to pull more or I am afraid to break it), applied WD40, see the latch under the hood (the one you normally just a light touch with finger) and able to push that, none of them even move the hood a bit.
    I wounder how many fingers (if not an arm) is going to cost me. If it is not because of winter, I would just wait til next oil change to get it fix.
  7. valde3
    2,002
    745
    Finland
    How much does the leaver move?
    If it moves out all the way you should pull the cable harder. Cable can withstand a lot of force. Hood release lever has leaver action than more than doubles the force. Pushing (or pulling) the cable sideways in between the pulled out release lever and where cable attaches also gives you some leaver action.
    If release lever is not moving out all the way. Keep trying with pressing the hood. Push the hood down while somebody is yanking the release lever. Fast yanking action can work better than constant force. Try pushing down one (front) corner and lifting the other while pulling or yanking release leaver. Don’t use excess force.
    Is it now on heated garage or outside? Can you get wd40 in correct place? I haven’t checked mine but it’s probably better to go in from front grill with long nozzle. You can also check to see if there is anything obvious there. If you want to poke in there watch out for air con condenser radiator etc.
    Those tactics have worked for me on many (non Prius) cars. On many cars I have been sure that I have to do something else but eventually it worked.
    #7 valde3, Feb 22, 2015
  8. 69shovlhed
    2,170
    746
    Delaware
    it is difficult at best to get to the latch with a screw driver on most cars. all your pushing on is the safety latch. it isn't the actual hood lock. at this point, unless your very strong, pull that cable as hard as you can with vice grips, and get some one to push on the hood and thump it who won't hit it so hard they dent it. if that won't get it, I think you got to take it to a shop.
  9. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Yea, that was one of my initial questions. I figure if the hood didn't even pop up a bit, I doubt that safety latch will do anything for me.
    Seems like I am SOL. :( Maybe an early oil change (still 1500km before it is due) and hope the tech will fix it for free.
    Okinawa likes this.
  10. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I have the same problem most of the time with my Gen3. I can hear the latch release but the hood doesn't pop. I can get enough of my fingers under the edge of the hood to pop it. Spraying lithium grease on all the moving parts I can see gets it to pop open the next time but not the second. It seems to be worse in the winter but it happens all the time. Very annoying.
  11. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Lucky for you, at least the latch actually release, you just need to get your finger to the safety latch.
    yea, it sucks happens in winter, trying to work on the car is more painful...
  12. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    I had the opposite problem, my hood wouldn't latch. The latch parts appear to be unpainted and unplatted steel. The only rust prevention is grease. I got it freed up with wd40 then greased it good.
    You might be able to hit the latch with some kind of spray from underneath, but you'll need the car up. Also getting the car in a warm environment might lossen things up.
    If you cant get it that way you might have to gain access by pulling the bottom of the bumper out. Pop the sides, unbolt the bottom, and bend it up. Again a warm environment will help.
    Good luck this will be a pain. When you get it open don't shut until you have everything working smooth.
  13. bisco
    49,001
    if you pay for an oil change, and afterward you can't open the hood, it will be an interesting conversation.
  14. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Getting the hood to latch happens more often than people realize. The application of grease is mandated especially winter / salty months.
    DBCassidy
  15. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Sigh. I guess I must be having really bad luck with my prius...
    Tonight, the 12V battery is on it's last life. Takes a few tries before my car can start (boot) in the freezing temperature (what a sight when your dash lights up/blink like Christmas lights...) . I guess it is a sign to the shop...
    (Will check battery replacement post after dinner...)
  16. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    OUCH!
    The darn hood problem does make the battery replacement more costly...
    Short version: Can't access the jumper point under the hood to provide 12V during battery replacement
    Long version: Replacing the battery will lose TPMS pairing unless 12V is applied during the process. Because I can't open the hood, that complex the problem. To just pair up the TPMS, dealer cost C$160!! (Wth?!)
    On a different topic (not hood related as my original post). Dealer wants C$240 for battery alone, and C$119/hr (est an hour job)
    Worth taking my car and just let the dealer to work on it? (plus it is -20'C outside right now and I don't have a headed garage...)
  17. Mendel Leisk
    38,260
    I don't think the TPMS sensors get lost if you disconnect the 12 volt, unless second gen is different? For my 2010, some data does get dropped, but not the TPMS. At least, it appears to continue to function normally, no lights. I've purposely disconnected the 12 volt when working on the brakes, no memory saver device connected.
  18. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    This is what I've noticed as well while also doing brakes on my 2007. No TPMS loss, just radio stations, seatbelt and reverse buzzer settings were lost when I've disconnected my battery for wheel hubs and brakes.
  19. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    So I guess it is the matter of spending an hour in -20'C outside swapping the battery or in the comfort (??) of the dealership waiting room and pay $119 (hopefully) for the job.
    (assume I don't get ding on the hood problem and hope it's a easy fix)
  20. Mendel Leisk
    38,260
    When you bring it in don't let on about the stuck latch, act like they're the only guys that go under there. :whistle:
    [H]ackerK likes this.
